Question about Panasonic Lumix DMC-FX01 Digital Camera
Turn off card protection
I am getting an error messafge that the memory card is protected, how do I unprotect it, ican't take pics
  • ghost21225 Apr 03, 2008
    i just brought an 1gb micro SD card and i can't take pictures. it says card protected. the card is in unlocked position.
  • 4 Answers
The SD card has a small "lock" slide switch on its side. Simply slide it away from the contacts edge.
Saul.
Posted on May 16, 2008
6ya staff
SOURCE:
How do I unprotect pics on a 0lympus c-765
As it was the camera that put the protection on ..You need to put the card into the camera..And ..UN-TICK each one to unprotect them...The idea of the protected photos is so you cant erase them when you format the card.
Sep 28, 2014 | Olympus Camedia C-765 Digital Camera
How to unlock a photo in camara
The protect function allows a user to protect a picture from accidental deletion. To unprotect a picture on your camera, scroll to the protected picture that you want to delete, then press the Menu button (the button to the right of the Play button.) Scroll down the menu and you should come to an option that allows you to Protect/Unprotect the picture. Since your picture is currently protected, deselect that option. You should then be able to delete the picture normally.
Alternatively, you could also format the memory card, however this deletes ALL photos and data you have on the memory card. If you are trying to completely clear the memory, this is the best way. After turning on your camera, simply press the Menu button, scroll to Setup, then scroll down to Format. Select Format, it will ask you if you want to format the memory card, or the camera's built-in memory. Format whichever one you want to clear, if you are using a memory card then your pictures are stored on the memory card. It will take a few seconds to format.
Hope this helps.
Dec 05, 2012 | Kodak EasyShare M1033 Digital Camera
Unprotect images?
You can unprotect an image the same you you protected it. Press the MENU button, select the wrench icon, then select the key icon.
Details are in the "Protect" section of the manual (page 111 in my copy). If you need a manual, you can download one from the manufacturer's web site at
http://support.nikontech.com/app/answers/detail/a_id/16311
Jul 29, 2011 | Nikon COOLPIX L100 Digital Camera
PROTECTED CARD
Most SD memory cards have a small slide switch on the edge off the card. This switch is used to write ptotect the data on the SD card - you can lock or unlock the SD card be sliding this switch.
Jun 18, 2010 | SanDisk 2GB microSD Memory Card
My card says: card write protected & won't let me take pic's
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Apr 21, 2010 | Canon Rebel XT / EOS 350D Digital Camera
I cannot delete photos from my panasonic lumix FS5 camera via the PC like other cameras in my office. I get an error message stating it is not possible because of right protected - I have tried moving the...
To delete all or just one of the pics on the memory card -- go to the play mode and use the Q Menu on the very bottom right -- you can select your choice from there.
In play you can also go to Menu and Protection and select if you want all or one photo protected.
Hope that helps!
Took me a while to figure it out!
Nov 12, 2009 | Panasonic Lumix DMC-FX33A Digital Camera
Olympus camedia c-3040 zoom how to delete pic
Judging by your explanation, the photos are on your sd digital memory card rather than the internal memory.
Since you are unable to delete just those 15, it sounds like you might have accidentally enabled the "protect" function.
Get out your manual (or download a new one) and read about how to protect/unprotect photos, and also read about how to format your card in camera - something you should do on a VERY regular basis for the health of your memory card.
While you have the book out, read ALL of it - twice! You'll be amazed how much you'll learn.
Oct 03, 2009 | Olympus Camedia C-3040 Zoom Digital Camera
My memory stick is protected
Just wanted to know if there is a slide switch anywhere on the memory card? .. See the image below where it says LOCK:
http://www.labamanta.lv/cache/product_images/big/20090205/sandisk_2gb_sd_card_1.jpg
Toggle the switch if there is any and that should help.
Regards,
Srinivas
Jun 21, 2009 | SanDisk Memory Media
Protected pics on cam
To Unprotect go to MENU down on the lower left when ur looking at screen press menu while u have one of the protected pics up. Go to Protect folder-select-ok-hit W at top-ok
it is now unprotected and u can delete from here!
Mar 14, 2009 | Samsung Digimax A503 Digital Camera
How to unprotect the memory card
the problem isnt with your camera, its your memory card, and it isnt a problem at all. simple solution- take out your memory card, and on the side there is a tiny switch. all you gotta do is flip the switch. quick and easy. hope that helps anyone.
May 18, 2008 | Microtek Take-it MV320 Digital Camera
Panasonic Lumix DMC-FX01 Digital Camera Logo
133 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
