Question about LG Shine KE970 Cellular Phone
LG SHINE PHONE... am trying to set the alarm on it but every time I try to save the setup it says "input string" ? any ideas about this?
  • sabrina030 May 11, 2010
    Basically all you do is click menu/tools/alarm clock, You just set up the time, days, and sound then cick save and If this doesnt work then i dont know
I cant send pictures on my lg shine phone
It shows that the MMS settings are not saved on your phone.Contact your network service provider and they will send you a cofiguration message.Save the message and restart your phone.
Jun 27, 2009 | LG Shine KE970 Cellular Phone
I have an lg shine and everytime i try to send picture it wont let me it say no mms setting
To send and receive MMS you have to save the MMS settings on your phone which is send to your phone as a configuration message by the network service provider..
Jun 25, 2009 | LG Shine KE970 Cellular Phone
Cannot upload pictures from LG Shine phone to computer
If your pics are on your card for sure than you may half to remove the card and connect it directly to your computer. The file may have been
saved to the wrong part of the card. This may not be the answer but it
has happened to me in the past. If you have not saved the pics to the
card that is your problem. You must save the pics to the card and try again. You should be able to select a pic and move it to the card.
after you do either of these two ideas you should be able to move your
pics to your computer. hope this helps.
Apr 25, 2009 | LG Shine CU720 Cellular Phone
LG shine CU720 moving pictures rto memory card.
The LG Shine allows you to do a multiple picture DELETE - but not a multiple pic transfer to memory card, at least that I've found. You have to transfer your pics one at a time from phone memory to the SD card as follows:
Select Menu --> 8 My Stuff --> 4 Pictures
Highlight the pic you want to transfer using the center toggle button,
then select Options --> 5 Move (or 4 Copy) --> 2 Memory Card --> Paste
Once your pics are on the memory card then put the phone into USB mode by selecting
Menu --> 9 Settings --> 7 Connection --> 2 USB Connection Mode --> 2 Mass Storage
Then attach a suitable USB cable to the phone at the charging jack and open Explorer (Windows) or Finder(Mac) and navigate to the phone. Your pictures will appear and you can copy them to your computer as needed.
NOTE: be sure to return the phone from Mass Storage mode to Data Service or your phone will not work.
Also - set your phone to highest resolution for best quality pics.
Menu --> 8 My Stuff --> 7 Camera and Recordings --> 1 Take Photo --> Options --> 4 Resolution --> 1 1600x1200
Mar 22, 2009 | LG Shine CU720 Cellular Phone
Alarm problems
When creating a new alarm, the LG Shine will start with the "Set Time" function where you can set a 15 minutes alarm jump (by moving the navigation button horizontally). If not desired, you can go one step down onscreen to set the alarm time manually. If you accidentally jump back to the 15 minutes jump method in the previous function, it will automatically postpone the alarmsetting with 15 minutes increments again. Please verify you don't use that function by accident while setting up the alarm time manually. If all of this is not the case, I would suggest to return the phone because there could be a problem with the phone or software.
Feb 06, 2009 | LG Shine KE970 Cellular Phone
How to save multiple ringtones to memory card on Lg Shine cu720
Same here - I have looked everywhere and it looks like no one is ever going to answer this - so anyway it looks like LG screwed us XD
Feb 04, 2009 | LG Shine CU720 Cellular Phone
Help me w/ my phone
I have the LG 970. my phone you can save all the song on you sd card. There is a section on my LG menu wich says "my stuff" If i click on it, then click on external memory, then click on sound. i can access any song recorded on my sd card and save it as a ringtone. try it, it might work on your phone.
Dec 23, 2008 | LG Shine KE970 Cellular Phone
Alarm won't go off/text messages won't send
the cheapest solution is to master reset the phone, but remember to back up the important stuff in it...maybe you have a small software glimpse, or something...if the master reset does not work...try resofting the phone (reinstalling the phone's operating system) allthough resofting the phone is a bit expensive.
Jul 23, 2008 | LG Shine KE970 Cellular Phone
LG Shine blank screen
Errm,,Try Plugging It In To the Computer And Trying To Find Them By Navigating It Through The Computer?
I Dont Realyy know But I Thoght Id Try :)
Good Luck.
Regards,
Sophiee.
Mar 08, 2008 | LG Shine KE970 Cellular Phone
Alarm clock, LG Shine phone
I just "personalised" the outdoor profile to set the message alert to silent, while still keeping the ring volume on high.
I also picked the divert call option so the phone doesn't ring.
So I just change the phone profile before I go to sleep and divert my calls.
Kind of an awkward solution..I'm considering getting an alarm clock or just using my old phone's alarm clock
Feb 19, 2008 | LG Shine KE970 Cellular Phone
LG Shine KE970 Cellular Phone Logo
67 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
