Question about Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television
How to the clean the air filter
Clean air filter
Where is the air filter located in the tv
Posted on Dec 05, 2009
    President:
  • 1,284 Answers
If you have removed the air filter you can dust it off then wash it under a stream of water. You will need to make sure that the filter is TOTALLY dry before placing it back in the TV. Also DO NOT operate the TV without the filter in place. Please take a few moments to rate my answer. Thanks...
Posted on Nov 20, 2009
How often should I clean my air conditioner filter?
You should clean your air conditioner filter at least 2-3 times per month. For a complete guide of how to clean an air conditioner filter, check out this website: http://www.ehow.com/how_5105292_clean-air-conditioner-filters.html
Feb 07, 2013 | Filter Heating & Cooling
You should clean your air conditioner filter at least 2-3times per month. For a complete guide of how to clean an air conditionerfilter, check out this website: http://www.ehow.com/how_5105292_clean-air-conditioner-filters.html
Jul 15, 2012 | Heating & Cooling
Can the hepa filter be cleaned?
The link below will show a page on how to clean and care for your air purifier. Although the Hepa filter can be cleaned multiple times, the manufacturer recommends you replace it every 12-18 months.
Bionaire Air Purifier Care + Cleaning
Jan 09, 2012 | Bionaire LC1460-U Air Purifier
2002 rm 125 oil drain plug size
Anyone who uses gasoline to clean an air filter - needs to re-think that. Gas totally ruins the seams and shortens the life of foam air filters. Gasoline is far too harsh a solvent to clean an air filter. Use something a bit "softer" like Kerosene or even Diesel. These will help your air filter last much longer. Where, sure, gasoline will clean the filter, and many people have been using it for years to clean foam air filters, but, really, gas is horrible for cleaning air filters in the long run. Not to mention how dangerous it is.
If you want to save money, and NOT have to buy air filters as often, do NOT use gasoline to clean it. Use Kerosene or gentler solvents. Any good mechanic will tell you the same.
Jan 07, 2012 | Suzuki RM 125 Motorcycles
How do i access the air filter on the PJ551?
Air-Filter
Cleaning the Air Filter
The air filter should be cleaned as described below at intervals of approximately 100 hours. When
the filter is used for approximately 100 hours, the message "CLEAN THE AIR FILTER" appears
when the projector is switched on.
1 Switch the projector power supply OFF, and remove the power cord from the power outlet.
2 Clean the air filter with a vacuum cleaner.
3 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Please
refer to the description of the "FILTER TIME" on the Table 9: MAIN Menu.
Replacing the Air Filter
Replace the air filter if contamination cannot be removed, or if it is damaged. To order a new air
filter see page 26 for contact information.
1 Switch the projector power OFF, and remove the power cord from the power outlet.
2 Remove the filter cover and the filter.
3 Replace the new air-filter and the filter cover.
4 Reset the Filter Timer using the function of the FILTER TIME on the OPTION Menu. Refer to
the description of the "FILTER TIME" on Table 9: MAIN Menu.
Sep 26, 2011 | ViewSonic PJ551 Multimedia Projector
READS E1
E1-Automatic filter clean reminder.
Turn the air conditioner OFF and unplug it. NOTE: The air conditioner must be unplugged for the automatic filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
Aug 08, 2011 | Haier HWR08XC7 Air Conditioner
E1 error code
Aug 07, 2011 | Haier HWR06XC7 Air Conditioner
Turning off code e1 flashing what is e1 code
Jul 28, 2011 | Sharp Comfort Touch AF-R120EX Air...
The screen is flashing E1
I was told the filter needs to be cleaned.
Turn the air conditioner OFF and unplug it.The air conditioner must be unplugged for the automatic filter clean timer to reset. Clean the filter. After cleaning, replace the filter and plug the air conditioner back in.
Hope this helps :)
Aug 07, 2008 | Danby Heating & Cooling
Projector Reset
Hi Here is the info for you :: Caring For The Air Filter The air filter should be cleaned about every 100 hours. If the indicators or a message prompts you to clean the air filter, clean the air filter as soon as possible. If the soiling will not come off the air filter, or it becomes damaged, then it needs to be replaced. Please replace the air filter as soon as possible. memoWhen you replace the lamp, please replace also the air filter. Turn off the projector, and unplug the power cord. Allow the lamp bulb to cool for at least 45 minutes. Apply a vacuum cleaner to the top of the filter cover and the air filter to clean. If the soiling will not come off the air filter, or it becomes damaged, it needs to be replaced. If the air filter needs to be replaced, contact your dealer to prepare a new air filter. Tell the dealer your air filter type. Turn on the projector power, and reset the filter timer. (1) While the projector running, press the MENU button to open the menu. (2) Choose the ?OPTION? on the menu using the / button, then press the button or ENTER button. (3) Choose the ?FILTER TIME? using the / button, then press and hold theRESET button for 3 seconds. (4) Choose the ?RESET? using the button. memo Incorrectly resetting of the filter timer (resetting without replacement, or neglect of resetting after replacement) will result in incorrect message functions. Here is the link to the users manual :: http://www.aboutprojectors.com/Hitachi-CP-X1250-projector.html Further Questions ?? Email Me hartmansp@inbox.com Have a great evening.
May 03, 2007 | Hitachi CP-X1250 Multimedia Projector
Panasonic PT-50LC14 50" Rear Projection HDTV-Ready Television Logo
866 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
