Question about Toshiba Satellite A135-S4427 Notebook
Laptop is shutting down suddenly, it is plugged in via an ac adapter. The computer will not restart when the power button is pressed. Same results hours later after the pc has cooled. PC is about 2-3 years old and still has its original battery.
  • formbergt Nov 20, 2009
    Turns out that the AC adapter had come unplugged from the AD/DC converter, the laptop ran on battery power until dead, the computer then suddenly shut down and would not restart. Laptop is running normally with AC adapter plugged in...sorry for the false alarm...
    Tom
    Brigadier General:
  • 4,090 Answers
This could be a few things, is thye fan working Whilst it is on? if not it is overhheating and the sensor is shutting it down into protection mode. The time it takes to recover seems to indicate this is what is happening.
It could also be a faulty battery, remove it and plug into AC and see if there is any change in behaviour.
Please rate my help++++Thanks for using FIXYA
Posted on Nov 20, 2009
  • dennis bullard Nov 20, 2009
    Ok well thats good for you, no costs and outlay to worry about. Can i ask you to kindly rate my help in speed of reply and information
    cheers nettiser
    Problem Solver:
  • 21 Answers
Could be a problem with your motherboard or the processor which can over heat very quickly and easily make sure that the laptop is put on a straight hard surface so the hot air can get out of the pc. if it does not then the processor will over heat and turn off your pc.
  • t tony Nov 20, 2009
    could be a problem with your motherboard or the processor which can over heat very quickly and easily make sure that the laptop is put on a straight hard surface so the hot air can get out of the pc. if it does not then the processor will over heat and turn off your pc.
I have a compaq presario cq50-107nr and i plug my charger in the front light is on but when i press the power button to start up the light goes off and nothing happens help? It happen several times and i...
Please 1. unplug the ac adapter, detach the main battery, press the power button for 15 seconds, plug in the ac adapter, and restart your laptop. If the problem persist: 2.unplug the ac adapter, detach the main battery, press the power button for 15 seconds, take out the hard drive, plug in the ac adapter, and restart your laptop. If the problem persist, then it means that the laptop motherboard is dying. Please read your laptop's service manual before you open the laptop's case/body.
Mar 01, 2014 | Computers & Internet
I shut down the laptop at once and i turned it on immediately.so only power light is on and the computer is not working.only black screen is seen.
Try this :
1. unplug the ac adapter and remove the battery .
2. press and hold power button for a minute
3. now put the battery back and plug in ac adapter
4. turn on the laptop now
it should work.
if not, try removing hard drive and memory modules then reinstall them back.
if the issue persists, your motherbord has gone bad.
Jul 11, 2011 | Toshiba Satellite P105-S6084 Notebook
Dear Sir My Laptop Lifebook FUJITSU ah530 shutdown suddenly, and also the battery bar on windows 7 says: plugged in not charging. What can I do my laptop shutdown suddenly?? Zuheir Sharafeldin
Hi there there was the same problem with my Fujitsu laptop as well you can try this step
1) Try to change different wall outlet
2) Shut down your computer and disconnect the battery and also the Ac adapter which is connected to your laptop, and then once your computer is Off just press and hold power button for at least 15-20 sec and yes do not lift your finger from the power button
3) Reconnect everything Battery as well as your Ac adapter, and try to see if the issue is resolved or not
4) Just download latest BIOS update from your computer manufacture website , Flash BIOS and check if the issue is resolved or not
5) If everything fails just try and check if the Ac adapter pin is burnt or not, you will see a black spot or something like a burnt spot on the Ac adapter pin of your laptop, if you see this just take any sharp device like Knife etc just scratch clean the black spot and once the black spot is properly cleaned then just connect the pin to the wall outlet and t see the Magic
Hey guys if you really think this works just post you comments or likes so that i will feel happy , really this things works on my 1 year old Fujitsu laptop and i have also worked for
companies like HP and Dell.
Regards
Majid khan
Dec 13, 2010 | Fujitsu (FPCBC21AQ) AC Adapter Battery...
I worked on my laptop and suddenly everything was froyen. CTRL-ALT-DEL did not work, also the power button is long pressed did not work. All that was left was to remove the battery. Then turned with the...
try to take out the battery and disconnect the AC adapter. Press and hold down the power button for approx 10 to 15 seconds to discharge any power left to it. Wait for about a minute, reconnect the battery and AC adapter and try to turn it on. If it powers and but does not boot to the OS, try to tap F12 key a few times when it restarts and from the One Time Boot Menu, select Last Known-Good Configuration and press Enter. HOpe this helps.
Oct 17, 2010 | Acer Aspire 5520-5908 Notebook
Toshiba Satellite L300 shuts down when ac power plugged in
How about this step, try to turn off the laptop itself. Remove the cables and battery just like what you did before, then press and hold the power button for 10 seconds. Then, reinsert the cables and battery on the laptop and then turn on the computer itself. If the laptop restarts, shuts down or freezes with the AC power cables, two things that you should seriously consider. It might be the power cable itself, AC cable port or the circuitry going to the motherboard. And since you have cleaned out the fan and heat sink, you have isolated that problem. Have you plug-in another power cable on your laptop? If yes, then check if it works. Otherwise, the main issue is that the AC port is loose or the circuitry of AC adapter going to the motherboard is not not working. You can re-open the unit and check the circuitry from the AC port going to the motherboard. You may check the circuitry from AC port to the power supply if it is ok. If symptom persist, please contact your local dealer...
Jul 03, 2010 | Toshiba Satellite Pro L300 Notebook
Sa1, screen black I can here the cd and HD working but screen stays black. how can I fix? M series gateway. laptop
Please perform the following steps to resolve the issue:
Power drain process:
1. Shut the computer down.
2. Disconnect the AC adapter and remove the battery.
3. Press the power button down for about 30-60 seconds.
4. Reconnect the AC adapter and the battery.
5. Restart the computer.
Alternately you can test your Notebook power by removing and inserting the Memory and Hard-Disk iin their locations.
May 25, 2010 | Computers & Internet
Conputer won't power on
Hi there.
Remove the power adapter and the battery, plug in AC power and hit the on/off button, if it powers up wait for the OS to load up and the shut it down again, put the laptop battery back in and power it up.
post back with the results please
Good luck and thanks for using Fixya!!
Feb 23, 2009 | Dell Inspiron 8600 Notebook
Hang
There is not a reset button that model. The only other way to force restart it would be to unplug the computer from the outlet. This is not a recommended method but, it can be used a last resort if your computer is hanging.
Jan 09, 2009 | Dell Inspiron 8200 Latitude C840 Laptop...
Will not boot up or turn on though it is getting power
The Charger could be bad, Try replacing that, or let charge, then try to turn on. The laptop might not boot with AC power. kinda stupid but maybe. If that doesn't work, the AC adapter is bad.
Jun 12, 2008 | Lenovo 3000 N100 0689 Notebook
While in BIOS command mode, turned of - not possible to start anymore
Hi Marc, Hope you doing good. Please try the following solution : 1. Disconnect the power cable. 2. Take out the battery 3. Keep holding down the power button for 60 seconds. 4. Put the battery back in. 5. Connect the power adapter 6. Make sure the Power adapter is switched on and laptop is on AC Power 7. Wait for 5 minutes and try to restart the computer 8. If it still doesn't starts. 9. Hold down the power button for 60 seconds with AC adapter and battery connected 10. Try to restart now and check. 11. If it still doesn't switch on 12. Take out the battery and run on only Ac adapter and restart. Please advise if this still doesn't helps.
May 06, 2007 | IBM ThinkPad A22m 2628 Notebook
Toshiba Satellite A135-S4427 Notebook Logo
110 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
