Question about GE Profile PSC25MSWSS Stainless Steel Side by Side Refrigerator
How do i set the freezer temp on my GE Profile side by side? The temp keeps warming and everything is melting.
icansurf
  • 72 Answers
SOURCE: Freezer set at 0 degrees, but runs at 19 degrees. Ice Cream melting...
Low on freon/refrigerant maybe.
Posted on Mar 03, 2007
  • 3422 Answers
SOURCE: GE Profile- Freezer/ Fridge at 56 wont go cooler!
HI,
All i can say is you will require a tech to get this fixed.
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing,
check vents in refrig. make sure no blockage, controls should be in the middle setting,
check make sure compressor is running.For this you will require a tech..
Goodluck.
Posted on May 03, 2008
  • 531 Answers
SOURCE: 16 month old GE Profile
see if the back wall inside of freezer have ice if so you have to change tiker board or check your doors if closing
Posted on Mar 31, 2009
  • 146 Answers
SOURCE: Fridge and Freezer won't cool.
The evap fan is running - but is your compressor motor running -t his is what i'm concerned about - 82F ? That is very high - this suggests to me there is no cooling AT ALL - only the fans are working - and my gut tells me your compressor is not running AT ALL - I would rule out thermostat since when it kicks in and your evap fans turn on, your compressor should turn on too. If this fridge has electronic controls, have your motherboard / control boards checked, have your compressor checked. If your compressor is running and you can hear its distinctive humming sound, then you have a sealed system problem, a major one :) Have those two things checked.
Posted on Aug 22, 2009
Testimonial: "You are right..it was the motherboard. The fan I heard was NOT the compresser, it was the evap fan. It took the repairman 5 minutes to change. Thanks!"
aasc
  • 1606 Answers
SOURCE: GE PROFILE SIDE BY SIDE MOD PSS25MGN - NOT COLD - FOOD THAWING!
Sounds like a main control board defective .The one on your refrig WR55X10552 , is on a recall list .
http://www.scribd.com/doc/13371507/Ge-Motherboard-Concession-Letter
The new part number is WR55X10656 . I would suggest calling GE , to have them come out and check , as this part and labor , should be covered , as stated by the letter .
Posted on Nov 08, 2009
Ge profile artica model PSC23SGPA Side by Side not keeping temp - lost everything in freezer and now frig is heating up. Can change temp to 0 but within a few seconds reads 24 (temp set does not hold)
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 01, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
GE PROFILE REFRIGERATOR-PSC25MSTA NOT WORKING
check to see if the fan by the compressor is working when the compressor is running if not you have the problem control board .....replace board
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Mar 17, 2009 | GE PSS25MGN Side by Side Refrigerator
Water was frozen all inside the freezer and fridge temp was high
Self defrost mechanism may have an issue. If it stays on too long you will have excessive temps build up in refrig as well as freezer. There is also a defrost thermostat that is supposed to turn compressor back on when temps get too high - check that out also.
Apr 14, 2017 | GE Profile PSW26P Stainless Steel Side by...
Does not stop cooling down
Door edges being warm is caused by what is called mullion heaters that operate to prevent humidity from condensing at these points.
Some refrigerators have an energy saver switch. Turn this switch if you have one to the energy saving position when the humidity is low. Is anything freezing in the refrigerator? If so setting the controls to a little higher setting may solve your problem.
May 03, 2008 | GE Profile¿ Arctica® Energy...
check freezer for frost build up and if fan is blowing, check condenser, make sure its clean, and fan blowing, check vents in refrig. make sure no blockage, controls should be in the middle setting, check make sure compressor is running
Aug 25, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE Profile  PSC25MSWSS Stainless Steel Side by Side Refrigerator Logo
257 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
