Question about RELIANCE ELECTRIC WATER HEATER
How do you reset
I moved the water heater and now the lower heating element is showing no power going to it....we went and bought a new one thinking that was the problem..... but still no power to the lower element...but showing power to everything else...is there a way to reset it ?
    Sergeant:
  • 399 Answers
Press the reset button this should take it to high if no i belive your limit switch has gone bad please rate this answer good luck
Posted on Nov 20, 2009
End of my rope, tried everything I can think of.
check power from t-stats to elements
dont try any power without being full of water
elements will burn out
Nov 02, 2015 | Reliance 606 Series 40 Gallon Electric...
Water Heater Issues
An electric water heater contains two elements (usually upper and lower). Normally hot water is maintained at a certain temperature to assure an immediate supply. When hot water is turned on at the fixture, the second element is turned on to boost the temperature. From your description one of the heating elements may be defective or set to incorrect temperature.
Apr 28, 2017 | Water Heaters
Not getting 240 volts to lower element- have replaced lower element and both thermostats. get 120 on each leg to ground but no 240
If your top element is bad the the lower element will never turn on be cause the top element completes the 240 circuit. It is like a resister in a circuit. Make sure top element measures out at 13 ohms.
Dec 24, 2012 | Rheem MR50245 Marathon Electric Water...
BRADFORD WHITE 40 GALLON ELECTRIC WATER HEATER MODEL M240S6DS-1NCWW.. PROBLEM : I WAS ONLY GETTING A FEW GALLONS OF HOT WATER FROM HEATER. FIGURED ONLY TOP ELEMENT WAS HEATING SO BOUGHT TUNE UP KIT AT
Doesn't sound like its the dip tube, its a element problem, I would contact bw directly to see if heater is stil in warranty and they will send you new parts free.
Dec 18, 2012 | Bradford White M240s6ds-1ncww 40 Gallon...
I'm getting hot water for 2 minutes , then it gets cold
Most electric hot water heaters have two thermostats, one near the top of the tank and one near the bottom, and are covered by removable metal cover plates. The thermostats are pressed firmly against the bare metal wall of the hot water heaters tank.
The top thermostat usually has a high limit switch that will trip if the water gets too hot. When it trips it shuts off the electricity to both the upper and lower heating elements.
To reset the high limit switch there is usually a red button that you must press. When the upper limit switch trips it is often an indication that something else has gone wrong with the heater.
When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
Hope this helps out
Feb 02, 2011 | General Electric GE SmartWater Household...
The reset button has popped more then once.
You have electric water heater.
Electric water heaters are fully repairable by homeowner.
Reliance is AO Smith company
http://www.aosmith.com/OperatingUnits/Detail.aspx?id=138&ekmensel=c580fa7b_12_0_138_3
http://www.reliancewaterheaters.com/prod/elec.html
Age of Reliance water heater is shown on serial number located on side of tank:
first digit is letter. Next two digits are numbers: for example C06 means 2006.
Serial number also shows model number & wattage of elements in case you need new element from hardware store.
ECO reset button trips when upper thermostat senses temperatures higher than 150 to 180 degrees.
When ECO energy cut off trips, it turns off power at the reset button, so the tank does not continue overheating.
Tripping reset button says tank is receiving electricity, so we can eliminate that suspect.
There are 4 reasons why ECO will trip.
1) Bad upper or lower thermostat: solution replace both thermostats for about 25$. Steps shown in link below.
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
2) Loose wire or shorted wire at or near upper thermostat: Open covers on water heater and inspect parts for signs of high heat and burning.
3) Bad element shorted to ground in center of element: Solution test elements and replace defective element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-water-heater-element.html
4) Factory-installed insulation and cover has been removed from tank: thermostat exposed to cooler temperatures, and misreads tank temperature, and then elements keep heating water.
If you want to test all the parts before replacing anything:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Thermostats are generic, and each functions same way and each can replace the other.
Same is true for both upper and lower thermostats
Dec 14, 2010 | RELIANCE ELECTRIC WATER HEATER
Rheem 83xr52-2 50 gal residential water heater. Water temp was low. I cut power at electric panel, removed upper panel on water heater, turned up thermostat, replaced panel and switched power back on at...
You can open the top up again. I would not turn the temp higher than 130 degrees, maximum. However, there should be above the thermostat a red button. This is where the power wires connect to the thermostats and heating elements. Sometimes this button needs to be reset, press it and discern if you hear a click sound. This means that the high temperature safety switch has tripped open and you had to manually "reset" it. There are two thermostats by the way. The water heater usually works this way. There are two thermostats and two heaters. The upper tank heater turns on first and it heats the top half of the tank. Then when the thermostat above is satisfied it then allows the bottom heater to come on and heat the bottom half of the tank. You might want to set the bottom heater thermostat as well. This is made this way because it is actually faster and more efficient to heat the top half first and the bottom half secondly. Try this first with the reset button. We could check voltages, but that requires a level of knowledge and safety that I am not sure that you are comfortable with. Pictures of the upper and lower thermostats and connections will help if the "reset" does not do the trick. By the way, not meaning or implying anything, but did you move the thermostat in the right direction? Sometimes the dials can be confusing.
Nov 28, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Installed new upper & lower elements & thermostats, only top htr works
If original problem was caused by sediment burning out lower element, did you clean sediment out of water heater when changing lower element?
Two element water heaters are 240V.
Thermostats cut power on one hot wire, but 240V circuit has 2 hot wires. So lower element has power at all times coming from the red wire.
1) Use ordinary tester or multimeter set to 240V <> test each screw of lower element to bare metal part of water heater. Each screw should show 120V. If there is no power, then upper thermostat is defective, screw on upper thermostat is loose, or red wire between upper and lower parts of water heater is bad.
2) Remove wires from lower element. Use continuity tester or multimeter set to ohms <> test across both screws of element to see if power travels through element <> if element is bad, then continuity tester will not light up and multimeter will show no ohms. Put wires back on element after test.
3) Start with cold water in tank. Turn on water heater & upper element will turn on. Put ear on side of tank to hear if upper element is heating water. Test #3 screw to #2 screw on low left side of thermostat, should read 240V > Test #3 screw to #4 screw on low right side of thermostat, should read 0V.
Put ear on side of tank. When upper element turns off: Test #3 screw to #2 screw on low left side of thermostat, should read 0V > Test #3 screw to #4 screw on low right side of thermostat, should read 240V. If this test shows 0V and 0V, then upper thermostat is bad. If reading is correct, immediately move to next test.
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
4) Turn temp on lower thermostat to 150. Using ordinary tester or multimeter set to 240V <> Test across both screws of lower element. If there is no reading, and you know element is good from step 2, then lower thermostat is bad, or wire is bad between lower element and lower thermostat, or wire is bad between lower thermostat and top part of heater.
5) Test across both lower thermostat screws, should read 240V.If this test is good, it means wires are good. Put jumper wire across both screws of lower thermostat, and test lower element again. If element finally turns on with jumper wire, then lower thermostat is bad.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
If wire is bad between upper and lower parts of water heater, and water heater has tight-fitting 2" foam insulation, it usually indicates water heater replacement.
Sep 20, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
We just bought a new water heater and it's not heating up water.
The heating element was bad. It's hard to believe that a brand new water heater would have a burn element, but that's the problem. I replace the heating element and its started working properly.
Dec 01, 2009 | Whirlpool Water Heaters
RELIANCE ELECTRIC WATER HEATER Logo
99 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
