Question about Cherry Electrical (G83-6759LPAUS-2) Keyboard
Need a driver for the card reader for the Cherry g83-6759lpaus-2 keyboard for Windows Vista
(dual boot system)will not read a card reader in vista 32bit, but works fine in windows 7 64bit. Loaded drivers in Vista
Try driver download from her http://www.startech.com/Cards-Adapters/USB-3.0/Cards/2-Port-PCI-SuperSpeed-USB-3-Adapter-Card-with-SATA-Power~PCIUSB3S22
Although I dont understand your statement " will not read a card reader" since you state a problem with the Syba Infozone cable.
Is the problen your USB 3 port or the Syba cable.
Mar 29, 2014 | BestPriceCables Syba InfoZone SuperSpeed...
Schlumberger Reflex USB v.2 Smart Card Reader Driver
i dont think there is one after XP. gemalto havnt bothered with it. some usb smart card readers were included with some usb keyboards on some pc makers like Dell its possible that the drivers for these might also work for the reflex one you have. but its also likely they will not load. you could try either a dell or hp smart card usb driver. you also have to turn on smart card reading service in the OS. Dell USB Smart Card Reader Keyboard Driver Driver Details Dell UK https://technet.microsoft.com/en-us/library/dd979545(v=ws.10).aspx
Jan 27, 2012 | Cameras
No base system device
Base system devices on laptops are usually tied with WebCam or card reader drivers. If your computer has Windows 7 on it, just download and install WEBCAM and CARD READER drivers from the manufacturer's website. If it has Windows Vista or XP, you may have to download and install the chipset drivers first, then the other 2 mentioned above.
Aug 12, 2011 | Acer Computers & Internet
In my win 7 card reader doesnt support .. Why?
Try installing the device using Vista drivers, You need to use compactibility mode to get it to work though or :
1) Disconnected Media Card Reader and reconnected it. I wanted Windows to automatically detect the hardware change. Details of the first step:
a) Turned off Windows.
b) Disconnected Media Card Reader.
c) Turned on Windows.
d) Turned off Windows.
e) Connected Media Card Reader.
f) Turned on Windows.
2) Disabled and re-enabled the controllers.
a) Opened Device Manager.
b) Expanded IDE ATA/ATAPI controllers.
c) Uninstalled each item one by one.
d) Restarted the computer.
3) After the computer started, Windows reinstalled all the controllers
Jan 20, 2011 | Dynex External USB 2.0 Multiformat Memory...
GT4010 - my card reader all of a sudden will not work unless I reboot. Then it will work for a while - but if I let it sit for a few hours and try again, it will say "please insert card" (the...
OK!!
DELETE your drivers via Control Panel / SYSTEM... install a 'fresh driver set'...
I found MANY drivers for ALCOR:
https://pcsupport.lenovo.com/us/en/downloads/ds031997
IT is the LAST Link below ~ try it FIRST!
I found "GATEWAY" driver sets for your specific CARD READER, but it's for a VISTA 64 Bit O.S. The address is here.
http://www.gateway.com/gw/en/US/content/drivers-downloads
It reads:
"CardReader Alcor 15 in 1 Media Reader Driver 2.02.01.01 6.0 MB 2010/07/21"
The Link below may not work for you and if not, use the address above. Also know the the SEARCH function at GATEWAY is BROKEN ~ so you may need to 'drill down' to the download link?
> Desktops
> GT Series
> GT4010
> Operating System
> Windows VISTA 64
____________
ALSO DO a GOOGLE SEARCH FOR:
Card Reader Alcor 15 in 1 Media Reader Driver
You should have around 169,000 HITS ~ and maybe you will find a newer/better driver from one of them?
Drivers Downloads
Download Gateway GT5082b Alcor Card Reader Driver 2 01 03 01 for Windows...
THIS ONE!
Dec 07, 2017 | Gateway GT4010 (RBGT4010) PC Desktop
Samsung Q35 notebook with Windows 7 , no sound and sony card read
Find the manufacturer of those devices and go to the manufacturer website and download the windows 7 drivers. There probabbly aren't any.
Windows 7 will use vista driver if upgrading, but not with fresh installs.
or
purchase driver magician and run the update feature.
Jan 24, 2010 | Samsung P30 Notebook
I have a finepix s5500 camera but the softwear is xp and i need a vista version, is it possible.
All Fujifilm digital cameras will work on Windows Vista using drivers already installed on the operating system.
The finepix viewer software supplied with our cameras will require a update which can be downloaded from the following link
http://www.fujifilm.com/products/digital/download/02/index.html#windows5.3
Accessories
The following products are not compatible with Windows Vista:
FD-A1/FD-A2 (Floppy Disc Adapter)
DM-R1 (Image Memory Card Reader)
DPC-R1 (Image Memory Card Reader)
The following products are compatible with Windows Vista:
SM-R1/SM-R2 (Image Memory Card Reader)
PC-AD3 (PC Card Adapter)
DPC-AD (PC Card Adapter)
DPC-CF (CF Card Adapter)
DPC-UD (USB Pen Drive)
Oct 17, 2009 | Fuji Finepix Z20fd Digital Camera
Dell usb smartcard keyboard model#sk-3106 need the software
http://ftp.us.dell.com/input/R148501.EXE
You can download the driver here.  However, it is not compatible with some newer CAC Cards especially with Vista.  If you install the driver and it won't read, you need a new reader.  Sorry.
Nov 22, 2008 | Dell Smartcard USB Keyboard SK-3106
Sd card reader
You can find the driver download at the following website that i have provided... look for the following in this list... If you have XP do the XP download and install... and the same if you have Vista. Hope this helps!!! this is a list specifiaclly made for your laptop. If anything else stops working refer to it and you might find the resolution. CIAO!
http://www.acerpanam.com/synapse/forms/AcerDrivers/Aspire%203680.pdf?CFID=1266040&CFTOKEN=21904604
Look for:
IF YOU HAVE WINDOWS VISTA--------->
Card Reader TI Driver 2.0.0.6q for Windows Vista
Windows Vista
Card Reader TI Driver 2.0.0.6q.zip
IF YOU HAVE WINDOWS XP----------->
Cardreader - Driver V2.0.0.2
Windows XP
TM4220_CardRdr.zip <--- click on this within the website i provided.
good luck.
Oct 20, 2008 | Acer Aspire 3680 Laptop
Mikomi card reader
you may have to check the manufacturers website for a vista compatible driver (as it seems that the generic driver is not working here.)
Oct 22, 2007 | Electronics - Others
Cherry Electrical (G83-6759LPAUS-2) Keyboard Logo
50 people viewed this question
Top Cherry Electrical Computers & Internet Experts
David Payne
David Payne
Are you a Cherry Electrical Computer and Internet Expert? Answer questions, earn points and help others
