Question about Gateway GT5220 PC Desktop
I have a gateway computer my speaker are not working no audio I've checked the drivers they are ok and the connections are good ,when I checked the control panel ( audio devices) I noticed It said no audio device please any advise ?thanks Al
    Problem Solver:
  • 21 Answers
On your keyboard if there is a button or two for volume check to see if the volume is on from there. you can also check the volume from your desktop just go to your taskbar.
Posted on Nov 20, 2009
NO SOUND FROM MY COMPUTER
Check the Mute button make sure it is not selected, also check the volume level,move the volume setting higher or to max.
Check the audio chip is OK by plugging headphones into the audio out/headphone socket.
If it is OK then most likely the speakers are faulty and they need to be replaced.
Mar 15, 2013 | Computers & Internet
I have Boston Acoustics BA7500G surround speakers that will not work with Win7 64bit. I have used them since owning a Gateway PC (Win XP) with a Soundblaster card. I've used them through three...
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
http://download.cnet.com/%7Bvalue=http://www.download.com/realtek-high-definition-audio/3000-2120_4-75317047.html
Realtek HD audio driver package. The package includes: driver setup program, drivers for Windows Vista / 7 64-bit
hope this helps
Jun 11, 2011 | Boston Acoustics BA7500 Computer Speakers
Just received a new Asus VE247H led monitor. Can't seem to get audio to work properly through onboard monitor speakers. Is there a driver out there that needs to be installed? (PC is Gateway GM5420)
The monitor will have a connection for audio.
The audio comes from your computer.
Must connect cable from your computer speaker out connection to your monitor.
Apr 02, 2011 | Computers & Internet
We recently had to have our gateway computer set back to factory settings and now our GMAX 2100 Computer Speakers won't work. I have everything plugged in correctly (I think!) but they won't work. I have...
control panel sounds and audio,audio make necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
good luck
Sep 10, 2010 | Gateway GMAX 2100 Computer Speakers
My computer lost sound. Audio driver ok. Speaker ok. volume controls ok. Motherboard: Lenovo, Columbus. Pls. help me! darabugan@yahoo.com thanks.
check for the Audio Output port for any damage. Make sure the speakers are connected to the Green Output port. Reinstall the Audio drivers if neccessary.Try good known speakers if you have one.
Nov 13, 2009 | Computers & Internet
How to use BA7500G on another computer
I have the same problem except i'm using a macbook and i'm trying to connect the speakers. My macbok accommodates optical digital audio output, but you have to buy a  a standard toslink cable with a toslink mini-plug adapter.  Since the speaker input is a digital coaxial (not fiber, optical) you have to buy a Digital Fiber Optical (Toslink) to Digital Coaxial (S/PDIF) Converter.  i haven't tried it, but i hope this solves our problem. i have the toslink now i just have to buy the converter. good luck to you.
Jan 29, 2009 | Boston Acoustics BA7500 Computer Speakers
Speaker problems
First, make sure the speakers are plugged into the center green connector.
Second, go to Gateway's website and download the latest audio drivers for your system and reinstall them. That should do it.
Dec 22, 2008 | Gateway (G-MAX2000) Computer Speakers
My speakers on my Dell computer quit working.
1) check audio driver is installed in system or not it may have some one remove audio driver.
2)If driver installed check volume is not mute.
3)If all thing is ok check speaker in another system by connecting it.
4) If spk is working in another system. it means sound card of that system is faulty.
Dec 01, 2007 | Audio Players & Recorders
Speakers work...just not when plugged into desktop
This is a duplicate post, click the following like to view the active posting: http://www.fixya.com/support/t129710-speakers_work_just_not_when_plugged
Jan 08, 2007 | Gateway GMAX 2100 Computer Speakers
Gateway GT5220 PC Desktop Logo
62 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
