Question about Hitachi Televison & Video
Hitachi 53uwx10b template
I'm looking for the convergence jig for a 53UWX10B
    Scholar:
  • 62 Answers
Hi, first what exactly are you looking for? the convergence board of the STKs number? If you have convergence problem, you will need to change the STKs for sure and check the resistence to the STKs and generally all of them have same low value. check it out and replace the faulty onces. switch on and adjust convergence and you have a good working picture on the screen. Visit www.fixurtvs.com for more FAQs.
Posted on Mar 22, 2010
Screen at top has a sag look to it what couses this also the coler dosent match up
your convergances amps have failed not a bad job but suggest you have a tech take care of it
Nov 24, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53uwx10b Convergence Grid Tilted A Little...
If the tilt is not that bad, I would leave it be. The reason is yes you can straighten the tilt out, but it requires a mechanical alignment to all 3 CRT's then you will have to align the convergence on all 3 as well. Please take a few moments to rate my answer. Thank you.
Nov 18, 2009 | Hitachi 53UWX10B 53" Rear Projection...
I changed the IC chips on my hitachi 53uwx10b tv like you guys said that helped alot but still have wavey lines on both sides of the screen what do I change on the con. board now? Thanks alot Jim
Resistors " RK42 3.3ohms
RK46 1.8ohms RK50 2.7ohms RK54 1.5ohms RK58 3.9ohms RK62 2.2ohms After you replace all of them then enter convergence by pulling OFF bottom front panel there on front of convergence board is a small blue button press it and a convergence pattern will come up now aline each color red then blue.
Sep 24, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Convergence settings on hitachi 53uwx10b
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 10, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Ineed to know what convergence ic's are in this tv
Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Apr 17, 2009 | Hitachi 53UWX10B 53" Rear Projection...
53UWX10B blurred pic and blue/yellow lines
you can try the convergence first
if you cant converge the lines into one to correct this then you would require service for the convergence stage of your set
this is not a uncommon problem and usualy runs around 280 to 350 to repair unless the dcu is at fault
Jan 20, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53UWX10B Convergence cutting in and out
Good Day, Armenian;
You have poor connections on the convergence IC's , re solder and your TV should be back to normal.
Good Luck, big IRISH.
Aug 04, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Convergence i.c. board
Yes, you need two convergence ICs for your model STK392-110 heres the link to the site.
http://servicemanuals.vstore.ca/
Apr 29, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53uwx10b
Hitachi has created a repair kit part# X480293 for this problem. It includes: (2)STK392-150 convergence ic's,resistors RK42 = 3.3 ohms,RK46 = 1.8 ohms,RK50 = 2.7 ohms,RK54 = 1.5 ohms,RK58 = 3.9 ohms,RK62 = 2.2 ohms,all 1 watt resistors.
Aug 20, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Televison & Video Logo
88 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
