Question about Whirlpool Dryers
I have a Whirlpool dryer model # LER7646EQ2, some time ago the timer setting started acting up, it would go down to about 20 min. but never shut off. At that time I started using the automatic drymiser setting which was fine for about 3 mos. now it won't shut off again. I think it's probably the timer but wanted a pro's opinion. Thank You
  • chue2u Nov 23, 2009
    Thank you very much for your reply. I was wondering how to go about checking the things you mentioned, if you can tell me that would be very helpful. Thanks
  • 5,138 Answers
Relay that starts and stops dryer, Call Encompass Parts Distr 1-800-638-3328 also go to E-Bay Look under washer/dryers you might find what you need there and cheaper too. they list Part to start which is what you need as 3398095 Price is 34.95
Posted on Nov 23, 2009
  • 10,515 Answers
There are few things you need to check :-
1. You need to check the Knob.( Rare Case )
2. You need to check the Cycling Thermostat.
3. You need to check Timer.
Let me know, if needed further assistance.
Hope i helped you,
Thanks for using ' Fixya ' and have a nice day!!
Posted on Nov 20, 2009
Whirlpool Duet dryer time skips mins.
clean the stainless steel sensor pads located just inside the dryer door with isopropyl alcohol,these sensors register moisture in the garments and adjust drying times accordingly,when you use dryer fabric softener sheets it coats these sensors and throws the system off,make sure to shut off power to unit as this alcohol is very flammable,then leave door open to air out before re-powering up unit
Apr 24, 2012 | Whirlpool GEW9250 Electric Dryer
Whirlpool dryer model #LER7646EQ2 dryer will not start up
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Sep 13, 2011 | Whirlpool Dryers
Dryer will not turn on,timer is counting down. I do not have a fuse problem, can you give me possible reason. We just finished a load of wash last night. ...
heatman101
Apr 30, 2011 | Whirlpool Dryers
My Whirlpool dryer(supreme) does not start. The timer switch, door switch, start switch can all be heard to electronically switch on and off when I turn the timer around and open and close the door....
the thermal fuse may be faulty. Remove the outer back of the dryer. the thermal fuse is located on the blower assy with 2 wires connected to it. It is white plastic. connect the wires together, then try to start the unit again. If the unit starts, clean the exhaust duct after replacing the thermal fuse.
Jul 20, 2010 | Whirlpool LEQ8000JQ Electric Dryer
My Frigidaire electric dryer GLER341AS2. The
Does it shut down completely? If it does, and the timer ceases turning, your problem may be a blocked vent pipe or Lint buildup.Your high limit switch is designed to kill power to your heater coils and sometimes the motor in case of overheat.
Mar 09, 2010 | Frigidaire GLER341A Electric Dryer
Inoperable Whirlpool dryer, Model LER7646EQ2
Good day,
Sorry, no reset you can get to. There is one embedded in the main motor itself, that if the motor draws too much current, and/or gets too hot.
If you shut the machine off for a 24 hour period, then it will many times appear to run normally again, but it's the motor getting weak.
It's usually a slow progressive problem, and if you choose,you can, at least for the short period use the machine by either lightening the loads, or spread the loads over a longer period of time.
Eventually the motor will need to be replaced.
Feb 21, 2010 | Whirlpool Dryers
Whirlpool Supreme Dryer will Not Start
I have a whirpool heavy duty dryer that is not working. When I push the button to start the dryer it only roars, and the drum will not move.
Dec 30, 2008 | Whirlpool LGR7646E Dryer
Sensor dry timer problem
Clean off the moisture sensor bars. They are the silver curved strips about 4 inches long inside the drum near the lint fitler. If you use fabric softner sheets, a waxy build up will coat the bars. The dyer can no longer sense the damp clothes, so it goes into the cool down and then shuts off. Time dry bypasses the moisture sensor.
Nov 30, 2008 | LG DLE5977 Stainless Steel Electric Dryer
Whirlpool gas dryer model number ler7646eq2 does not produce heat
Need more info. Does it rotate? If it has a viewing door on the front, you may see if the ignitor is glowing. If the ignitor glows, the ignitor (flame) sensor may be bad, and the ignitor will shut down.
Aug 09, 2008 | Whirlpool Dryers
Dryers Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
