Question about GE Refrigerators
Ge side by side (psh25sgsa 3 yrs old) and the ice melts every few weeks in the freezer. Empty out the ice and everything is fine again for a couple of weeks. Checked the coil underneath and everything is fine. The fan in the freezer is a little noiser than usual. Something tells me it's related to the main control board. I heard that GE had a recall for defective control boards, but cannot find anything on GE's website. Replaced thermistor #4 and #5 but problem continues.
  • gdoliver Nov 20, 2009
    PSH25SGSA SV is the model #. The serial # is FH 408241
    The ice melts in the ice tray at the top of the freezer, but there's a few ice cubes at the bottom of the freezer that are not affected. The digital temp reading says the temp in the freezer is 6 degrees. Very frustrating problem to say the least.
  • 10,865 Answers
Hello. It appears that you may indeed have a defective control board, or it could be your defrost thermometer, Read on please. As you know, the self-defrost system has three functional components: 1. Defrost timer The timer is like a clock. It continually advances, 24 hours a day. Every 6 to 8 hours, the timer turns off the cooling system of the refrigerator and turns on the defrost heater. 2. Defrost heater The defrost heater is similar to the burners on an electric stove. It's located just beneath the cooling coils, which are concealed behind a panel in the freezer compartment. The heater gets hot. And, because it's close to the cooling coils, any ice or frost build-up melts. As the frost and ice melt, the resulting water drips into a trough. The trough is connected to a tube that drains the water into a shallow pan at the bottom of the refrigerator. The water is then evaporated by a fan that blows warm air from the compressor motor over the pan and out the front of the refrigerator. 3. Defrost thermostat The process ends after either the amount of time specified on the timer or when the defrost thermostat near the cooling coils senses that the heat near the coils has reached a specific temperature.
Posted on Nov 20, 2009
  • 15,935 Answers
What is the full model # please??
2 Suggested Answers
aasc
  • 1606 Answers
SOURCE: ge side by side (psh25sgsa 3 yrs old) and the ice
Yes , your main control board is on the recall list , however , that is not the problem . The problem , is the #4 and/or # 5 thermistor . The #4 , tells the control board , the temp of the coils , when to defrost , and when to stop defrosting . The # 5 , tells the control board , the freezer temp . Both thermistors work together , relaying information to the board , to act on . The # 4 , is behind the inside rear freezer panel , clipped on the top , left side of the coils , with 2 white wires going to it . The # 5 , is located behind the bottom freezer crisper , slid inside a small housing , also with 2 white wires going to it . The part number for each thermistor is WR55X10025 . I would replace both thermistors .
Posted on Oct 31, 2009
Frost in freezer, fan in freezer sometimes changes speeds, low pitch or humming noise,manualy defrosted it 1 month ago seemed to be fine for two weeks, vegies freeze in drawer. hotpoint hss25gfta 5 yrs old
If the defrost thermostat is bad it will need to be replaced, otherwise you will have to continuously manually defrost the unit. The noise you hear is probably the fan hitting the ice. The defrost thermostat assists in melting that ice about every eight hours.
May 15, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
I have a GE side by side refrigerator, with an icemaker in the door. The refig is slightly less than 6 years old. I have been out of town for a few days, but today opened the door to get something out...
Seriously? Mine just did the same thing today. The electric on the inside is fine. No cooling. there is a code blinking HRS on the inside. the ice and water were working intermittently the past couple of weeks. wtf?
I found a post describing the exact thing I have going on but it was from 3 years ago.
Feb 10, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Our refrigerator is 2 years old a few months ago the back wall of the freezer was covered in ice and everything had melted. i took everything out melted the ice off the wall of the freezer and it started...
your defrost heater behind this wall isnt working to defrost the unit,a block of ice cant pass cold air,its either the heating element or the defrost thermostat or the main board in the rear area of the unit
Sep 13, 2010 | GE Refrigerators
I have a 3 yr old ge Profile side by side refridgerator model #psc23sgrdss with the following problem. on 3 occasions in the last 3 wks I've found the temp. in the refrig section very high ( 56 degrees and...
I had same issue this past week. Refrigerator up to 45 freezer up to 15. Ice would melt and then everything would get cold again. Ice formed on everything. Next thing you know it was warming up again. I knew the rubber seal on door flap that opens to let ice out warped during summer months because I keep it 78 in summer. Had that replaced today. Temperatures have gone back to normal and stayed ALL DAY (knock on wood). Check door flap seal sticking your hand up making sure you don't push in the water tab. You should be able to feel if it is warped/wavy like an old LP or not. Good Luck.
May 20, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator seems to just turn off for a day or so every two or three weeks and all the freezer items melt. Kicks back on after some time and works fine for another 2-3 weeks then repeats. Have unplugged...
Most Refrigerators have a defrost timer which cycles every couple of weeks, typically for several hours, in order to let any residual ice melt from the cooling system. If yours cycles long enough for the freezer items to melt, it should be replaced.
Nov 02, 2009 | GE Adora (DSF25KGTBG) Side by Side...
Ge side by side (psh25sgsa 3 yrs old) and the ice melts every few weeks in the freezer. Empty out the ice and everything is fine again for a couple of weeks. Checked the coil underneath and everything is...
Oct 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Side by side- lines from custom cool covered with ice
I can't give you a solution but I can tell you that we have exactly the same situation. The freezer seems to work but we come back and water has dripped from the ice holder and formed a classic stalagtite (or is it a stalagmite?) Obviously something has melted. We have also found items in the freezer melted - yet the digital readout said it was 3 degrees! Arghhhhh. Glenn in Delaware
Apr 19, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Side by Side (3 yrs Old): Freezer iced up, refrig not cooling
Most GE defrost problems are bad defrost thermostat and defrost heater.
It requies removing the back wall panel on the inside of the freezer to access the parts.
Mar 17, 2009 | GE GSL22JFPBS Side by Side Refrigerator
GE side by side - upper freezer warming once a week then freezing
Had the same problem. Bottom of freezer was about the right temp but the upper part was way too warm. Fridge side was fine. Ice maker stopped making ice - it wasn't broken, but it won't run through its cycle if the temp is too high. Cubes already in storage hopper melted and water refroze as it ran to lower, colder part of fridge. Problem: Fan controller for freezer compartment was faulty. The fan itself was fine. Fix: GE replaced the main circuit board that controls everything on this model, including the freezer compartment fan. Once that was done, temp returned to normal, ice maker is happy again. The board had undergone several revisions from the factory installed one (could tell this by comparing the part number on the old and new boards - they increment it when they revise it.) Bad news: the part/labor were expensive and of course failed after the warranty ran out. Good news: the board is now guaranteed for 5 yrs. (Why wouldn't the factory-installed board ALSO be good for five years instead of just one? It's not like the replacement boards are made better.) Labor is covered only for 90 days though so it won't be free if they have to come back after that.
Mar 03, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
61 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
