Question about Fellowes Powershred DM8C (Confetti) Shredder
My Fellowes shredder DM17Cs won't stop running unless shut off
I have a Fellowes paper shredder, model DM17Cs. It shreds fine but it no longer stops running when I put paper through. How do I get it to stop running without having to shut it off??
    President:
  • 3,085 Answers
Blow some canned air down into the feed slot to clean the sensors.
Posted on Nov 20, 2009
  • 3 Answers
Throw it away and buy a new one. The Eye sensor if FRIED.
Posted on May 12, 2010
Motor problem
It sounds as if the SafeSense is improperly shutting of the forward sensor. Call Fellowes and see if they can help.
If you do not have the manual use the link below:
Fellowes Shredder Manuals
Aug 18, 2014 | Fellowes 75cs Cross Cut Shredder -...
Only runs in reverse
I just had this problem with my shredder. I think the problem started with a bin that was full. Running the shredder in reverse resulted in shredded paper being pulled up into the slot used to feed paper into the shredder. Some of this shredded paper was blocking the little plastic tab that activates the switch when paper is inserted, so the shredder would no longer start when paper was inserted. I emptied the bin and removed the shredded paper from the feed slot, being careful not to break the plastic "sensor" while removing the paper from under it. The shredder works fine now.
Dec 13, 2010 | Fellowes W11C Confetti-Cut Shredder
Runs only in reverse
Nov 06, 2010 | Fellowes W11C Confetti-Cut Shredder
Was shredding papers and unit stopped,and will not take anymore papers,but it will still go in reverse Fellowes model w11c
Make sure you use a can of compressed air and cotton swabs to cean the entrance and exit sensors.
Jun 11, 2009 | Fellowes W11C Confetti-Cut Shredder
Overly loud shredding; stops prematurely
I have taken many shredders apart and found them so clogged up with shreds of paper and too much oil will turn into paper mud.Be bold and take the top off and clean it out. Unplug the power source and when removing the top , be careful because their will be a short cable connecting the top to the circuit board. Easy to damage.
May 12, 2009 | Fellowes S701CM Shredder
PowerShred C-220 will not shred automatically
OK lets try.
You likely have a photo sensor that detects the paper and it is dirty.
It is likely covered with paper dust (hopefully only on the outside)
Locate the sensor and wipe it off or just wipe the entire throat area.
WITH MACHINE OFF
Hope this helps
Dec 05, 2008 | Fellowes Powershred C-220 Strip-Cut...
Shredder stops in the middle of shredding and won't shred.
Is the paper bin full?....mine always shuts down when the paper bin is a little over half full.
Jan 21, 2008 | Fellowes 220 Powershred Strip-Cut Shredder...
Shredder no longer runs
Fellowes Customer Service is the best in the business call them at 1-800-945-4545
Dec 06, 2007 | Fellowes P600C-2 Shredder
Shreader won't turn off.
The paper sensor is stuck, actually a pretty common problem with many auto shredders. Basically the sensor for auto shredding thinks that there is still paper in the unit so it won't shut off. This can easily be caused by shred debris. Shooting some compressed air into the unit may help but usually it requires a bit more effort. Sadly, these guys can be quite hazardous to repair so I would not really suggest trying to open the unit unless you really know what you are doing.
Aug 18, 2007 | Fellowes Powershred 220CC Shredder
Fellowes Powershred DM8C (Confetti) Shredder Logo
681 people viewed this question
Top Fellowes Office Equipment & Supplies Experts
quennie732
Charles T Nevin
Charles T Nevin
Adorjani Laszlo
Are you a Fellowes Office Equipment and Supply Expert? Answer questions, earn points and help others
