Question about Mountain Plumbing SOLID BRASS DRAIN KIT - 4" ROUND PVC PIPE MT507P-ORB
Inspector said you cant tie anyother fixtures into a vent. DWV
I had a inspection on a house to day it has 2 floors. they tie into another floor unknow how they tie togather but was stub up for the other two floors . the inspector said i could not tie waste into these lines are 3'' . all i am putting on it is another toilet and sink . and he all so said i could not reduce the vent off of it to a 2'' above the last tie in
    Scholar:
  • 35 Answers
What state is this? Each code varies slightly within states. More than likely, your inspector is right. There are guidlelines we have to follow as to where and how (toilets especially) tie into the sewer. You may still be able to tie your toilet into this line, but in a different spot. It is much too complex to be able to walk you through the steps. Many inspectors are not very accommodating to a homeowner trying to do their own work. Without visually seeing the entire system, I doubt anyone will be able to help via the internet. Due to the complexity of the plumbing codes, I would highly encourage you to see if a plumber would be kind enough to just look at it for you, and offer some suggestions. I believe what you need can be done, but perhaps just not the way it is done right now.
Posted on Nov 21, 2009
Office of the ombudsman
Surely your toilet is part of fixtures and fittings and as such is the liability of the property lease owner.
Yes expensive!
Jun 13, 2014 | Computers & Internet
I have a Ruud air conditioner model #13AJA36A01757. The temperture out of the vents is only 70 degrees while it is running. Outside unit, low side is very cold, and the high side is not hot, not even...
If your vents are in the floor, you need to inspect your return air ductwork, you may have some air leaks pulling hot attic air in thru the vents. If the supply vents are in the floor, the return duct may run through your attic, if the duct work is uninsulated or pulled apart, it will pull hot air thru the return, causing a mixture of cold and hot air, giving you a warm air movement through the ductwork. Many service men will not catch this problem. You need to turn the unit on, go up in the attic and visibly inspect the entire return air. I hope this helps you. mark
Aug 14, 2011 | Ruud Heating & Cooling
Will not change from defrost to floor, vent or anyother funcion on the heat side of the air system
check for a vacuum leak at the intake manifold, sounds like you have a broken vacuum hose to the heater control.
Feb 12, 2011 | 1995 Ford Econoline
Basement plumbing. I want to put in a basement bathroom and my plumbing drain from the house is 4' from the basement wall. I need to put in a sewer basket and venting. any diagrams to follow?
My suggestion is to build up the floor where the tub will be maybe 12" above original floor and u can make a couple steps up to the tub the whole length of tub
Dec 10, 2010 | Home
Range Vent is only 3 feet from the floor
sUGGEST SAFETY INSPECTION BY LOCAL GAS COMPANY. USUALLY FREE!
Nov 08, 2009 | GE 30" Freestanding Gas Range - White
I have a 94 jeep wrangler front left axle seal bad. I took the left side apart and not sure how to get the seal back in. Do I need to open the inspection cover on the diff. and take the gears out?
Rear Axle Notes
  1. Raise and support vehicle.
  2. Remove rear wheels.
  3. Scribe alignment marks on propeller shaft and axle for proper assembly, then disconnect propeller shaft from axle.
  4. Disconnect the track bar from axle mounting bracket.
  5. Disconnect parking brake cable at equalizer.
  6. Disconnect shock absorbers at axle tubes.
  7. Disconnect hydraulic brake hose at rear axle Tee-fitting, then tape ends of hose and fitting to prevent contamination.
  8. Disconnect axle vent tube from axle.
  9. Remove U-bolts and tie plates.
  10. Loosen spring mounting bolts.
  11. If equipped, disconnect ABS wiring connections at axle.
  12. Support axle with suitable jack.
  13. Remove spring-to-shackle attaching bolts and lower spring to the floor.
  14. Remove axle assembly.
  15. Reverse procedure to install.
Front Axle Notes
  1. Raise and support vehicle at frame behind front springs.
  2. Remove front wheels.
  3. Scribe alignment marks on propeller shaft and axle yoke for proper assembly, then disconnect propeller shaft at axle yoke.
  4. Disconnect connecting rod at steering knuckles.
  5. Disconnect shock absorbers at axle housing.
  6. Remove stabilizer bar connecting links to spring tie plates attaching bolts, if equipped.
  7. Disconnect breather tube at axle housing.
  8. Disconnect stabilizer bar link bolts at spring clips.
  9. Remove disc brake calipers, rotors and brake shields.
  10. Remove U-bolts and tie plates.
  11. Support axle assembly with suitable jack to relieve spring tension.
  12. Loosen rear spring shackle to spring attaching bolts.
  13. Remove front spring shackle to spring attaching bolts and lower spring to floor.
  14. Remove axle from under vehicle.
Jul 21, 2009 | 1994 Jeep Wrangler
Sewer Gass after using Bocsh 300 washer
When you have problems with sewer gas smells around a
fixture, there can be a number of causes.
1. Sewer gas coming back up into the home
a. Blocked vent.
b. No vent.
2. Leaking drains that cause rotting below the floor.
3. Moisture that causes mold buildup.
4. No trap on your sink.
5. One roof vent on septic system.
6. Toilet needs to be reset and calked.
Sewer gas can come back up into your home, when the
trap completely empties after a letting the water out
of a fixture, when the trap dries out, or when it is
sucked out by another fixture flushing. When water
goes into a pipe, it first has to push the air ahead
of it, if there is no place for it to go, it comes up
the trap. This causes a buildup of pressure if there
is no vent.
If there is a vent, the pressure is relieved up to the
roof, carrying with it all of the yucky smells. When
the water runs down the drain, the air behind it has
to be replaced, if its not, the pipes will try to ****
it from some drain...typically the shower drain, but
sometimes the floor drain when its close to a washer.
When vacuum draws air in through the trap on the
laundry tub it also takes the water out of the trap,
leaving an opening where the sewer gasses can come
back up from the septic system .
Think about your pipes as if they are a drinking
straw. When you put a straw into a glass of water,
the water fills the straw. But if you put your thumb
over the end of the straw and pull it out of the
water, the water (or liquid) stays in the straw. This
shows you, air has volume. When you remove your thumb
from the end of the straw, the water flows back into
the glass. This is the principal of a vent.
So if you only have the smell when a fixture is
running, the trap is refilling after the fixture and
blocking the sewer gasses from coming into the home,
but your vent is probably not functioning.
In addition, if you have only one vent up through the
roof on a septic system, you can get sewer gas smells
coming up through your home. As the wind blows
across the roof, it pressurizes the plumbing system.
Since the septic tank is full of water, the wind
cannot go into the septic tank. So it bubbles up through the
traps into the house. Installing a vent on an
opposing roof pitch, helps to relieve the pressure buildup,
since the wind then is only hitting one side of the
roof.
Floor drains are succeptable to this type of pressure.
If your drains are partially clogged it can work
similar to a clogged vent. Since there is no place
for the water to go, it forces the air, which is much
lighter up through traps, bringing sewer gas into the
home.
If your fixture is not set right or is wabbling, the
traps or wax ring that seals it underneith may not be tight.
When this happens, if you empty the fixture, sewer gas
will come under the sink into the room.
Each of these senarios will require a different
solution. The key to solving your problem, is having
the right questions to ask when the plumber comes out
to look at it. The previous information should
provide you with a basis for the questions you need.
Make sure before you call a plumber to check
cleanout covers and pipes to see if they have
openings to the sewer. If you have an opening
without a trap, you will get sewer gasses.
In conclusion, if you don't have a vent inside the
wall which equalizes the air pressure inside the
pipes, if you are on a septic system with only
one roof vent, if the vent is clogged off due to
sludge and soap scum, if you don't have a proper trap
on your sink, or if the drain is clogged, sewer gas can escape
into your home.
Thanks for using FixYa - a FixYa rating is appreciated!!
Feb 13, 2009 | Frigidaire ATF6000ES Front Load Washer
First floor of house is cold
The thermostat will turn your furnace on and off to satisfy the temperature setting at the location where the thermostat is located. If you move the thermostat to the first floor and set the thermostat at say seventy, it should keep the furnace on until the temperature near the thermostat hits seventy degrees.
Feb 06, 2009 | Honeywell Focus 6300B 5-2 Days...
Carrier weathermaker 8000
Is this an up flow system,(vents in the ceiling) or down flow, (vents in the floor?) As always, theres a place to add filters , before the fan on the suction side! No telling how long this been running without the filter and already contaminate the freshair system.. This is supposes to be checked out by the building inspector before you buy any house,Just talk it over with the Realestate Agent , have the full system cleanned and send them the bill or talk to your big brother the BBB! Thank-you-very-much!
Aug 30, 2008 | Carrier XHB123D X/Y Series Heat/Cool Air...
Mountain Plumbing SOLID BRASS DRAIN KIT - 4" ROUND PVC PIPE MT507P-ORB Logo
81 people viewed this question
Top Mountain Plumbing Plumbing Experts
Tom Chichester
Gil Shultz
Are you a Mountain Plumbing Plumbing Expert? Answer questions, earn points and help others
