Question about Boxlight XP 5t Multimedia Projector
Cant get image on laptop desktop on the Boxlight XP5t-I plugged in the VGA cord into my laptop and into the Boxlight. Nothing.
  • 2,237 Answers
Reset the settings on the projector to factory default. the resolution may not match. then press either function-f4 or function-f7 (each laptop has different buttons to activate the external monitor port).
Posted on Jan 21, 2010
Why wont it power up ?
LAMP IS ONE OF THE PROBLEMS WITH THAT . NEED TO GET TO REPAIR SHOP TO BE CHECKED..
Jun 25, 2014 | Boxlight SP-9t LCD Projector
Vga hook up
may need to tell the laptop in the screen resolution settings to display the image on the tv instead of the laptop. Right click on the empty desktop of the laptop and go to either propertie or screen resolution and then make sure that the computer can see that the tv is hooked up and that the image is showing on the tv instead of the laptop. You may also need to change the mode on the tv to vga.
Nov 21, 2013 | Pioneer SD-532HD5 53" Rear Projection...
Desktop computer monitor goes black but works on other computers
It sounds like the resolution is set wrong. Go to the minimum and see if that solves the problem. If so keep working up.
Nov 25, 2012 | AOC V22 22" Monitor
Which cords and/or plugs should I use inorder to connect a projector to a computer
if your desktop doesn't have a standard vga socket then you can get a dvi adapter that fits onto the end of a vga lead. you will still need a seperate cable for audio as a dvi connection only does video.
Aug 02, 2012 | Computers & Internet
No image on projector screen from laptop VGA connection
On most laptops you have to select Function F8 to direct output to the projector or the projector and the laptop display.
May 07, 2012 | Dell Inspiron Mini 10 Notebook
Can you help with connecting a laptop VGA to a philips hdtv lcd (model #32pf7421d) with a component cable? The laptop recognizes that it is connected, but nothing comes up on the TV except for...
Check your laptop with the same VGA cord on some projector or a monitor. If it works there, then there is a problem with your TV's VGA switching circuit. If it does not work, then there is problem with either the VGA cord or laptop's VGA port. To rule out the possibility VGA cord , replace it with new one. Please give the feedback for this so that further diagnosis can be done, if you are comfortable with the TV's electronics.
Aug 09, 2011 | Philips 32PF7421D 32 in. LCD HDTV
I have an Acer aspire m3200. I tried to connect it to my hdtv, i got picture but no sound using the VGA cord, and got nothing using the HDMI cord. Please help
Using a vga cable to connect your laptop to a hdtv is very easy but the cable does not transfer the audio signal, you need another cable aswell. You need a 3.5mm jack to jack cable, one end plugs into your headphone socket on your laptop and the other end plugs into the pc audio socket at the back of your tv (usually next to where you plug in the vga plug).
May 28, 2011 | Acer Computers & Internet
I was told this would work from a laptop to tv but i cant find where or how to plug into laptop. what out and in should it be and what type of cord? do u have a manual or help list?
I don't really know what you mean but here's my answer:
laptop to TV can be done via VGA or HDMI, HDMI will give also send sound trough the cable to your TV.
both your TV and laptop must support one of these options or it will not work
here is what it looks like:
VGA : http://www.pc-helpforum.be/attachments/f184/2074d1243082457-live-voetbal-zien-via-laptop-naar-vga-kabel-mannelijk-mannelijk-.jpg HDMI : https://www.free-box.nl/images/HDMI_cable.jpg
most laptops should have VGA and most newer ones should have HDMI options
after connecting the cable you can hold windows + p for some basic options
ps: sorry for bad english
Feb 21, 2011 | Televison & Video
Can you hook the aspire one to a hd tv and use that for your moni
This is actually a really commonly asked question to me by friends.
Short answer, yes.
Most TV's have what is known as a VGA input on the back and this looks like a small trapezoid with a bunch of holes in a three row pattern. If you have ever set up a cord from a monitor to a desktop, the process is identical. Getting a double sided VGA cord (Almost always colored blue" with two male sides (meaning that it has the pins inside the little metal piece) and plug it into the back of your television. Next, plug the other end into your laptop, assuming it has a VGA output, and power on both pieces of equipment. Make sure that your TV's input is set to VGA or computer and that your computer is set to transmit a signal, typically done by hitting "FN" F5. Now both screens which transmit the same image.
I am not very knowledgeable about your specific laptop, but you may even have an HDMI port, which means you can just buy an HDMI cord and plug it into both systems.
I hope this was helpful and apologize if it is not.
Jul 15, 2010 | Acer Aspire One PC Notebook
Boxlight XP 5t Multimedia Projector Logo
Top Boxlight Office Equipment & Supplies Experts
jasbo
jasbo
Computer Links
Mike Charette
Are you a Boxlight Office Equipment and Supply Expert? Answer questions, earn points and help others
