Question about Panasonic CT-32HXC14 32" TV
Main power button and remote will not turn on tv. It is plugged in and has 110. Worked last night but would not come on today.
    President:
  • 1,284 Answers
The most common failure for these sets to go totally dead is the degaussing thermistor shorts out thus causing the A.C. fuse to open. The part number for the thermistor is D4DDF1R50001 and the fuse is part number XBA2A00101F... You can do a Google search for these parts. One you get the parts and look at the board where the A.C. cord connects to, the fuse and thermistor are not too far from that point. Its an easy fix if you have any soldering skills. Please take a few moments to rate my answer. Thanks...
Posted on Nov 20, 2009
  • 156 Answers
If you left it plugged to the wall then an overnight tension peak may have burned the TV internal fuse. If you have electronics knowledge, unscrew the back of the TV and replace inner fuse. If you don´t have electronics or electricity knowledge, don't attempt to do so, you may end doing more damage than good. Take it to an electronics repair store. Sorry for may very poor english, I'm Argentinian.
E500i-B1 won't come on.
Suspect a failing power supply
Jan 13, 2017 | Televison & Video
Last night about 3 am I turned off my tv. when I usewd my remote to turn it back on it would not ( t v) come on and no picture or sound . I turned it around to see the back of it but it has no reset
Your TV have faults on Horizontal deflections, the oscillator and the Flyback might be the problems. If you are not familiar with TV circuits?... call tecnician to check your set.
Oct 03, 2014 | Televison & Video
My Panasonic CT-27SC14 tv won't turn on. worked fine last night. The cable box does but nothing happens with the tv..whether I use the remote or the power button. Unplugged it from the power source and...
hi,disconated from AC main. if you know bit of repairing tv and soldering? this what to look for main power board. 1 x dry joints 2 x leaky capacitors just remember when changing cap's make sure to use the 105' and same value.
Feb 04, 2010 | Panasonic CT-27SC14 27" TV
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
My tenplus year old Toshiba 32" TV is stuck in standby mode
You have an old tv so the best problems are bad capacitors and bad grounds. Have someone pull the board and search for high voltage caps [160volts or 250 volts] with 1 to 4.7 microfarads. Should be two or maybe three and check all grounds. If the 4 amp fuse is good than the above will save your TV.
Sep 24, 2009 | Toshiba 32A33 32" TV
Hi, i have 2 televisions different makes both turn on to standby but wont turn on fully, the bush tv when i push programme button to turn on the red standby button flashes but nothing else.
I have the same problem, my Bush LCD worked fine last night but won't turn on today. The main power button on the TV puts it onto standby but the remote or the buttons on the side won't turn it on!....HELP!
Sep 06, 2009 | Televison & Video
Tv won't turn on
Was the power button from the main outlet(wall) kept in the ON (position)throughout the knight! i.e. switched off by the remote only? In that case a power surge druing the night could have fried some part of the TV circuit. In such case there are many fuses inside the TV which need to be checked out If the main tubes are gone kaput then better to replace the entire set......................sodeep
Sep 03, 2009 | Panasonic CT-32HXC14 32" TV
Television won't turn on.
Hello
The same problem i am also facing bin last weak what i will suggest you that neverturn off ur TV by remote switch off directly from the scree from next time it will be helpful for you from next time...
Thanks & Regards
May 24, 2009 | Televison & Video
Tv wont power up ?
TV turned off and will not turn back on.
Sep 27, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Panasonic CT-32HXC14 32" TV Logo
812 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
