Question about Cell Phones
At & T I called but they couldn't solve my problem even though the phone is new the waranty has expired. I don't think they know too much in there either.
  • eddiev65 Nov 20, 2009
    I have a Blackberry Curve 8310 it works fine sending text messaging and receiving, but when
    I am in the middle of a conversation the call drops or it starts loading, it shows the symbol like when is searching for a network that little loading symbol. I'd called my provider At & t but their only solution was, for me to buy another phone, since the waranty had expired, but this phone is new and I would like to fix it if possible.
    but when I am in the middle of a conversation the call drops or it starts loading,
    President:
  • 2,185 Answers
Can you specifically define the problem with your phone? What is the make and model?
Posted on Nov 20, 2009
  • 643 Answers
Hello and welcome to Fixya! What is the issue that you are having with your phone? Please be as descriptive as possible, what happens, what you are doing when it happens.? How often does it happen? Please respond to this thread and i will be happy to assist you!
What is the PUK code for Samsung T301G tracfone
My dear:
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
But:
Don't try to enter a PUK code without knowing the right one.
You need to call your service provider to get this code.
It can be as many as 8 digits, and it is random. If you enter too many wrong codes,
you can permanently damage the device. So Please You Go to Service office
and Get the Duplicate Sim From Office Oprater
Same Your No Problem will Solved
Oct 15, 2012 | Samsung SGH-T105G
The thing in the middle that holds the disc moves up and down. What do I do?
Does it still have waranty? I would take it back to the place purchased or send it back to the company for repair or replacement. If it is old or out of waranty I would consider whether it would be worth repair costs or just buy a new one if it is less expensive to buy new or used... I could be wrong but unless there is a screw in the top or the bottom to tighten it down (and if so be careful not to tighten it too tight) and there could also be a screw under the cover but be sure it is out of waranty before taking the cover off even to check that would void the waranty. Hopefully it is something that simple or it is under warantee and can be replaced. Sorry couldn't be much more help.
Aug 06, 2012 | RCA DRC629N Portable DVD Player
My phone is lock
I had the same problem last year, I was messing around with the security part of my phone and I dialed in the wrong code so many times that my SIM card locked up on me and I couldn't call or text anyone, except to only 911. that is what is happening to you.
Since your SIM card is locked since you punched in the wrong PUK code, call your cell phone customer service, explain the situation, and what they did with me is they sent out a new SIM card in the mail to me. They would probably do the same thing to you as well. and when you get your new SIM card you would have to call your cell phone company customer service and have the SIM card activated.
Next time don't mess around with the security part of your phone and don't dial in any wrong codes that you don't know of. I learned my lesson when it happened to me. I went with a prepaid cell phone company and they said that if I did it again that they wouldn't give me another SIM card and I would have to purchase a new phone.
good luck :-)
buy F150 parts.
Jun 03, 2012 | Samsung SGH-E251 Mobile Phone - Black
It reads unit is in safeguard mode Eject and reinsert tape I need to see a manual of the inside of the tape housing unit because I found a black rubber wheel that I think needs to be put back in
Remove the battery while the camera is at the "on" position then put it back. Press the forward or rewind button then stop. This should solve your problem. It works for ither JVC owners. Are you try with other new tape?
Turn's out that JVC Does that to protect your camcorder some do it some don't because there might not be a problem and JVC will pay a tech to unlock this mode under waranty and you can get extended waranty by calling satis fusion at 1-888-269-6432 even your item is out of waranty.
Hop helps.
Jun 15, 2011 | JVC GR-D94 Mini DV Digital Camcorder
Air compressor is working but air is not pumping to the tire. Initially, started filling but after certain time, pressure in the tire stopped increasing
Checkthis website:
http://servicenet.blackanddecker.com/Products/Detail?productNumber=VEC012POB
The PN is Vec012POB not Veco12POB
Jan 31, 2011 | Peak Performance Peak PKC0BL 450 Amp Jump...
No power to the coil. Car cranks but no spark from coil and we replaced the coil new 2 times figured that the 1st one was defective but still no spark
I had similar problem would crank but not start. Tried many things finally found the distributor wires & cap was the problem. Was many years ago don't remember exact details, think cap had hairline crack that couldn't be seen. Just enough to let moisture in to the wires. replaced cap problem solved. Good luck.
Aug 16, 2010 | 1989 Chrysler LeBaron
A contact that I regularly sms and call is no longer receiving my txt msgs (even though the txt goes to my SENT box) and when I try to call this contact i get a msg that 'the number is not in use' even...
I don't think its a problem in your phone. The problem must be in your comtact person's phone. I also think ( if the person is not much known to you ) the no. has activated its utility to block you. Chek the other's phone.
Aug 14, 2009 | Nokia 6300 Cellular Phone
Acer aspire 2930 series when using bluetooth flashes and laptop starts writing itself
it's a hw problem. when i using my easyport iv it doesn't occures. only when the display is turned up. after 2-3 hours of use i think it's overheating. (i tried to buy a waranty extension after i bougth the laptop, but acer said "it isn't available". i think thew know someting about this problem...) i bought it in Jan 2009, and the problem occured in Jan 2010. just after the warranty expired. wierd...
Mar 01, 2009 | Acer Aspire 5100 Notebook
Thank you
they will cover everything that is wrong with it... just make sure they know about it
Jun 17, 2008 | Microsoft Xbox 360 Console
Sound
http://www.geeksquad.com/pricing/default.aspx#section3
That is the link to the Geek Squad general price list. It would be best to call them and talk to them inperson and not just go by the prices listed on the site. Also, if you are still under waranty, you are always best off having the manufacture do the repair work for then your waranty on all work done is covered and also the new parts are covered by waranty under the manufacture.
Apr 29, 2008 | Computers & Internet
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
