Question about IBM ThinkPad T40 2373 Notebook
I have 2 ibm thinkpads t40, on one of the systems the lcd inverter and screen get no power but when i take the lcd and connect it to the 2nd ibm tkpad it works fine, What would be wrong with the one lap top that the inverter wouldnt get power when the colling fan harddrive? again on one system base both lcds work fine, when i connect them to the seconf base the base turns on harddrive works and fan spins but no power to inverter board. how can i fix this
  • IBM Master
  • 5,660 Answers
On the second Thinkpad laptop, that doesn't show a display with an LCD screen.
Plug a VGA monitor into the VGA port on the back of the laptop.
Hold the Fn key down, tap once on the F7 key (Toggle your display over to an external monitor)
Give the VGA monitor a few seconds to come on. (It's a VGA monitor)
Do you have a display on the external monitor? No? You May have a bad GPU then. (Graphics Processing Unit,
http://en.wikipedia.org/wiki/GPU )
Fix? Change out the motherboard. Possibly Ebay has one, dunno.
VGA monitor has a display? Then you may have a bad Inverter. The Inverter provides power for the LCD screen. Inverters go bad.
Are both Inverters the same? (Laptop to laptop)
BE SURE. The Inverter MUST match the LCD screen!
Check the numbers on both Inverters. If they are the same, switch the good one over to the 2nd laptop. See if you have display now.
No?
Then it's the GPU.
Service Manual for IBM Thinkpad T40,
http://tim.id.au/laptops/thinkpad/T40-T40p-T41-T41p-T42-T42p.pdf
Copy and paste the above link into your Address bar. Press the Enter key. (I don't post direct links that you just click on. I want the asker to be able to see where the link takes them, by looking at the link. I feel it helps make the asker more comfortable with my solution, knowing I have their best interest in mind.
Regards,
joecoolsvette)
(If this link doesn't work for you, come back, and let me know)
Posted on Nov 20, 2009
My IBM Thinkpad screen has gone dark but I can still see a bit. Is there a key to brighten the screen?
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Aug 29, 2010 | IBM ThinkPad T23 2647 Notebook
Why does my thinkpad blink on and then go black once I turn it on? The model is T40 2373
its having problem posting. You might need to have a replacement of the motherboard and power supply. you can contact IBM if system still within warranty
Jul 21, 2010 | IBM ThinkPad T40 2373 Notebook
IBM thinkpad turns on but screen stays black.....
Hi, This issue is clearly hardware and might be related to 3 part, Inverter card, LCD cable or LCD Panel ( Or systemboard, just to make sure try with an external display if the issue reproduce it's systemboard/graphic card related, if not LCD related ). If you are still entitled to warranty then this hardware failure is covered by the terms. You should have the 3 parts stated below replaced as it s a common issue with Thinkpads.
In case you are out of warranty cover you still can try to subscribe to a warranty extension, you can check on www.lenovo.com , otherwise you might want to order theses parts on a website such as ebay. To swap the pieces requires quiet advanced skills as you have to take down the whole computer, obviously LCD Panel included. Unfortunalty this is hardware related, not much you can do... I hope this help ! Thanks and have a nice day ! J -
Jul 10, 2009 | Apple iPhone Smartphone
MY IBM THINKPAD HAS A BLACK SCREEN.WHAT MIGHT BE THE PROBLEM AND SOLUTION?.
You could have a defective screen - a defective inverter or a CCFL lamp or simply the video cable needs reseating. After reseating the video cable and the problem is still there then :- To determine if you have a LCD screen or video card problem, read this and follow the instructions. Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case. The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills. Check out www.lcdparts.net for parts, repair service and DIY info.
Jun 16, 2009 | IBM ThinkPad T40 2373 Notebook
IBM T40 Laptop screen goes black, will not come back
First of all, you have to check whether you can see video signal with surrounding light tilting the screen.
If you can see dim image, all you have to do is replace back-light inverter or fix it. Usually, the fuse is open and you can connect it by simple soldering.
If you can't see dim image, it is another problems.
Give it a try.
Dec 09, 2008 | IBM ThinkPad T40 2373 Notebook
My screen on my T40 shows lots of gibberish colored squares
If you have access to an external monitor, connect it to the laptop. If everything works properly, then the screen or inverter has gone out. If you get the same garbled screen, then the video card has gone out.
Jul 28, 2008 | IBM ThinkPad T40 2373 Notebook
IBM,lenovo ThinkPad R31
Maintenance manuals for both systems are on www.lenovo.com/support, under the publications section. But without looking at it, I would say no, the cables will not work.
Jun 09, 2008 | IBM ThinkPad R31 2656 Notebook
IBM Thinkpad t40 black screen
Chips DO get loose and what you're experiencing is a common problem with IBM T40's. The solder that holds the graphics processor to the motherboard is cracked and no longre consistantly makes a good connection. This problem can only permanently be resolved with a new motherboard, or reflowing the solder of the GPU chip on the old one with a heat gun. Do a search for "thinkpad solder reflow" in any search engine.
Good luck.
Mar 28, 2008 | IBM ThinkPad T40 2373 Notebook
IBM ThinkPad T40 2373 Notebook Logo
266 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
