Question about Kenmore 62602 Electric Dryer
Drum won't turn
I need information on how to replace a belt on my dryer. Serial #M35013485, Model #86545100
  • Anonymous Apr 21, 2008
    I get a buzzing sound when I pust the start botton and the drum will not turn, I don't beleave it's the belt. How do I get inside?
My dryer starts but the drum does not rotate and it shuts off.
Posted on Apr 13, 2008
Dryer turns on but drum won't turn
Remove the top to see if the belt is intact. If it is, you will need to replace the motor. Here is the motor to order.If the belt is broke, here is the belt to order.
The part comes with a 365 day, any part, any reason return policy.
Nov 11, 2012 | Dryers
The drum on our Neptune Dryer has stopped turning. It still heats up, but the drum just won't turn.
If the heater and blower work then th eprblem is with the drum turning system
This includes the motor ( which we will presume works because the blower does),the belt (Item #25 in the Cylinder, heater and bulhead diagram) and a spring and idler pully (Items 20 and 21 in the Base, Motor, and blower diagram)
Most likely problem is the spring broke releasing tension that halds the belt to the motor pully and drum. Second most likely is the belt has stretched.
You need to open the unit to determine where the problem lies.
Here are diagrams and parts listing for that machine.
http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Dryer-Parts/Model-MCE8000AYQ/3048/0151200?searchedModel=MCE8000AY&blt=
May 24, 2011 | Maytag Neptune MCE8000AY Electric Dryer
Dryer heats but drum will not turn
the drum belt is more than likely broken. To access this area you will need to remove the back panel of the drier and there the motor and the belt assembly is. Take the model and serial number to an appliance part house for the correct replacement.
Hope this helped
Dave
Mar 01, 2010 | Dryers
The drum has stopped turning in the dryer. How
well with no other information i would have to say its A belt
a very easy reapir
Oct 08, 2009 | Dryers
DRUM DOES NOT TURN
Try turning the drum by hand. If it spins easily with no resistance, the belt has failed. On the back of the appliance you should find a label identifying the Make, Model, and Serial Number. Take down all the information provided, and then find a local appliance shop that carries that brand. Order the new belt.
Sep 17, 2009 | Dryers
Model PYE2300 AYW the dryer turns on and provides heat but the drum does not spin
your belt has come off the drum or has broken. Take the model and serial number to parts house for replacement. The belt should be accessed through the back of the dryer. Good Luck on your repair. Make sure to disconnect electricty before removal of back.
Dave
Aug 05, 2009 | Maytag PYE2300AY Electric Dryer
I have a GE Dryer Serial #GL228541G Model DD25310 BAC WH. I am trying to replace the belt around the drum. I tried hooking the belt around the hooks to tighten the belt, but the drum is not turning.
Does the motor run? The path of the belt is a little tricky. You have to push a loop of the belt around the belt tightener and then over the motor pulley. The top of the belt loop will ride against either a rolling wheel, or a plastic guide made out of low friction plastic. The bottom of the loop of belt should only go over to the drum. The tensioner is held in place by a tab that fits into the bottom pan of the dryer.
Jun 24, 2009 | Dryers
Kenmore 62602 Electric Dryer Logo
89 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
