Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Flashing red lights as trys to turn on
I tried to turn it on while holding the MENU AND DEVICE buttons.
the power lamp flashed a 12 (maybe 21, but probably 12)
reset button clears red flashing lamp but repeats if I try to turn back on.
replaced the lamp, but to no avail
  • pawned Jan 11, 2008
    I called Costco and inquired about the problem.
    I told them that I had replaced the bulb 3 times so far, also.
    The girl told me that if I had called them they would have sent me the bulbs.
    But for this problem, I bought the set 2 years 25 days ago.
    She told me to take it back to the Costco warehouse where I bought it and they will take it back under the 100% satisfaction guarantee.
    They MAY only give me a credit towards a different TV which is fine and dandy to me
    Surprised the heck out of me
  • robert landry May 11, 2010
    I can't anser this I don't know enough but sound like it is convergence shouting down your system . These or probroly the stk394-510 ic's. Replace them only with sanyo parts, don't truss the cheap version.
    Also may be a burt pico fuse, I've seen this this or for the supply for the convergence ic's look for 4 amp pico.
    Just to let you know I have alway's find the mitch, tv's the best in all there design this is what I have at home upstairs and downstars..
    What About Bob
    rlandry@vianet.ca
    Novelist:
    Scholar:
  • 96 Answers
Hi again, ok so you have a lcd rear projection, not analogue ptv, I appolozine it's not convergence, this problem may have several problem, first witch the info I read I don't know but does keep burning the bulb, I have run info a problem were it over heats and the bulb keep burning after about 600 hr's or 6 mounts, I hve found a bad colling system, or a bat termal shoutdown termistor on the bulb heat cassing. I also encounter bad cap's but was not the cause for buning the bulb.
Regards
Bob
ps when posting a problem please specefied model, problem history and what type of projection, crt, lcd, plasma, dlp, etc..
Posted on Jan 19, 2008
  • 24 Answers
Dlp tvs Do Not have convergence I/cs....Sounds like the caps on the power board have swelled and leaking.
Posted on Jan 11, 2008
We have a Mitsubishi TV model# WD-60735.. we have changed the lamp because it was flashing red but now its flashing yellow and the tv will not turn on..
Mitsubishi TV troubleshooting
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Nov 18, 2015 | Mitsubishi Televison & Video
Flashing light mean yellow
Jan 15, 2014 | Mitsubishi WD-60737 60 in. HDTV
Starting light flashes green, and then red. Turn off and on several times.
Possible lamp but:
Nov 07, 2012 | Mitsubishi WD-65733 65" HDTV
My mitsubishi flashes a red light what does that mean
Red light is usually lamp indicator---may be time to replace the lamp--they have a 2000 hour life span except for generic ones which last half that long----when was lamp last replaced? also the set does have a self check:
Oct 30, 2012 | Mitsubishi WD-60737 60 in. HDTV
RED FLASHING STATUS LIGHT
Possible lamp failure but lamp light not status should blink-I have suggestions but want you to try the self check first--if set has been unplugged plug it up and turn on and when it fails:
Mitsubishi TVtroubleshooting
Here's something that might also be useful. After you turn on the set, and getthe regular red blinky lights, hold down the Device and Menu buttons togetherfor about 5 seconds.
33 = Air filtercover is open.
44 = DVI cablebetween FMT and Engine disconnected
Jun 11, 2012 | Mitsubishi WD-62525 62" Rear Projection...
We have a mitsubishi WD-62525 tv and we turned it on and after a while it turned itself off and then we got a continiously flashing red status light! what does this mean & what do we need to do to fix...
Mitsubishi wd-73739 turns on then turns off with a red constant led
The set has a self check--try this(posted by another expert here):
"Here's something that might also be useful. After you turnon the set, and get the regular red blinky lights, hold down the Device andMenu buttons together for about 5 seconds.
44 = DVI cablebetween FMT and Engine disconnected"
Jun 03, 2012 | Mitsubishi Televison & Video
Timer is lock replace bulb
This set has all kinds of problems--
try the self check:
Jun 01, 2012 | Televison & Video
Mitsubishi dlp tv model wd-62627 wont power on when i plug tv in green light flas then will stop then i try to power on tv after after green light stops flashiing after oabout 30 sec red lamp light co
Inspect the lamp first to see if shattered--set has a self check feature also:
May 30, 2012 | Mitsubishi WD Televison & Video
Red flashing status light
Press and hold the "Device" and "Menu" for 5 seconds and see what code comes up....... 12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Apr 03, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
42 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
