Question about Samsung RS2630SH Side by Side Refrigerator
Loud sound coming from back of fridge. Pulled out from wall. sound like it's coming from the lower left corner when looking at it from the back. Looks like i'd need to take the lower panel off to inspect further. Hard to describe the sound it's making. Sound like a compressor or pump going bad of some sort. ??? Any ideas? The fridge is about 4 1/2 years old. Thanks- Rick M.
Hi Rick,
Sounds like the now infamous 'fan icing up' caused by a design fault of the fridge evaporator cover assembly & evaporator heater.Contact Samsung.You may find that these components are covered by by an extended 5yr. guarantee. Good luck.I was 30 days outside.
Cheers,
Ron Swift
Posted on Nov 22, 2009
Very noisy fridge, back wall freezing up
Possible bad freezer fan motor. I need more information such as brand and model number
Mar 10, 2014 | Samsung RS2630WW Side by Side Refrigerator
Loud humming noise
Happens when the bearings in the fan or compressor motor are getting worn out. make sure there isn't a piece of cardboard cowling or debris hitting the fan.
Jan 11, 2014 | Maytag MFI2269VEM 22.0 cu. ft. French Door...
Humming sound
Samsung states - A buzzing sound from your plasma TV is normal. It is caused by the electrical charges used to create the images on the screen. The buzzing, however, should not be so loud that you can hear it when the volume on the TV is set at normal levels.It is also important to determine the type of buzzing sound. A sound like a ground hum is completely normal. This buzzing can originate near the power cord connection or from the SMPS board position on the upper back of the TV. The buzz will be more audible as contrast increases on the screen, most notably when displaying an all white screen. If the buzzing sound is loud, you may have the Contrast set too high. Lower the contrast to reduce or eliminate the buzzing.You may also have loud buzzing if the rear of your Plasma TV is too close to a wall or other hard surface. Try moving your TV away from the wall until the buzzing is minimized. [1]
If the buzzing is at a higher frequency and resembles a crackling sound (like the sound of Velcro being pulled apart), and originates from the upper middle back of the TV, you likely have a failing SMPS board. Place a support call with Samsung to have the SMPS board replaced.FP-T5084 Have a known buzzing problem with a very simple fix.If the buzzing is coming from the left or right sides of the rear and the volume can be changed by pressing lightly on those locations, you are probably hearing the vibration of the grounding springs on the back panel. Call Samsung (or whoever) and have a technician confirm the problem. The easiest fix is to insulate the offending spring by applying some felt tape.
May 22, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
My Maytag MFD2560HES bottom fridge is making a loud humming noise.
Any time there is the sound of humming it is important to locate where the noise is coming from. Sometimes fans wear to a point that at one speed the sound as if humming. Sometimes compressors hum with more catastrophic results. Because your model is a bottom freezer it would be a good idea to open drawer to freezer and see if the sound is from fan in freezer or if pulled away from wall is the sound the fan or compressor area? I believe I will be able to locate a service manual but I will need you to help me pinpoint the location of the loud sound so we can get the sounds back to normal. Let me know if you are able to try that and what you find, Sea Breeze
Mar 23, 2010 | Maytag MFD2560HES Bottom Freezer French...
My refrigerator has a loud rattle in back when the compressor (i think) shuts off. when i pulled fridge away from wall i can simulate the noise by shaking what looks like an expansion tank. Sounds like a...
more than likely you probably have a bad compressor foot mount . It is a rubber cushion between the compressor and the refrigerator base frame. they wear out, allowing the compressor foot to contact the mounting base which would be metal to metal contract.
Mar 13, 2010 | Refrigerators
GE Fridge Motor Super Loud
Open the freezer door and see if the sound is there or if its near the floor. This needs to be corrected soon to prevent damage to your refrigerator. Your explanation makes be think the fan inside the freezer is loose or has ice buildup around the blades or the fan blade has become unbalanced in some way...Let me know and please rate me, Thanks, Sea Breeze
Jul 14, 2009 | GE Refrigerators
Loud vibrating sound with compressor starts up
remove the back cover and visually inspect the small fan under the fridge, chances are the fan or blade has become unbalanced or the mount has come loose or failed.
Jul 12, 2009 | GE Refrigerators
Every thing in our freezer is melting and the fridge is barely
take the back cover off and then clean the condenser coil on the unit. that will lower the head pressure whiuch in turn will lower the suction temperature.
Mar 28, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Kenmore Side by Side Refridgerator
it sounds like the compressor is short cycling,is it working at all?mike
Nov 03, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refridgerator freezer GE
Frost is due to outside air leaking into unit. Check on back wall to see if hole for ice maker fill tube is still plugged. If not and you have no ice maker cover hole with tape. Also look for water or ice build up in bottom of freezer or ref. sections. May have a plugged drain. Let me know what you find.
Nov 11, 2007 | Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
395 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
