Question about Columbia All Sport Digi Watch - Men's
Columbia watch - set time
Day Light savings - time is off an hour on my watch - 4 buttons but can not figure out how to change the time ( buttons are SET, ST/SP, RESET, MODE) Any ideas would be appreciated
  • 3 more comments
  • Anonymous Nov 05, 2008
    reset time
  • Anonymous Nov 06, 2008
    ladies Columbia cl-5017 watch
  • Anonymous Mar 15, 2014
    My j ferrar watch doesnt have instructions so im not sure what the bottom clock is the top is for time and the bottom has a mode button and set what do I do is this for another clock ?
  • Anonymous Mar 17, 2014
    setting time,month , day
  • Anonymous Mar 18, 2014
    I can't set my 10 lap Columbia watch, when I hold the set button it just goes to something called offset
Hope this helps!
I found it finally!!!
Good luck, I hope this helps you!!!
Columbia by Fossil Customer Service Contact
Contact this seller Phone: 800-449-3056
Posted on Jan 11, 2008
Adidas digital watch adp6042 i have press something and now i have offset when i try to set time on the left top button. How do i get it back to normal? Please help
To set the time for Adidas - Model ADP 6042
1. Hold SET/LIGHT (upper left button) for 4 seconds.
2. Press MODE (lower left button) to select the option that you want to change.
a. light
b. chime
c. 12/24 Day format
d. hour
e. minute
f. second
g. year
h. month/day or day/month format
3. Press the START/STOP (upper right) and LAP/RESET (lower right) to change the value for the options indicated in number 2.
4. Press the SET/LIGHT to save all the changes made.
Source: Allan T.
May 21, 2014
Feb 28, 2013 | Adidas Watches
How do you change the time setting to 24 hours?
  • Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
  • Step 2 Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
  • Step 3 Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
  • Step 4 Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
  • Step 5 Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
  • Aug 17, 2010 | Columbia All Sport Digi Watch l
    How do you set this watch....4 buttons
    SETTING THE TIME AND DATE ON AN OLD 4 BUTTON DIGITAL WATCH
    [L1] [R1]
    [L2] [R2]
    SETTING THE TIME.
    Press [L2] to move through the modes. When the time display flashes, you are in the correct mode to set the time. The hours first, then the minutes and seconds.
    Press [R1] to advance the numbers, [R2] to go to the next.
    Press [L2] to save your settings. [L1] is not used; it's the light.
    SETTING THE DATE AND DAY. After setting the time (seconds flashing) push [R2] to move though time, backwards, to date, [R1] to set day, [R2] to move to month [R1] to set the month. Push [R2] to get to the day of the week, then [R1] to change. [L2] to end.
    Jul 26, 2010 | Fossil JR9455 Watch
    How do i change the time on a columbia CL5055 its set an hour behind and i can not change it to the correct time!!!
    hold down the set button until the display flashes. You may then cycle through the modes and fields to be set by pressing the mode button. The opposite two buttons (strt/stp / clr) are used to add or subtract to the field that is flashing or in set mode.
    Sep 18, 2009 | Columbia All Sport Digital watch
    How do i set alarm on a gap sport watch?
    For setting Time & Date...
    1. Push "MODE" button three times (change Mode to TimeSet)
    Time -> StopWatch -> AlarmTimeSet -> TimeSet -> Time ->...
    2. Flashing Second Number Digits
    3. Push "RESET" to select...
    Second -> Minute -> Hour(12hr<->24hr) ->...
    Date -> Month -> Day of Week -> Second -> ....(repeat)
    4. Use "START" to set each item...
    For setting Alarm ON/OFF
    1. Push "RESET" button then Push "START" same time...
    Alarm ON -> Alarm OFF -> ... (repeat)
    Jan 09, 2009 | Columbia All Sport Digi Watch l
    How to set time on columbia cl-5008 watch lost manual
    Press and hold "set" until the "Chime" screen comes up.
    Let off "set" and then press "mode" - This will take you to the clock. adjust the numbers by using "st/sp" and "reset". Use the mode button to cycle through the hour, min, sec and date.
    This was a pain in the **** until I figured it out.
    Nov 10, 2008 | Columbia All Sport Digital watch
    Vestal G5 Global Traveler watch
    THE REAL SOLUTION:
    1. Hold down (light/el/set--the top right button) for 2 seconds to enter real time setting mode. 2. Press Mode key (bottom left button) to skip around to the different setting items. 3. Press Reset (top left button) to lower a setting. 4. Press ST/SP (bottom right button) to advance a setting (like increasing the time). 5. The day of the week will show automatically if you were correct in setting the year, month, date, and local city.
    Apr 19, 2008 | Watches
    Timex 1440 sports digital watch time setting
    1. Press and hold the mode button until it starts to blink, then release.
    2. First the alarm time will come up.
    3. Press the mode button once to get to the time and date.
    4. The seconds will flash first.
    5. Press the st/stop button to toggle between the seconds, hour, minutes, date (month and day) and day of the week.
    6. Press the lap/reset button to change the values.
    7. When done, press the mode button again to return to normal.
    Mar 09, 2008 | Timex 1440 Nylon watch
    Columbia Watch CL-5030
    Hold the light button (top left hand) for a few seconds and the adjustment mode becomes available.
    Dec 25, 2007 | Columbia All Sport Digital watch
    How do I change time on timex watch?
    These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
    These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
    TIME AND DATE
    1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
    2. Press ADJUST to set SECONDS to zero.
    3. Press START/STOP to select MINUTES.
    4. Press ADJUST to change.
    5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
    6. Press MODE when done.
    7. To display DATE from Time display , press START/STOP.
    8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
    9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
    ALARM AND HOURLY CHIME
    1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
    2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
    4. Press ADJUST to change.. Press MODE when done.
    5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
    CHRONOGRAPH
    1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
    2. With time displayed, press MODE to select Chrono Mode.
    3. Press START/STOP to start.
    4. Press ADJUST to view lap time. Press again to sesume lap timing.
    5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
    6. Repeat for successive laps.
    Have fun! - Not a bad watch for the money! - - Silver Bullet
    Mar 16, 2007 | Timex 5B841 Wristwatch
    Watches Logo
    1,759 people viewed this question
    Top Columbia Watches Experts
    Marvin
    Marvin
    Ansel Alberto
    Ansel Alberto
    Are you a Columbia Watch Expert? Answer questions, earn points and help others
