Question about ASUS PSCH-L Motherboard
Asus psch-l motherboard problem
Asus psch-l mother board restart while accessing cdrom
  • 2,351 Answers
Recheck data cable for wear & power cable for a possible short. If possible use another power connector within the system.
Posted on Jan 13, 2008
The system getting restart continiously
just try to boot without hardisk if a boot screen appears showing that the motherboard have no problem . and then buy a new ram and insert it . buy a correct ram
Apr 26, 2010 | ASUS P5GC-MX/1333 Motherboard
Mercury pi845g mother board restarts again and
The problem you are facing is generally caused by Defective rams please remove the rams clean the copper contacts by a soft cloth and then reseat them.
Feb 10, 2010 | ASUS P5LD2-VM Motherboard
Please identify RAM upgrade options for Asus PSCH-L motherboard. Thank you.
From the Asus spec site: Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB
Memory Memory Type dtrquestion.gif DDR SDRAM Number of Memory Slots 4 x 184 Pin DIMMs Supported RAM speeds 400 MHz • 333 MHz • 266 MHz Max Supported RAM dtrquestion.gif 4 GB DDR SDRAM 400; 333; 266mhz
4 GB max 4x1024 184pin
Hope this helps.
Aug 26, 2009 | ASUS PSCH-L Motherboard
My motherboard cannot detect cd and hard disk
you are facing this problem due to improper cabling or wrong jumper setting try to two different cable to connect HDD & CD. Go to bios & try to detect them. If not replace the faulty mother board.
Mar 30, 2009 | ASUS Computers & Internet
ASUS P5S800-VM mother board V Asus EN9500GT graphic card
you would need a new mother board or change the graphics card
Feb 11, 2009 | ASUS P5S800-VM Motherboard
Hardware Detection problem with ASUS K8VMX Mother Board
Firstly, Put a new battery on your motherboard(usually a cr2032).
Unplug everything except the ram and try to boot up.
Switch off and gradually attach one component at a time and reboot.
Remember to turn off every time you add a component.
This happens because your bios chip is getting mixed up because you are changing the configuration all the time.
Hope this helps
Jan 19, 2009 | ASUS K8V-MX Motherboard
Asus 845 chipset pb4 mother board not starting
it may be the circuit problem,inside the mother board.send it to service center
Jan 16, 2009 | ASUS Intel 845 Chipset P4B (P4B WOA)...
Why litium battery in mother board(intel,asus)?
The lithium battery is use to power up the RTC/CMOS chip which stores the date and time, and some essential configuration settings for your motherboard. If you notice that your computer clock is not displaying the proper date and/or time after you set it correctly, then you may have to change the battery.
Nov 25, 2008 | Intel Motherboard
Mother board problem
Fiend your solution direct from intel. Here is your solution........
Mar 20, 2008 | Intel D845GVSR Motherboard
hi jeeva,
to format ur hard disk simple way installed ur window xp/vista from installing the operating system it will be easier to format ur hard disk
1) just put bootable windowsin ur cdrom
2) run the set up
3) follow the procedures while installing from there u can format ur hard disk
Mar 10, 2008 | ASUS K8S-MX Motherboard
ASUS PSCH-L Motherboard Logo
53 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
