Question about Sony Playstation 3 (PS3) Console
When i turn it on all i see is a wavey line. no main menu
    Problem Solver:
  • 11 Answers
I had the same problem after loading the latest patch and I resolved the problem.
The ps3 would turn on and just sit at the wavy line.
I initially installed the latest patch directly on the ps3 through it's internet connection. To fix it I had to download it and copy it to a sd memory card (camera memory) and insert that into the sd memory slot on the ps3.
Follow this procedure for proper setup of the update file.
http://www.us.playstation.com/Support/Sy…
Here is what i did to fix it.
-hold down the power button for 2 separate beeps. It will turn on then off. Take finger off button.
-after it powers off (light red) press the power again and hold until you hear a single beep (or 2) then a double beep. After the double beep stop pressing the button. (it took me a couple of tries to get to this point.)
-This will bring you to a menu
-Select install update option
-insert the sd memory card or usb memory card/stick.
-the ps3 will find the update and reinstall.
-let the install finish and let it reboot on it's own.
This worked for me. Hope it works for you.
Posted on Nov 20, 2009
Testimonial: "thanks"
Jagged edges going off and on
Go if model here is correct to menu and engage Convergence and advanced to pull up a grid of lines---are they 3d in some areas when this happens?
Apr 06, 2012 | Mitsubishi WS-55513 55" Rear Projection...
Horizontal wavey lines in projection TV picture
what brand? could be a ground problem or bad crt
Aug 22, 2009 | Televison & Video
My ps3 wont turn on
Alright you need to put your ps3 in what is called "safe mode". First make sure there is no disc in the ps3, then turn off the ps3 in the back(main power switch), turn that switch back on, then hold the power button in front until you hear a total of 3 beeps, then let go, the light will be red, hold the power button again and you will hear 2 beep then a quick double beep, let go of power button and the light should stay green. A menu will appear, try all option working your way up from option 1 until it works. If you go through all 6 option and you are still having issues call 1-800-345-7669 to have your ps3 serviced
Aug 10, 2009 | Sony PlayStation 3 40GB System
Menu not showing
you probably over used or you might have had to much things going at once .so you may have blown a circuit.
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
Wavey lines in tv
sometimes wavey lines can come from your cable or satelite connections because the wrong size cable was used or there is just a bad connection in the cable somewhere..
Nov 15, 2008 | Proton MM2701VT 27" TV
My PS3 when switched on goes to the wavey lines (just before the menu screen) and then freezes? it also stops making a sound. i've switched off at the mains but the problem persists. any thoughts?
it looks like your system may be corrupt try hard resetting your system turn off the power in the back of the ps3. Turn it on while holding down the I/O utton until it beeps 3 times
Oct 20, 2008 | Video Game Consoles & Games
Wavey lines
Sounds like your set has dried caps in the Power Supply, take it to a decent tech, its not something you should try to do yourself as dangerous voltages can still be present evn if the set is unplugged.
Jul 25, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Lg 37 inch lcd has a dark shadow vertical line down left side of screen about 1cm wide and does not seem to go right to the top or bottom and is slightly wavey
reseat the LVDS cable inside the set. this is the multi wired connector that connects the main board to the panel. if that doesn;t solve your problem replace the main board. if you turn off the set and you can still see it in the screen it is the panel.
Feb 14, 2008 | Televison & Video
Wavey coloured horizontal lines and no sound
sounds like a bad eeprom.If thats not it start looking in the power supply.
Apr 11, 2006 | Toshiba 51H83 51" Rear Projection...
Sony Playstation 3 (PS3) Console Logo
46 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
