Load the 110 output and disconnect pin number five of STR, now full output will be showed, pin five is controlled from system control ic, trace this route.
Comments:
Jan 22, 2008
- Hello,
As an add on to what I have posted last day, this pin five is the standby control pin for the STR, and it is controlled from the television microprocessor. This STR outputs a voltage around 50V in standby, so I believe the power supply is okay, the problem is most probably with oscillation because microprocessor controls the STR depending on the horizontal and vertical sync pulses. So disconnect the control pin and trace out the problem.
I recently missplaced my remote and i was wondering if there is a manual way to put it on to were i...
(More)
I recently missplaced my remote and i was wondering if there is a manual way to put it on to were i could watch a dvd with my dvd player?
ive got a maual hd switcher model sws232sw/17 says its for all systems and im trying to set it up...
(More)
ive got a maual hd switcher model sws232sw/17 says its for all systems and im trying to set it up for my boys so they have there PS2 and XBOX and dvd player all on one tv my tvs are coaxial cable this box is svideo can i still hook it up do i need a converter or should i just go back to the salesman and jackie chan him....
