I have an element ELCHS321 32 flat screen tv and forgot the pw
I have an element 32 flat screen tv and forgot the parental code on it. How do i reset it instead of going through all 9,999 password codes
  • 395 Answers
SOURCE: How do you cancel parental control?
If you forget your password, simultaneously press and hold the MENU/
OK button on the front panel and VOLUME down button on the
remote for three seconds. This resets the password only and unlocks the
TV; all other settings in Parental Controls are not changed.
Page 48 of the manual.
Posted on Jan 14, 2008
dsacco86
  • 1077 Answers
SOURCE: Element 32'' LCD TV, has picture but no sound
The S-video cable doesn't have hookups for audio, only video. It's better than the video coaxial cable. But, you still need to hook up the right and left audio coaxial cables.
Posted on Feb 09, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: element 32" flat screen tv has cracked screen
Sorry to say, when the display is broken you're best off looking for a replacement TV.
There isn't any way to repair a cracked display except to replace it. You can try a Google search or check websites like shopjimmy.com that sell parts removed from junked sets. It's almost impossible to find replacement displays (unless you are a warranty servicer and get them right from the manufacturer) since most TV's are junked because of broken displays. And if you do find a display, there are still potential problems. Besides the cost (the display is the most expensive part, most of the set's cost), you need to be sure the display is exactly the same part as the one you're replacing. The same model of TV can use different displays depending on when and where it was made, and there may be differences in other parts in the set as well.
Posted on May 27, 2009
  • 132 Answers
SOURCE: how to reset the parental control code
This is what I found in the instruction manual on this and I posted it here for you. Try using 3355 for the code and everything else listed here. If that doesn't work, try the very last tip which tells you how to do a factory reset and repeat the first step using the 3355 as the code.
Here's the instructions from manual:
Parental Control
Parental Control allows you to block certain channels or programs so children cannot view
programs that are not age appropriate.
To enter the Parental Control menu, you need an
access code. The first time you enter, use access
code 3355. See "Setting an Access Code" on
page 33 for information on creating a new access
code.
You can set the following options to block
content:
• Channel Lock — Blocks selected channels
• Movie Rating — Blocks movies based on their rating (G, PG, PG-13, R, NC-17, and X)
• TV Ratings — Blocks TV shows based on their rating
• Block Options — Turns on or off all your parental control settings
NOTE: You can use Clear All to unblock the channels and programs that you have set.
NOTE: If the Block Control in the Parental Control menu is enabled, all the sub screens in POP (POP1,
POP3 and POP12) mode will be blank
Setting an Access Code m
After you enter the Parental Control menu for the first time, you can set your own four-digit access
code. If for any reason you lose or forget your access code, you can use the default code.
1 In the Parental Control menu, select Change Code.
2 Using the number pad on the remote control, enter a new access code.
3 Select Exit.
Reset the original factory defaults. Press Menu on the remote
control, select Setup, and then select Factory Reset
Posted on Jul 28, 2010
tvtek
  • 1284 Answers
SOURCE: I have Model ELCHS321 Element
If using cable with no cable box go into the Closed Caption settings on the TV and turn the TEXT mode off.
Posted on Sep 08, 2010
Forgot secret code to access restart
CLEARING THE SECRET NUMBER
If you forget the secret number, clear the secret number using the following procedure.
1 Select an item from the list below to display the secret number input screen. (For operating the on-screen
display menu, see page 17.)
• "EZ Setup", "CH Setup", "Parental CTRL" or "Reset" on the Setup menu.
• "Color System" on the Option menu.
• "Software Update" on the Digital Setup menu.
2 Press and hold both CHr and VOLk on the TV simultaneously until the message appears on the screen.
Jan 27, 2014 | Sharp LC52SB57UN LCD TV
Hisense H32V77C password reset
I couldn't find it anywhere in the service manual but you can try calling there support line. default is 0000 if that helps anyPhone: 1-678-318-9074
Fax: 1-678-318-9079
Jul 05, 2012 | Televison & Video
How to reset the parental control code - I forgot the code and want to reset with a new one
Parental Control
code.
content:
3 Select Exit.
Jul 28, 2010 | Dell W4201C 42 in. Plasma HDTV
Lock appear on Tv. Screen Blue. Sound audible
You Probably Need To Go Into Parental Controls And Change The Settings If You Forgot Your Code Go To Your Brand Name's Site And Find Your Tv User Manuel And Go Under Parental Controls
Hope This Helps = ) Tophee
Jul 16, 2009 | Sharp LD-26SH3U 26 in. LCD Television
I have purchased an element flat screen....problem is that there are no codes for an element...plz help cuz i love the remote!
Try finding out what parent company makes the Element. It should say it on the back of the manual. 1. Google the parent company 2. Find out what other TV they make. 3. Try the codes from the other TV the parent company makes. Good Luck. FYI, The parent company 90% of the time use the same parts in all their TVs. So the codes are mostly the same.
Jan 24, 2009 | Televison & Video
Overriding parental block code
If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Press and hold Menu on the TV AND volume down on the remote for 3 seconds. Nothing will appear on the screen, and the Parental Controls will unlock, and you can re-enter a new password with the LOCK PARENTAL CONTROLS
May 24, 2008 | Televison & Video
FORGOT PASSCODE ON TV PARENTAL LOCKOUT
that's a big problem. sometimes using the 0000 can unlock it but it's not 100 percent.try the trial and error.
Apr 19, 2008 | Mitsubishi CS-40503 TV
Tv problems
Valerie,
Thompson/RCA states: "If you forgot your password for this feature, press the following buttons on the remote, one at a time. (Note: You must be in the password entry screen) Press, Mute, Display,Clear and Reset, this unlocks parental controls and you can now re-enter a new password.
OR TRY THIS..
Let me know if that does the trick getting it unlocked..
Bill
Feb 04, 2008 | RCA TruFlat 27F520T 27" TV
Parental Code
OR TRY THIS..
Bill
Jan 30, 2008 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
137 people viewed this question
Top Televison & Video Experts
Electro Med Services...
