Question about Grilling
I need a new regulator with a low med high knob for two burner dyna glo tank top heater propane if tou have how much if not where can I get one thank you
    Problem Solver:
  • 7 Answers
If you don't have an authorized dealer to get a replacement regulator, contact GHP Group Inc, (877) 447-4768. MAKE SURE YOU HAVE THE PROPER HEATER MODEL NUMBER. Replacement Part Number: S2TT0001B for the RMC-TT30DGP.
Here's a link to the manual for eight of their tank-top heaters
Replacement cost including shipping is a couple bits over $21.
When talking to the technician on the phone, he cautioned me against rapidly opening the tank valve, which hammers the regulator (the replacement one is more robust than the original), kinda' like how water-hammer can cause damage to water pipes and/or water appliances. Open the tank valve gently, don't just whip it open (like I used to), your regulator will last a lot longer that way.
Because of the press-fit and pins used in the regulator construction & assembly, self-repair is not possible or recommended since the regulator may not seal correctly afterwards.
Posted on Jan 12, 2011
I have a dyna glo RMC 40 NGT vent less wall heater that I would like to convert to propane, I need to know which conversion kit to buy, and where. Thank you.
dyna glo natural gas heater Questions & Answers - Fixya
www.fixya.com > Forum > Tags
dyna glo ventless rmc50 ngt can this heater be changed from natural gas to propaneuse, ... Dyna Glo Natural Gas conversion to LP Gas I have a Dyna-Glo natural gas space ... Question about D-E36 Infra-Red Wall Mounted Panel Heater ... dyna glo heater model #RMC-40GT I believe on your particular model , that you ...
Parts for Dyna Glo, Thermoheat and Dyna Glo Pro Heaters
spaceheaterparts.com/category.sc?categoryId=13
Shop Dyna Glo, Thermoheat, Dura Heat, Workhorse LP and oil fired htrs ... Circuit Board 2201181 Dyna Glo & Thermoheat 150k Nat Gas Htr RMC-FA150NGDGD ... This spark plug (ignitor) is used on Dyna Glo and Thermoheat 40K btu LP.
Propane Wall Heaters - Walmart.com
www.walmart.com > ... > Heaters
WalmartDyna-Glo IR18NMDG-1 18,000 BTU Natural Gas - Infrared Vent Free Wall Heater. $170. ... Dyna-Glo 40K Liquid Propane 360-Degree Tank Top Heater. $88.00 ... Dyna-Glo Deluxe RMC-FA125DGD Portable Gas Powered Forced Air Heater.
1352062 Dyna Glo Natural Gas conversion to LP Gas
162.220.53.34/F/.../t1352062-dyna_glo_natural_gas_conversion_lp_gas
Jan 12, 2016 | Heating & Cooling
Where can I buy a regulator for 2 burner tank top heater
Our "old fashioned" local hardware store carries a line of several regulators. So, you might try all of your local hardware and/or building supply stores.
Jan 09, 2015 | Dyna Glo 18,000 - 30,000-BTU Liquid...
Need a control knob for: dyna-glo pro propane heater. model: # rmc-tt30dgp-01, # rmc-tt30dg, # rmc-tt30gd. this is the off/low/med/hi temp. control knob.
I AM TRYING TO FIND A PROPANE REGULATOR FOR A DYNA-GLO PRO. THE MODEL # IS RMC-TT30DGP. THERE IS A NUMBER ON THE OLD REGULATOR. THAT # IS S2NTT0002-2.THANK YOU.
Dec 17, 2010 | Heating & Cooling
Dyna glo tag along propane heater pilot stays on but when turning
sounds like either a bad thermocouple or more likely a pressure regulator problem. should have unit checked by someone familiar with propane systems.
Jan 13, 2010 | Dyna-Glo (PPH16-LP) Utility Heater
Dyna-glo rmc tt30dgp wont turn on
Your regulator has failed, just like mine did. Contact GHP Group Inc, (877) 447-4768 to order a replacement regulator - MAKE SURE YOU HAVE THE PROPER HEATER MODEL NUMBER. Replacement Part Number: S2TT0001B for the RMC-TT30DGP.
Feb 28, 2009 | Dyna-Glo RMC-8001SS Heater
Broken adjuster for propane heater
Broken adjuster for two burner attachment. Cant find a replacement.contact budmtzgr@sonic.net
Jan 30, 2009 | Dyna-Glo Double Tag-a-long Heater
Could not get more then 72hours using 20lb tank on low
HI. propane has 91000 btu's per gallon. 20# bottle has 4. divide btu's of heater by #of gallons for hours of use. I have the same heater and I think the med. setting both burners on is more the 7000 btu's.
Mike
Nov 25, 2008 | Dyna-Glo Double Tag-a-long Heater
Shuts off when switched to low and smells when running.
clean the burner and the orifice you can use a air line or blow off a vacum cleaner
Nov 20, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Grilling Logo
248 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
