Question about LG VX5200 Cellular Phone
Programing mode for lg vx 5200 - LG VX5200 Cellular Phone
  • 643 Answers
Hello, and welcome to fixya..
what type of programming are you trying to load or do to your vx5200?
Please reply to this thread and i will be happy to assist you!
Posted on Nov 20, 2009
Does the lg 5200 have a master reset
  1. Press OK key for MENU, Right Navigation key two times, 5 key, 5 key.
  2. Enter 4 digit lock code. The default lock code is the last 4 digits of your phone number.
  3. Press 5 key (Reset Default).
  4. Press OK key, select Revert and then press OK key.
Dec 21, 2012 | LG Verizon Vx5200 Camera Flip CePhone...
User guide for the LG VX5500
http://www.phonedog.com/products/lg-vx-5200/manual/
you can download the manual from the above mentioned link....
Jun 09, 2010 | LG VX5200 Cell Phone
LG Migo says initial program needed. what does
Power off, then power back on. WIthin 10 seconds, press "yes", "1", "4" and then "yes". It should them take about 2-3 minutes to complete the initial programing and the word "Successful" will appear on the screen.
Nov 18, 2009 | LG Migo VX-1000 Cellular Phone
My LG VX-8700 does not vibrate. Ring works, but vibrate mode is the same as silent mode. Can this be fixed?
Yes,
What happened is you probably set it on silent and from the soft keys, you increased the ringer volume. What you want to do is go to main menu => settings => profiles, and from there make sure your ringing volume is set on lowest possible.
Oct 28, 2009 | LG VX-8700 Cellular Phone
Instructions to manually program LG VX-9800
Check out this link below to download a PDF manual for you phone. Just copy and paste into your browser.
http://www.phonedog.com/cell-phone-research/lg-vx-9800_user-manual.aspx
Hope this helps. Let me know if I can do anything else for you.
JimmyC
Oct 12, 2009 | LG VX9800 Cellular Phone
My LG 8350 is snapping in half
I don't see a problem statement here that needs a solution by someone else.
Broken hinges on LG VX-8350 are notorious failure mode for this model. You may be able to find and obtain a water-damaged phone for small money and transplant only the keypad shell body (the broken hinge part) to your phone. To separate the keypad and screen shells on the good body unit, look here:
http://www.fixya.com/support/t1525077-repair_broken_hinge_verizon_lg_vx8350
Aug 26, 2009 | LG VX8350 Cellular Phone
I have a LG vx 5200 that displays the words "Car Kit" after getting wet
Take your phone apart, an using a soft toothbrush clean the CN302 connection at the base of your phone, next to the connector there's a U204 IC with identinfication AAD1 on it. Those are the main areas that needs to be cleaned. For better results you can use a bit of NON-alcoholic cleaning detergent. This will solve your problem.
Best of luck
Jun 27, 2009 | LG VX5200 Cellular Phone
Manuelly programming lg vx 9900 to cricket service
any missing info should be provided by your reseller.......
here is what I found...
Note: Some Programming must be done from the internal keypad / QWERTY Keyboard.
Alternate Programming Sequence for the VX9900 (Orange) or for newer software versions.
[#] [#] + [7][7][6][4][7][2][6][9][9][0][0] + [SEND]
OTA PROGRAMMING
Step 01:
Change ESN in billing system.
Step 02:
Power up the handset.
Step 03:
Dial *228 + SEND
Step 04:
Follow the VRU prompts
USE OTA Where Available. If OTA is not available follow instructions below.
Top
AKEY PROGRAMMING
Step 01:
Generate a random A-Key and power phone on.
Step 02:
With the flip CLOSED, press 2539 + * + * to access AKEY INPUT MODE.
Step 03:
Press 1 for Akey Entry
Step 04:
New AKEY displays, enter 26 digit A-key then press OK when complete.
PROGRAMMING COMPLETE
Feb 03, 2009 | LG enV VX9900 Cellular Phone
LG VX 5200 - Permanent Blue screen Display Problem
I had the same problem and just fixed it, literally five minutes ago. You'll have to be a little brave and sure of yourself because it involves taking the phone apart. Around the inside screen are four silver cushion/spongy pieces. Remove these with a very small flathead screwdriver and set aside. Now you will need a very small Phillips head screwdriver to remove the four screws that are underneath these cushions. Once they are removed very carefully use the flathead screwdriver to "crack" open the phone housing. Once it is opened you will see a gold/tan colored ribbon coming from the lower half of the phone. All you have to do is press down on this ribbon to make sure that it is connected to where it is supposed to connect. It's like a puzzle piece that has to fit perfectly in order for the screen to work properly. You can check to see if it's working by turning the phone on before replacing the housing. If it is not recheck the "puzzle piece." I hope this helps.
Sep 28, 2007 | LG VX5200 Cellular Phone
LG VX5200 Cellular Phone Logo
81 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
