Tevion tv won't display normal colours on PAL 60 setting
I have an ALDI 32 inch tv and have just bought an xbox 360. Everything works fine, except that when I switch the display setting to PAL 60 (which all of my games require) the quality of the picture isn't as good and some colours like red are shown as a fuzzy green. Is there a way to tune the tv so that it will display normal colours using this PAL 60 setting? Do you have any other solutions?
Thanks very much for your help in advance
  • 156 Answers
Look behind of the TV for trim adjust potentiometers. If there are any of them, you shall open your tv's backcase, look for Crominance trim and adjust it manually. If you have no electronics knowledge, i wouldn't not recommend do it "for pratice", you may distroy the TV, end in the hospital, or into a coffin.
Posted on Nov 20, 2009
My Xbox 360 shows a grey screen, the sound works fine and i do have picture
Hey dude, I had this problem and found a solution on another website. Basically, I had either changed the display settings on my tv, or it had done it by itself or my new ps3 had done it or whatever, but to fix it I went into the TV menu, went to display options, on my tv it has something entitled 'Colour system' I changed that to PAL-60 and I now have colour, just to give you an idea of whether you have the same problem, try setting your x-box display to pal-50 and see if that shows colour (if it's easier to do), if it does then try then solution above! Hope it helps!
Mar 13, 2012 | Microsoft Xbox 360 Console
I have a Philips flat screen HD ready TV for my xbox. I don't know what type though as my parents have upgraded to an LG and we now have this Philips TV. I have Sky connected to one of the EXT ports and...
Perhaps the Phillips TV isnt compatible with some of the Xbox Settings.
Or mabye when you adjusted your settings it may have affected any graphics.
Apr 07, 2010 | Microsoft Xbox 360 Console
My tv runs on pal50 but some games on xbox360 run on pal60 , how do i play these games on my tv
Standard definition TVs loadTOCNode(2, 'moreinformation'); If you connect your Xbox 360 console to a standard definition TV, follow these steps to set the Xbox 360 display settings to PAL 60 Hz:
  1. Turn on the Xbox 360 console.
  2. In the Xbox Dashboard, select System, and then press the A button.
  3. Select Console Settings, and then press the A button.
  4. Select Display, and then press the A button.
  5. Select PAL settings, and then press the A button.
  6. Select PAL-60, and then press the A button.
  7. When you are prompted to keep these new settings, confirm the settings, and then press the A button.
Note Some older TVs do not support PAL 60 Hz. If you do not know whether your TV supports PAL 60 Hz, contact the manufacturer of your TV or see the owner's manual.
Mar 07, 2010 | Microsoft Xbox 360 Arcade
PAL 60 Display Problem
Greetings,
Please go through the Website link mentioned below.
http://support.microsoft.com/kb/917304
Please let me know if you have any issues.
Regards,
Feb 12, 2010 | Microsoft Xbox 360 Console
Picture will not show
You might want to try the following:
1. make sure that the AV cable is not loose or incorrectly seated in both the Xbox 360 console and the TV
2. make sure that you have the correct AV cable for your TV, to verify that the AV cable is connected correctly to the Xbox 360 console and to the TV, disconnect the AV cable and then reconnect the AV cable to both devices
3. if you are using composite cables, do not try to set any HDTV settings because you may lose the picture
4. make sure that your TV is set to the same video broadcast system as your Xbox 360 console (PAL or NTSC)
Example:
- if your Xbox 360 console is an NTSC console, make sure that your TV supports NTSC
- if your Xbox 360 console is a PAL console, set your PAL settings to PAL 60
- if your TV has a type of picture compensation enabled, disable it
5. reset your Xbox 360 console
- Remove any discs from the disc tray
- Turn off the console
- Turn on the console
- As the console starts, press and hold the Y button, and then pull the right trigger at the same time
- The Xbox Dashboard resets the display settings to the default settings and then automatically restarts the console.
6. Do not take your Xbox 360 console or its accessories to your retailer for repair or for service unless an Xbox Customer Support representative asks you to do this
Mar 09, 2009 | Microsoft Xbox 360 Console
My xbox 360 is from the united kingdom (england) i am in canada, i have bought a power converter to convert voltage, but, the screen is in black and white!!ive plugged everything in as normal!am i doing...
A UK Xbox will work on a uk TV, which uses the PAL colour system. Canada use NTSC so the image is black and white. Can the Xbox be configured for NTSC ?
Dec 30, 2008 | Microsoft Xbox 360 Console
Xbox 360 black and white
I would check to make sure your video settings aren't set to PAL-60 by mistake. It might be easier to resolve if you could let us know what leads you have and where you've plugged them in to.
Jul 24, 2008 | Microsoft Xbox 360 Console
Xbox 360 turns on, but nothing shows on the screen
If the person that you bought it from on E-Bay had an HD Television. Then the Xbox console is set into HD from the Display options. If your TV is not HD, then It will not display. It can also be the other way around, if His TV is standard and yours is HD. Also try looking at the RCA's(The Part that plugs into the 360) And you will see a slider. Switch the slider, then turn it on. Tell me if that works, if Not, tell me and I will tell you what to press on your 360 controller to set the other menu. Hope this helps.
Jul 11, 2008 | Microsoft Xbox 360 Console
How to change from PAL-50 to PAL-60?!
i have a xbox 360 and a television that opperates at PAL-50
my xbox is telling me, to play a game i must operate at PAL-60.
when i change the xbox settins to PAL-60 the televison goes all fuzzy, can i fix this.
Apr 14, 2007 | NEC MultiSync LCD1550VM 15" LCD Monitor
Televison & Video Logo
250 people viewed this question
Top Televison & Video Experts
