Question about Toshiba Qosmio G25-AV513 Notebook
Unable to boot from HDD1 position or recreate RAID1.
I finally have the correct hard drive capacity recognized in BIOS, but both hard drives are now JBOD -- unable to recreate RAID1. Also, laptop will only boot from HDD2, no matter which hard drive is in that position.
BIOS, Toshiba RAID utility, and Acronis True Image see 2 separate hard drives, but Windows XP only sees a single (Healthy, System) hard drive.
How can I recreate RAID1 and bootability from the HDD1 position?
  • 1 more comment
  • drrocket Nov 20, 2009
    Configuring BIOS to boot from HDD1 (which is the default setting) doesn't help. The laptop gets a BSOD when trying to boot into Windows XP from HDD1, but will successfully boot from HDD2. I even tried swapping the position of the hard drives; each hard drive will boot into WinXP ONLY when installed as HDD2.
    I think because HDD2 (rather than HDD1) is the active hard drive, Toshiba RAID utility (in Windows) won't let me create a RAID1 array. In BIOS, both hard drives are currently designated as [Optimal condition] JBOD. The only other BIOS options are RAID-0s (1RAID-0 or 2RAID-0), whereas RAID1 is actually the factory default. I must have broken RAID1 while trying to get the BIOS to recognize the correct capacity of the installed hard drives (it kept giving the CAPACITY of the original, smaller, hard drives even though it read the current hard drives' actual size).
  • drrocket Nov 22, 2009
    Problem solved: Using the 2 identical, formatted hard drives, I used the factory discs to restore the laptop to its original factory state, including its default RAID1 state. This maintained correct capacity in BIOS and made HDD1 bootable again. Upon first boot into Windows of the newly factory-state restored laptop, the RAID Console utility offered to mirror the 2nd hard drive, recreating the RAID1 array. At that point I closed out of Windows and used an Acronis bootable CD to restore my most recent back-up (but NOT MBR or Track 0). Booting the Acronis-restored system, HDD1 successfully booted into Windows, and the mirroring process proceeded automatically. Problems solved.
    Problem Solver:
  • 21 Answers
You need to go into your bios and tell it to boot from the other hard drive make sure you plugged in the right wire to power it it should be the same as one used for the hard drive that works and plug it in tightly.
Posted on Nov 20, 2009
Dell b110 does not recognize more than 32 gb of hdd
check the jumper settings of the hard drive
The drive is larger than 32GB, but the operating system only recognizes 32GB. If the operating system, BIOS or DiscWizard can only recognize 32 GB of the drive it may be caused by one of the following:
  1. Drive Jumpers: Applies to Mac and Window users. On drives that are larger than 32 GB there is a Capacity Limitation Jumper (CLJ), also known as the Limit Capacity Jumper or the Alternate Capacity (AC) Jumper setting. This jumper will limit the capacity of the drive to 32 GB and should only be used when the BIOS hangs when trying to auto-detect the drive. If you have two jumpers shunts on the drive you will need to remove the CLJ or AC jumper. If you format the drive with the CLJ or AC jumper then the drive capacity will be limited to 32GB. After removing the CLJ or AC jumper the drive will still be recognized as 32GB. You must reformat the drive without the CLJ or AC jumper to gain the full capacity of the drive. The other option is to create a second partition with the remaining unallocated disc space.
  2. BIOS: On older systems (pre- November 1998) the BIOS may not support drives that are larger than 32 GB. In the BIOS setup please set the drive type to AUTO detect. If the BIOS detects the full capacity of the drive then the BIOS will support the capacity of the drive. If not please perform one of the following:
    1. Check with the system or motherboard manufacturer for any BIOS upgrades for the system.
    2. (Recommended) Purchase a PCI ATA controller card that will support the capacity of the drive. The two benefits of ATA controller cards are:
      • The ability to support large capacity drives
      • The ability to support the faster transfer rates of the drive.
  3. Operating System: Windows have a 32 GB format limitation for FAT 32. That means if you formatted the drive in FAT 32 with Windows, the largest partition supported is 32 GB. You will need to format the drive in NTFS if you want to partition the drive larger than 32 GB. The other option is to create a second partition with the remaining unallocated disc space.
  4. Incorrect Reporting to the BIOS: The drive itself may be reporting the incorrect size to the BIOS. In order to correct this, you will need to download SeaTools for DOS, boot into the SeaTools disc, and run the Set Capacity utility. It is recommended that you only have the hard drive reporting the incorrect capacity connected to your system while performing the following steps. Any other hard drives should be disconnected.
    It is recommended that you back up any important data on the hard drive before using SeaTools to set the drive size. This is a potentially data destructive procedure. Seagate is not responsible for any lost data.
    After correcting the drive capacity, the drive may still show a partition size of 32GB but with unallocated space. You must delete its current partition then repartition and format the drive to gain the full capacity of the drive. The other option is to create a second partition with the remaining unallocated disc space.
    1. Insert the SeaTools for DOS CD or floppy disc into the appropriate drive, and restart your computer. When SeaTools boots up, carefully read the license agreement, and press Y if you accept it.
    2. Select the correct drive from the list using the mouse or keyboard.
    3. Choose Advanced Features .
    4. Choose Set Capacity to Max Native.
    5. Once the capacity has been set SeaTools has returned to the main screen, take the SeaTools disc out of the drive and completely power down the system. The system needs to be shut down so any cached information is cleared. If you simply reboot or reset your computer without completely powering it down first, the corrected capacity setting will not take effect.
REFERENCE TO THIRD PARTIES AND THIRD PARTY WEB SITES. Seagate references third parties and third party products as an informational service only, it is not an endorsement or recommendation - implied or otherwise - of any of the listed companies. Seagate makes no warranty - implied or otherwise - regarding the performance or reliability of these companies or products. Each company listed is independent from Seagate and is not under the control of Seagate; therefore, Seagate accepts no responsibility for and disclaims any liability from the actions or products of the listed companies. You should make your own independent evaluation before conducting business with any company. To obtain product specifications and warranty information, please contact the respective vendor directly. There are links in this document that will permit you to connect to third-party web sites over which Seagate has no control. These links are provided for your convenience only and your use of them is at your own risk. Seagate makes no representations whatsoever about the content of any of these web sites. Seagate does not endorse or accept any responsibility for the content, or use, of any such web sites.
Apr 14, 2014 | Dell Dimension™ B110 PC Desktop
Lost bios settings
Your hard drive is missing from the system. Or, just does not recognize it. The obvious - Remove any USB devices like drives and any media from disc player. Its trying to load, but can't find bootable hard drive, CD, or USB... Remove the hard drive and re-seat (reconnect). Check BIOS by pressing an F key during boot. Look on the screen for correct Function key. Might be F2 key. Verify BIOS recognizes the drive. It must be listed! There is no going forward if it's not. Check boot order and make internal hard drive first. Save and restart.
Dec 09, 2012 | Dell Dimension 8250 PC Desktop
Boot failure insert system disk, but it wont load
You need to check both in BIOS by pressing F key during boot. First check to see if HD is there. If OK, then change Optical drive to first boot, save and reboot.
IF MISSING HD -
Dec 07, 2012 | Computers & Internet
I upgraded matheboard from p6t6 (stopped working for some reazon) to p6t7. My hard drives have been set up to raid. I have windows 7 ultimate installed. I set bios to raid and choose proper disc as boot 1...
On many systems with RAID1 support built into the mobo chipset, that system includes some RAID management software in BIOS. You won't see it until you turn on RAID capabilities in the BIOS and add a drive. But you might find all the details you need in manuals on the matter from Dell, so look for those. They could have come with your machine, or you may have to search their website and download.
On systems I've seen you create and manage RAID arrays using that built-in software, NOT Windows tools. In fact, some RAID1 management tools would allow you to convert a single stand-along HDD to a RAID1 array by adding a matching HDD unit and then having the system copy all the data to the second drive. This is almost the same as the process to repair a damaged RAID1 array by replacing one faulty drive with a new one and rebuilding the array.
HOWEVER, Windows ALWAYS needs a RAID driver installed in it to use any RAID array. If you are simply booting from a "normal" stand-alone disk into Windows and then using a RAID array as a data storage system, the RAID driver installation can be done any time after Windows is running as you set up the new storage system. BUT Windows in ANY version cannot BOOT from a RAID array unless the RAID driver has been installed at the very beginning of the OS installation. This implies that, if you want to convert your single disk into a RAID1 2-disk array and use ONLY that as the HDD resource in the machine, you will need to re-install Windows, this time including the required RAID driver install at the beginning, in order to boot from that array.
I have read that there may be ways to convert a non-bootable RAID array into bootable by some complicated editing of Windows registry and boot files in order to force it to load the right driver at the right time from the right spot on a HDD, etc. But I am not SURE that would work. It's definitely for the adventurous knowledgeable techie.
So here's a quick guide to installing hardware RAID on a motherboard that features a RAID controller. These steps assume you are performing a clean Windows 7 install rather than an upgrade, and they might differ depending on your system set-up, but the general principles should be the same.
  1. Download the RAID drivers for your motherboard from the manufacturer's website and save them to a memory stick.
  2. Back up all your important data!
  3. Turn your PC off and unplug it.
  4. Install 2 hard disks preferably with identically capacity into your PC.
  5. Turn on your PC, press the delete key or F2 key when prompted to get to the BIOS menu.
  6. Find the option to select the RAID mode, save your settings and exit BIOS.image.axd?picture=bios-raid-options.jpg
  7. On reboot you should see a new menu option to enter the RAID controller settings. Enter the key combination when prompted to get to the RAID controller menu. image.axd?picture=amd-raid-menu.jpg
  8. Create a new RAID array selecting either RAID 0, or RAID 1.
  9. Select the disks that will form the array, save the settings and exit.
  10. On reboot press the delete key or F2 key when prompted to get to the BIOS menu.
  11. Check the boot sequence of your PC and ensure your optical drive is top of the list.image.axd?picture=bios-boot-sequence-options.jpg
  12. Insert your Windows 7 disk into the optical drive and exit the BIOS.
  13. On reboot press any key when prompted to boot from the optical drive.
  14. Windows 7 should start installing.
  15. Select your localisation settings and click next.image.axd?picture=localisation.jpg
  16. Click "repair your computer" and click the "load drivers" button.image.axd?picture=windows%207%20repair%20menu.png image.axd?picture=load-drivers-option.jpg
  17. Insert your memory stick and browse to the correct driver and install.
  18. Exit back to the Windows 7 install menu click "Install now" and on the next screen click "Custom (advanced)" to perform a clean install.image.axd?picture=install-windows-custom_thumb.jpg
  19. When you are asked where you want to install Windows 7 you should see that the 2 RAID hard disks are now visible as just 1 drive.
  20. Add a partition to the new drive so Windows with be able to recognise it.
  21. Continue installing Windows as normal.
Dec 04, 2010 | ASUS P6T7 WS Supercomputer Core i7 / Intel...
ON REBOOT, I GET AN ERROR MESSAGE "Cannot find disk.Press any key to reboot" HELP, PLEASE
ur boot seq in BIOS is not in the correct order
if u know how to enter BIOS then make the seq to boot in the foll order
1 boot - CD ROM drive
2 boot - Floppy drive
3 boot - HDD0 or HDD1 or HDD2 etc(in that order)
press save and exit BIOS and reboot
Jan 18, 2010 | Acronis Migrate Easy 7.0 (AME7)
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Start by simplifying the configuration. Disconnect the second IDE cable from the motherboard and disconnect the power to the DVD drive. Disconnect the SATA device. On the #1 IDE cable, connect the master drive to the connection on the end of the cable. Connect the Slave drive to the middle connection on the cable. Start the computer and press the key indicated to enter setup. Verify that drives are properly indentified as master and slave. If they are, shutdown the computer. Now add the IDE DVD drive to the end connection on IDE cable #2. It should be set as a Master drive. Start the PC again and go into setupand verify that the DVD is IDE #2 Master. Shut down the PC. Add the SATA device and start eh PC again. Go into Setup to verify that all of the drives are properly identifed. Restart the computer and let it boot into Windows. Open Windows Explorer to view the drive settings. If the drives are all present, but the letters are not what you want, click on START and then right click on MY COMPUTER and then left click on MANAGE. Under Storage click on DISK MANAGEMEN. The drives will all be displayed with their assisgned letters. If you need to change a drive letter, right click on the drive you want to change and select 'Change drive letter . . .'. Change it to a hight letter in the alphabet, then change the dive you want in the original postion to the now vacant letter. Finally change the original drive to the first available letter. Example: C:=IDE M1 D: E:=IDE S1 Change D: to H: then E: to D: and finally H: to E: they drives would then be: C:=IDE M1 D:=IDE S1 E:=IDE M2(DVD). Restart the PC and the drive should come up as you want them to be labled.
Good luck and please let me know how it works ouot for you.
Feb 26, 2009 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Feb 26, 2009 | Computers & Internet
Hard Drive Replacement on Notebook
your computer might not able to support this capacity i suggest calling the manufacturer for Hardware compatibility, if it does not recognize, then the bios might not be able to recognize this big capacity, updating to higher version of bios might help but sometimes not, it all depends on your motherboard config.
Sep 17, 2008 | BenQ Joybook 5100U Notebook
Maxtor diamondmax plus 9 6y080l0
IDE AND SATA CONTROLLER PROBLEMS ON MAXTOR DRIVES.UNINSTALL CONTROLLERS AND REBOOT,DO NOT PLUG IDE DRIVE IN.THEN REBOOT AGAIN PLUG IDE DRIVE AND LOOK IN DEVICE MANAGER IF DRIVE IS RECOCNIZED CORRECTLY.(ASUS BOARD) OR INTEL CHIPSET PROBLEMS.
May 20, 2008 | Computers & Internet
Upgrade Notebook hard drive capacity
hi there,
you Dell Latitude D610 can support large hard drives from 100gigs up to 250gigs ... but i very much think this is the limitation of your system bios if u are looking to go higer ... u might need to upgrade your system bios.....
Apr 07, 2008 | Dell Latitude D600 Notebook
Toshiba Qosmio G25-AV513 Notebook Logo
516 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
