Question about Garden
Ihave an Arien's snow Blower Serial # 008024 and Model# 922020 which will not create a spark at the plug when trying to start. Can you please explain the problem and also explain the wiring as i am not sure if that is correct. There are certain wires that are not connected. i have tried to fix what I thought was the problem which was the gap between the magnet and the rotor, but was unable to access the fault as I felt that I needed to have a puller to remove the drive cog, is this correct. Can you please advise. Thanks, Derek
  • dontbother10
    dontbother10 May 11, 2010
    Hello, we are having a problem with self rating by our experts. If you did not rate this or do not believe it warrants a rating of very helpful please rate it as NOT HELPFUL. Experts cannot override your rating and seems to be the only way to stop this practice.
bryant329
  • 125 Answers
SOURCE: 2000 GMC Sierra 4.3L no spark at the plugs...HELP!
no codes. most direct components changed.
computer. take it out or have the truck towed to the shop/dealer to test the computer.
Posted on Sep 25, 2008
  • 12 Answers
SOURCE: Mantis 2-stroke tiller won't start
This could be one of several problems...
• Last year's fuel. Get some fresh gas.
• Every 2-stroke needs a new spark plug each year... you know what that means.
• Clogged carb jets due to storing the tiller over the winter with fuel in the system. Never, ever do that. Now you'll need to pull the carb apart and clean it. Most of the orifices are so tiny you can't see them. Good luck.
• Engine is so old the crankshaft seals have hardened with age. This is one reason no 2-stroke lasts longer than about 8 years. If the seals are shot, then it will cost more to fix than a new one costs. Time to toss it.
Posted on Mar 21, 2009
  • 65 Answers
SOURCE: 626 won't start no spark
Distributor fault, the coil goes down in tyhem and sometimes pops the ECU.
Posted on Mar 23, 2009
SOURCE: need to know the spark plug gap for ryobi model
Ryobi RY60511A
Champion plug RCJ6Y - gap is .22
I have original manual.
Posted on Apr 22, 2009
SOURCE: trouble starting old Mantis tiller 9012 - don't have a manuel -
Mantis has the owners manuals in pdf format available for download on its website. The tillers are here (I hope the link to the tiller group works...if not, just go to the main site and look for "owners manuals" link.
Also, you can call a number and get a representative who usually can help at the numbers listed there, find authorized service people if its not something you can do yourself, order parts and find detailed schematics in the owners manuals. My dog actually ate mine. LOL. But they are free, the owners manuals, unlike other places that charge you for them like they were a "part".
http://mantis.com/owners_manual_library-swell2_tiller_engine.asp?cat=8
Posted on May 18, 2009
I have an arien 8524 snow blower. Is there an air filter on this snow blower as my snow blower will not stay running it only starts and runs for about 20 seconds
Most snow blowers do not have air filters. They tend to clog on these units. Sounds like your issues are fuel related. You may try to flush the system with a product called "Start" from Wal-Mart. You will need to follow the instructions on the bottle and try to keep the unit running long enough to run this cleaner through the system.
Feb 13, 2017 | Garden
I have an ARIEN snowblower Model 921031 24". It will not start. Please help me remedy this. Thank You ....Eddie
If there is adjusting screw on the carb open it up a part of a turn and see what happens I had to do that to my Craftsman Blower. Open is left If that does not work
Take the spark plug out and shoot a little bit of gas into the plug hole then put the plug back in. Try to start it. If it starts and stalls then try two or three times. Make sure you have fresh gas as well.
Dec 20, 2016 | Garden
My troy built squall 210 snow blower will not start
was the gas in there from last season? If it was... you better drop the bowl on the carburetor and clean the mess that the Ethanol Gas created. Ethanol Gas the Carb Kil ler
Nov 25, 2014 | Garden
How fo i keep my toro snow blower from bogging down?
Dry the spark plug it might probably wet
Feb 09, 2014 | Garden
What is the right spark plug number for a JACOBSEN HomeLite 320E snow blower, model number UT35012A and seties SH3030001. Please help.
I recommend that you contact your nearest authorized service center, or contact Homelite directly for assistance.
I trust this information proves useful.
Sep 15, 2010 | Agri-Fab Agri - Fab Snow Blower - 42"
I cant find the correct spark plug and dont have
go to a farm store near you take the old plug with you and match it up the size with a new one even you don't find the same number look for the one that is the same size.if you still have problems go to contact on Tecumseh.com
Oct 17, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Troy Built Snow blower won't start.
Cleaned out caruretor and blew out presumed dirt via compressed air. Thanks for your support.
Jun 20, 2009 | Agri-Fab Agri - Fab Snow Blower - 42"
Mtd snow blower no start
HI
Check the ignition.Check the compression(remove the spark plug and ground the plug wire on the engine,seal off the plug hole with your thumb,operate the starter,if thecompression preasure blows your thumb off the hole the compression is adequate for the engine to run.Be careful not to touch the plug wire as this is done.Try to start the engine and see what is happening.Please let me know!
regards savumihai71
Dec 05, 2008 | Garden
Garden Logo
74 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
