Question about Water Heaters
How to put music on a gpx mp3 player?
I have a gpx ML759B and when I sync my music on it and try to listen to it, it will not play it would say format error even with the album I can not listen to it can someone give me advice.
I can put the music on my mp3 player, but when i try to listen to the music it wont play it says HDS???. what is going on.
Posted on Sep 29, 2010
    Problem Solver:
  • 6 Answers
Make sure your music files are in mp3 format, if you are trying to load wma's or some other format the player may not support it. You can also try going to my computer and finding the player, right click and then format the disk, but this will wipe everything off of the player
Posted on Nov 20, 2009
Boiler working ok ? but the waters not getting hot
Check if you have a leak running all the hot water out of unit...
Do this by turning off all taps, and put ear against pipe... listen for running water.
http://waterheatertimer.org/Leaking-water-heater.html
.. another test: wait one hour without any water usage and check before and after water meter reading.
Jan 27, 2017 | Water Heaters
Water not going into well water tank
Is the pump running when power is ON?
Put ear against pipe and listen for pump.
Have you installed a check valve?
Check vlave lets water pass through the pipe and enter tank, but the valve closes after pump shuts off and keeps water from falling back down into well.
Aug 23, 2014 | Amtrol WX-302 WX-302 150S1, 86 Gal...
Hott mu730
Question posted under water heaters.
Do you have water heater?
mu730 appears to be a mp3 player. Buy another one if it's broken.
Jun 19, 2013 | Water Heaters
Water meter keeps running. When I turn off the water supply to the hot water tank the needle on the water meter stops, does that mean that I have a leak in the hot water pipe coming out of tge tank.
Yes you have a leak on hot pipe or TP overflow tube.
Put ear against pipe to listen for sound of running water.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#listen
If TP valve goes into drain line, check if water is running down TP overflow tube.
Check each faucet for leaks.
If pipes are under slab, put ear against each faucet to determine which faucet is closest to broken pipe.
Mar 23, 2013 | Water Heaters
Gas ignites flame but water is not getting hot
You have gas water heater with working burner.
But not getting hot water at faucet?
1) Bad faucet cartridge. Test for crossover. Copy following link:
http://waterheatertimer.org/Crossover.html
2) Is there hot water inside the tank? Open drain valve and check for hot water.
3) Drips and leaks: Turn off all taps and put ear against pipe and listen for water leak.
Water leak can run all the hot out of tank.
Dec 05, 2012 | Water Heaters
I have constant 24/7 humming noise (combi boiler i think) the boiler itself is not humming but seems to be in the pipes? mainly kitchen & upstairs, there is "hot spot" for the noise as you go...
If you turn the power off and it's still there then it's not anything electrical in the flat.. it could be transferred noise from another source. I would try locating the sound by listening through a tube to locate the sound more accurately. This method of sound source location is used by old fashioned mechanics listening for engine noises and is very good at finding them..
good luck !
Mar 30, 2017 | Water Heaters
Water Heaters Logo
99 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
