Question about RCA R52WH73 Projection Television
My rca tv model no r52wh74 goes off after a few minutes and wont come on until about 10 minutes then goes back off again?
    Problem Solver:
  • 9 Answers
What the problem is here is you have a bad power supply or you need to do a hard reboot. On this tv to reboot you need to unplug it from the wall and leave it unplugged for about four hours if not you need a power supply
Posted on Nov 28, 2009
My RCA R52WH74 chassis # ITC222A wont turn on. The green power light comes on for about 10 seconds then shuts off. No picture, no sound. How do I fix it? Buying a new TV just isn't in out budget!
That model is famous for having issues with the deflection board failing. Replacing the deflection board should solve the issue. You can get replacement deflection board for the ITC222A chassis from www.tvrepairworld.com under the RCA circuit boards catagory.
Aug 05, 2011 | RCA R52WH73 Projection Television
RCA R52WH74 HDTV started black outs for 10 -40 minutes
This is a repair by service techanician and can solve by first check for dry soldering, if found resolder , but if otherwise replace the z-sustain board and then check all the fuses again .
Thanks for asking...
Hope this will help out ..
Jun 04, 2010 | RCA Televison & Video
RCA R52WH74 that will shut itself off
Replace 3 capacitors on Deflection board its the bottom left hand side cp150 200uf 16v use 25v capacitor and cp114 cp120 in same circuit 220uf 35v. You will see cap cp150 if it is puffed up on top they are Bad. Call Mats Electronis 1-800-628-1118 Radio shack might have capacitors.
Dec 29, 2009 | RCA R52WH73 Projection Television
My rca r52wh74 turns on for 10 secs then off.
was the storage unit climate controlled? If not then it's most likely due to heat and or humidity in which case I would suggest cleaning out the tv from the inside if you want to spend the time to do so but there is a good chance that the tv will need to be replaced.
May 31, 2009 | Televison & Video
Tv's green light comes on then off three times
On same Board that you replaced fuse Look at cp 150 if it is puffed up on top it is bad so replace cp150,114,120 one will be 2200u 16v
other 2 caps will be 220uf 35v With tv turned OFF Press and Hold Vol- and CH - at same Time on Front Panel board wait untill set comes on you should now be in Service mode Go to Convergence Try to aline convergence Do Auto converge
Feb 08, 2009 | RCA Televison & Video
RCA 52 inch
three strikes and it's out... rca does this, it is just showing it has tried 3 times for you and untill it is unplugged it won't try again.. you need to provide model #.. could be a few different things
hissing usually meens you have high voltage...that's good but then what don't you have?
ctc 169 - 179 could be high voltage divider... need more info
Oct 17, 2008 | RCA R52WH73 Projection Television
RCA R52WH73 Projection Television Logo
203 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
