Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
I need to program a key pad for an overhead garage door.
    President:
  • 3,197 Answers
On the rear of the motor unit you will find the smart/learn button. Press and immediately release this and then walk over to your keypad and key in any 4 digit code you like and press enter.
Posted on Nov 20, 2009
Garage door will not go up using remote or keypad only with wired unit inside garage. Batteries were changed in remote and keypad.
You need to reset the remote units. There should be a button on the overhead unit that operates the door opener that will tell you what to do. To set my key pad I push the button and punch in my code then it flashes three times then I push the button on the opener again and the door will go up or down. You do the same with the car remote as well.
Sep 10, 2017 | Building Materials
The remote does not work on the outside of the garage. The batteries have been replaced, and I did reprogram the remotes. What's next?
My key pad outside I had to program by punching in my code and pushing in a button on the overhead unit and holding it till the light flashes two or three times.It took two of us because I am not fast on my feet to get up there.
Jan 12, 2016 | Craftsman Garage Door Opener 1/2 HP Belt...
How do i pair a clicker model klik2u key pad to a overhead door model 455 opener
http://chamberlain.custhelp.com/app/answers/detail/a_id/2578/~/clicker-model-klik2u-wireless-keyless-entry-owners-manual
Jan 19, 2015 | Building Materials
Liftmaster door opener
Try using one of your other buttons on the remote , this is only if you have a 2 or 3 button remote , Sometimes the contacts wear out from daily use on the remote ! If that does,nt workout for you then you can purchase on ebay a liftmaster /chamberlain universal receiver ! The receiver is 1/3rd the cost of a logic board and performs the same function! You can plug the receiver overhead of your opener and you will need to wire the receiver with low voltage wire that comes with the receiver to the receiver and then to the #1 and #2 terminals on your garage door opener and that's it! They work right out of the box and it will cost you around $ 20- 25 dollars theres no programming neede unless you need to program a key pad , Just make shure that you get a receiver that has the same frequency as your remote ! Good luck ,I hope I was able to help you! Sincerely Glenn
Oct 28, 2014 | Building Materials
I have a clicker model KLIK2U and forgot the code. How do I reprogram without the old code?
It's really easy to reprogram your unit:
Step 1. Hold down the (*) and the (#) keys until the keypad stops flashing.
Step 2. Determine your opener ID using the list below:
*1= linear garage door openers manufactured from 1997 to
present.
*2= Chamberlin, Sears, Craftsman, LiftMaster, Master
Mechanic and Do it garage door openers manufactured from
1997 to 2004 ( Orange learn Button)
*3= Same as *2 above, but manufactured from 2005 to present
with a (Purple learn Button)
*4= Same as *2 above, but manufactured from 1993 to 1996
with a (Green learn Button)
*5= Genie Intellicode and Overhead Door garage door openers
manufactured from 2005 to present (315 MHz).
*6= Same as *5 above but manufactured from 1995 to present
(390 MHz).
*7= Stanley garage door openers manufactured in 1998 to
present.
*9= Wayne Dalton garage door openers manufactured
in 1999 to present.
Openers with learn Buttons
Programming: Enter the PIN that you want to use, remember
(4) digits only. then press #
Enter ID # from list above, for example 2 then #
Press and release the Learn button on your
garage door opener.
Enter your (4) digit PIN and press (0),
for Genie and Overhead door units press
(0) twice. To test and use wait for light to go out
on keypad, Enter you PIN and press (0).
Note: If opener doesn't function repeat programming.
Instructions if required.
Sep 17, 2010 | Universal Garage Wireless Keyless Entry...
Key pad not working. Garage door will open with
I'm confused about the battery you replaced inside the garage but you can try programming the keypad just to see.
Locate the smart/learn button on the back of the motor unit near where all those white wires go. Press and immediately release it and then walk over and key in your 4 digit code and press enter. If this doesn't work and you know the battery inside the keypad is good, you have a bad keypad.
Mar 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
How do you program an Overhead Door garage door opener for a Clicker that soesn't have a smart learn button
Click the button on the overhead unit . it's square it will light up. Click your remote ,it will flash and then it's done
Dec 30, 2009 | Universal Garage Wireless Keyless Entry...
OLD garage door opener
Sounds like you have the keypad that is hardwired.
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
These instructions may not work if the keypad is some other manufacturers.
Aug 23, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door key pad
For most openers you don't need the old code.
Just press the program button on the powerhead enter the code you want in the keypad and press enter (within 20 seconds).
Jul 28, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
248 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
