Question about HP PSC 2175 All-In-One InkJet Printer
I used to be able to check the print cartridges ink levels through the "maintenance" tab and now there is no way to access that information. Can I get that feature back? I'm running Windows 7. Thanks
    Brigadier General:
  • 4,090 Answers
You need to get an updated driver from HP that is designed for Win 7.
Please rate my help++++Thanks for using FIXYA
Posted on Nov 20, 2009
How can i tell the ink levels in the cartridges
You are either low on ink or the yellow cartridge is blocked. If you have a plug in the cartridge, doing a print head cleaning may help. On my inkjet printer, there are two levels of print head cleaning available.
Which brand/model printer do you have? Accessing the print cartridge level depends on the model and usually the software that you have installed. However, the software-provided level is an estimated level and may not accurately reflect the actual ink level in each cartridge. This is only available if you install the full-featured software from the manufacturer.
Generally, to see the estimated levels, if you have the full software installed, open the printer Toolbox. Then find a tab related to Maintenance and then get the estimated ink levels. For my HP printer, there is a specific tab just for the ink levels. (If you use Windows, there may be a icon for the printer in the notification area (on the right with the date/time information) that will let you open the software. Right click on the icon to access specific parts of the program.)
My printer has an option to print a quality test page in the Maintenance section which gives a better look at the ink levels. (For my HP inkjet, this is under the Device Services tab. Print head cleaning is also accessed here.)
Some printers with an LCD panel will let you access these maintenance items directly from the printer.
Please add a comment with your printer for additional information.
I hope this helps.
Dec 27, 2011 | Office Equipment & Supplies
Printer has stopped printing blue
Make sure that you are inserting only genuine Lexmark cartridges in your printer. Removing then re-inserting the color cartridge into the printer is a quick to minor cartridge communication issues.
Make sure that your color cartridge still has substantial ink level for printing using the Lexmark Solution Center software on your computer.
Click Start > Programs > Lexmark X74-X75 > Lexmark X74-X75 Solution Center. Check the ink levels.
If color ink level is still good, then it probably just needs some cleaning. Print quality issues can be due to dirty or clogged print cartridge nozzles. From the Maintenance tab in the Lexmark X74-X75 Solution Center, click Clean print nozzles to fix horizontal streaks. Your printer will then print a test page. Try to print a color page again to verify that the problem with the blue color is fixed.
If the problem continues, try to insert a different known working color cartridge to identify if it's a faulty cartridge issue.
Oct 26, 2011 | Lexmark X75 All-In-One InkJet Printer
Hi. I cannot find where to check the ink level in my deskjet 3500. Can you help me? - thanks.
When you installed the printer from the HP-supplied CD-ROM, you installed the HP Printing Assistant. Use its "maintenance" tab to check ink-cartridge levels.
Or, open Control Panel, and open Printers, and right-mouse-click the printer, and choose Properties, and you should be able to use a utility program to check the levels.
Jun 26, 2011 | HP DeskJet 3550 InkJet Printer
Paper comes out blank
Please check your ink levels:
1. Click Start > Programs or All Programs > Lexmark 2400 Series 2. Select All-In-One Center 3. Click Maintain/Troubleshoot. 4. Select Device status and ink levels.
If all ink levels are still good, proceed to cleaning the cartridge nozzles.
1. Click Start > Programs or All Programs > Lexmark 2400 Series 2. Select Solution Center. 3. Click Maintenance tab. 4. Select Click to fix horizontal streaks.
Your printer will begin to print, forcing ink through the cartridge nozzles and clean them. Try to print your file again.
Jun 17, 2011 | Lexmark X2470 All-In-One InkJet Printer
My printer won't print in color
Check your color ink levels, the cartridge may need changing.
If they are fine check in the printer settings that you have both color and black cartridges are selected to print from.
Enter control panel, click on Printers (may differ for you), right click your HP D4360 and select properties, you will see a maintenance tab, select the tab and search for Ink Cartridge Settings. In there you can choose what cartridges to print from.
The names of the tabs may differ slightly as its not the exact model I have previously worked with.
Jan 09, 2011 | HP D4360 DeskJet Printer InkJet
When we do a fax test, we get clear print; when we try to print documents nothing appears, altho it goes thru all the right sound motions
Sounds like your colour cartridge is empty. Fax test will pull from black only but documents sometimes use a combination of colours in order to print out black. I suggest checking your ink levels - instructions for windows;
Check ink levels
NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
  1. Open the Printer Toolbox . There are two ways to do this:
    • Open HP Director , select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • Open Printers and Faxes in the Windows Control Panel , then right-click your printer icon and choose Properties . Click Printing Preferences . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low Check ink levels
Mar 05, 2010 | HP Officejet 5610 All-In-One InkJet...
How do I check ink levels on my HP deskjet D4160 printer?
Here is what I found on the Web. You can click on the link below, to see Full Instructions. If you find this helpful, pls rate me.
http://h10032.www1.hp.com/ctg/Manual/c00687555.pdf
View estimated ink levels
Follow these instructions to view the estimated ink levels of the print cartridges that are installed in the printer:
1. Open the printer Toolbox.
2. Click the Estimated Ink Level tab.
Note If the print cartridges were used before being installed in the printer, the
estimated ink levels will not appear on the Estimated Ink Level tab.
The Estimated Ink Level tab also contains print cartridge ordering information. To view
this information, click the Print Cartridge Information button.
Thanks and good luck.......
Pls rate me
Jan 01, 2010 | HP Deskjet D4160 InkJet Photo Printer
How do you check ink levels
Introduction This describes how to check the estimated ink level in the cartridge. NOTE: Ink level warnings and indicators provide estimates for planning purposes only. When an indicator shows low ink levels, keep a replacement ink cartridge available to avoid possible printing delays. Ink cartridges do not need to be replaced until print quality becomes unacceptable. Checking ink levels Perform the following steps to check the estimated ink levels: NOTE: If you have installed a refilled or remanufactured print cartridge, or a cartridge that has been used in another printer, the ink level indicator will be inaccurate or unavailable.
    • Click Start and select HP Solution Center . Select the Settings menu, then the Print Settings submenu, and finally the Printer Toolbox .
    • In your printing application, click File , click Print , and click Properties . Click the Services tab, then the Service This Device icon.
  2. The Printer Toolbox opens. Click the Estimated Ink Level tab. A cartridge may be running out of ink even if the graphic shows ink remaining (see the note at the start of this section). Lines or streaks always appear in printouts when the cartridges begin to run out of ink. Replace print cartridges that are out of ink or low on ink. Figure 1: Estimated ink levels
Nov 23, 2008 | Office Equipment & Supplies
White horizontal streaks in documents
I Am Experiencing Poor Print Quality With My Dell™ Printer
Table of Contents
Verify the Printer Ink Levels Using the Dell Printer Solution Center
Clean the printer contacts and print a test page
Clean the Printer Nozzles Using the Dell Printer Solution Center
Dell™ Printer Additional Information
» Verify the Printer Ink Levels Using the Dell Printer Solution Center
Poor print quality of a document or picture may be the result of low ink levels or dirty printer nozzles or contacts.
To check the printer's ink levels, perform the following steps:
1.
Click the Start button, point to All Programs, point to Dell Printers, and then point to Dell (printer model).
2.
Click Dell Printer Solution Center.
3.
Locate the printer's ink levels on the lower right corner of the Dell Printer Solution Center window.
4.
If the printer's ink levels indicate that ink cartridges are empty, click the Order Ink button to place an online order for replacement ink cartridges.
For information about ordering ink for your Dell printer, refer to article: Obtaining Ink for a Dell™ Printer
Back to Top
» Clean the printer contacts and print a test page
To manually clean the printer nozzles and contacts, perform the following steps:
1.
Turn the printer off and remove the power cord from the back of the printer.
2.
Open the printer lid.
3.
Manually move the ink-cartridge carrier to the left by gripping the top of the rubber carrier belt and gently pulling it across towards the right hand side of the printer.
4.
Take a warm, semi-damp paper towel and gently clean the wiper on the right side of the maintenance station.
5.
Lift up on the cap(s) that cover the ink cartridge(s).
6.
Remove the ink cartridge(s), and using a new warm, semi-damp paper towel, gently clean the contacts on the ink cartridge(s).
Verify that the contacts on the ink cartridge(s) is/are sufficiently dry prior to re-inserting into the printer.
7.
Re-insert the ink cartridge(s) back into the correct printer slot(s).
7.
Close the printer lid.
8.
Re-attach the printer power cord to the back of the printer unit.
9.
Press the Power button to turn the unit back on.
10.
11.
12.
Click the Maintenance tab.
13.
Click the Print a test page icon.
A test page prints.
Back to Top
» Clean the Printer Nozzles Using the Dell Printer Solution Center
To clean the printer nozzles and contacts using the Dell Printer Solution Center:
1.
2.
3.
4.
Click the Clean to fix horizontal streaks icon.
5.
Click the Print button.
Note:
The printer will make sounds when cleaning the nozzles that are not commonly heard during normal usage
Mar 19, 2008 | Dell 962 Photo All-In-One InkJet Printer
Ink
Normally when you install the print software you install HP Director or solution centre software that has a estimated ink staus monitor..from user manual
Check the estimated ink levels You can easily check the ink supply level to determine how soon you might need to replace a print cartridge. The ink supply level shows an estimate of the amount of ink remaining in the print cartridges. Tip You can also print a self-test report to see if your print cartridges might need to be replaced. For more information, see Print a self-test report. To check the ink levels from the HP Director (Windows) 1. In the HP Director (or HP Solution Center), click Settings, point to Print Settings, and then click Printer Toolbox. Note You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Services tab, and then click Service this device. 2. Click the Estimated Ink Level tab. The estimated ink levels for the print cartridges appear. To check the ink levels from the HP Image Zone software (Mac) 1. In the HP Director (OS 9) or HP Image Zone (OS X), choose Settings, and then choose Maintain Printer. 2. If the Select Printer dialog box appears, select your HP All-in-One, and then click Utilities. 3. From the pop-up menu, choose Ink Level. The estimated ink levels for the print cartridges appear.
Print a self-test report If you are experiencing problems with printing, print a self-test report before you replace the print cartridges. This report provides useful information on several aspects of your device, including your print cartridges.
Load letter, A4, or legal unused plain white paper into the paper tray.
Press and hold the Cancel / Resume button and then press the Start Copy Color button
The HP All-in-One prints a self-test report, which might indicate the source of the printing problem.
Jan 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
HP PSC 2175 All-In-One InkJet Printer Logo
158 people viewed this question
Seeker5211
Seeker5211
