Question about LG WM-2277HW Front Load Washer
My LG washer keeps displaying LE error and shuts down. What is wrong with it?
  • vc813 Nov 20, 2009
    I have had this machine serviced twice. 1st time replaced the sensor, 2nd time replaced the motor. It still displays the LE error. What else could it be? Paid close to $300 to have repaired and it still does not work.
  • 6,784 Answers
HI, this error code is referring to a locked motor issue. This will occur if the The connector (3-pin, male, white) in the motor harness is not connected to the connector (3-pin, female, white) of stator assembly. Other issues with the motor harness may pertain to The electrical contact between the connectors, (3-pin, male, white) in the motor harness and 4-pin, female, white connector in the main PWB assembly is bad or unstable. Or the motor harness between the sator assembly and main PWB assembly is cut (open circuit). If all the motor harness connection are in good condition, This will lead to an out of order or, defective hall sensor. in this case, the motor will need to be replaced.
Posted on Nov 20, 2009
LE error on washer. What can I do without a tech?
The *dreaded* "LE" error is overwhelmingly caused or triggered by incorrect type detergent **OR** too much *HE* detergent (a special low sudsing detergent).
In all LG washers-when too much detergent has been used-this will cause the "LE" error to be displayed & the wash cycle will be interrupted. Unplugging the washer for more than one minute will cause the MAIN BOARD (computer) to power down and re-boot when the washer has been plugged back in.
On LG washers built *before* 2008-after several "LE" error events-the error *cannot* be reset by unplugging the washer. This indicates that the HALL EFFECT SENSOR has failed and will need to be replaced.
On all LG washers built during and after 2008-a more robust resistor was used in the HALL EFFECT SENSORS-which eliminated damage caused by higher electrical loads placed upon the sensors due to oversudsing. HALL EFFECT SENSORS virtually never fail in 2008 and newer LG washers but the "LE" error will still occur if too much or the wrong type of detergent is used. This will be "resettable" by unplugging/replugging the washer.
The CORRECT amount of HE (High Efficiency) detergent to be used is as follows:
HE : (2) Tablespoons Per Wash Load
HE 2X : (1) Tablespoon
HE 3X : (1) Teaspoon
USE THESE AMOUNTS RELIGIOUSLY-NO EXCEPTIONS-IN ALL FRONT LOAD WASHERS WITH 3.0 cu ft DRUMS AND LARGER
Read more: The Dreaded LE Error Code in LG Washing Machines: Diagnosis / Troubleshooting, Root Causes, and Repair ' Washer Repair ' Fixitnow.com Samurai Appliance Repair Man http://fixitnow.com/wp/2010/08/03/the-dreaded-le-error-code-in-lg-washing-machines-diagnosis-troubleshooting-root-causes-and-repair/#ixzz2nlabX1Gv
Follow us: fixitnowsamurai on Facebook
Dec 17, 2013 | LG WM2233H Front Load Stacked Washer /...
My 7 year old LG Front Load Washer Model # WM1812CW displayed ERROR CODE LE(Overload in motor): how can I fix this problem ? The rinse cycle begins, shortly thereafter, the machine stops and the LE code...
Hello & Welcome to FixYa
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall Effect sensor is used in these washers which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when there is an issue with the motor or when the Hall Effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sensor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Aug 29, 2011 | Washing Machines
LG WM 1485FHD with LE error code. Stope washing after 5 or 10 mins and can't get it to complete cycle
Kevin
Jun 14, 2011 | LG WM-1485FHD Front Load Washer
"LG Tromm WM2277HW will not
LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad. Please get back to me if you have any other questions.
Kevin
Mar 27, 2011 | LG WM-2277HW Front Load Washer
LG washer WMO642HW shows on display window le and i lost my owners manual
Kevin
Mar 14, 2011 | LG Washing Machines
Washer lg is having error LE
Hi, LE error in your LG front load washer is displayed when either the motor is not working or the control board thinks that the motor is locked up. A Hall effect sensor is used in these washer which monitors the speed and direction of the motor and then forwards this information to the control board. Hope you understand by now that this LE error is displayed when their is an issue with the motor or when the hall effect sensor sends wrong signal to the control. Conclusion is you'll have to check both motor and hall sesor and replace the part# that is bad, usually I have seen the sensor going bad.....
Dec 29, 2010 | Kitchen Ranges
My washer won't spin. Error shows up LE. what can I do.
Hello
Kevin
Nov 08, 2010 | LG WM-2277HW Front Load Washer
LE error on LG wm1814CW
My wife and I had the same LE error on our LG washer intermittently in the past. We have already been down the road to replacing the Hall Sensor only to find the washer not spinning and displaying the LE error again. Here is what we have found to be the remedy: Being that the Hall Sensor is a "Position" Sensor, we made a conscientious effort after unloading the washer to place the drum in the same position as when it finished its spin cycle. It has now been about 3-4 months with NO "LE" ERROR on the washer!!! One other thing - if you currently have the error displaying, you will have to unplug the washer for at least 2 hours to erase the memory of the drum position. This way you start fresh with a good position. Just leave it unplugged overnight. Hope this helps out!
Mar 14, 2009 | LG WM1814CW Front Load Washer
"le" on the LG WM0532hw front load washer errror
try unpluging for 45 seconds than hold in the selector knob for 10 sec. & plug back in
Feb 02, 2009 | LG WM-0532HW Front Load Washer
LE trouble code
The LE error code can be an indication of several different issues. The most common cause is over-sudsing in the machine. Many times owners experiencing the LE error code are using regular detergent. It is recommended to use a high efficiency or low sudsing detergent. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause the error code. This can occur if there is a loose wire, dislodged ball sensor, or if the shipping bolts are removed prior to situating the washer. Good luck!
Sep 13, 2007 | LG 24 in. LDS 5811ST Stainless Steel...
LG WM-2277HW Front Load Washer Logo
230 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
