MY UNIT IS NOT STARTING. I SUSPECT THE DRAFT INDUCTION MOTOR IS SHORTED OUT. BUT I WANT TO BE SURE. THE BOARD IS FLASHING A CODE OF SIX FLASHES. I NEED TO KNOW WHAT THIS MEANS.
  • don_construc Nov 20, 2009
    THIS UNIT IS A BRYANT GAS PAK, MODEL# 582ANW030060AAAD, SERIAL # 3500G14267. WHEN THE THERMOSTAT CALLS FOR HEAT, NORMALLY THE FIRST THING THAT SHOULD HAPPEN IS THE DRAFT INDUCTION FAN MOTOR SHOULD START. IT SIMPLY HUMS, WHILE THE BOARD IS FLASHING A SERIES OF SIX FLASHES EVERY THREE SECONDS.
  • 3,051 Answers
Hello there There is several reasons why a air conditioner will not work please read the following troublesooting steps and i thnk you will see what i mean ok Best regards Michael Air Conditioner Troubleshooting - Troubleshooting Air ... Air Conditioner Troubleshooting To properly troubleshooting air conditioners one ... HVAC Air Conditioner Troubleshooting Page Quickpage Jump links: ...highperformancehvac.com/air-conditioner-troubleshooting.html - Cached Tag:air conditioner troubleshooting Tag:air conditioner troubleshooting. Troubleshooting Heat Pumps ... Our temporary air conditioner and heating system reviews site is up and running. ...highperformancehvac.com/component/option,com_tag/... - Cached
Posted on Nov 20, 2009
  • Michael Thomas
    Michael Thomas Nov 20, 2009
    Hello there again:
    can you tell me if the codes that are flashing have any numbers or letters on them
    cause if the inducton motor is just humming it may be either not getting enough electric impulse
    from a diode or circuit on the controle panel board like a start relay or like you said the motor itself may be bad or has got a lot of dirt and debris around it and it could be stuck ok
    best regards MIchael
Coleman Evcon Furnace. Why do I keep getting three flash code?
You might try viewing this YouTube video which shows a way to unstick the pressure switch. https://www.youtube.com/watch?v=Wc_oFIL2aRY
Nov 28, 2015 | Heating & Cooling
Furnace will not ignite.
I think you are talking about draft induction pressure switch operation. Make sure the metal orifice located on the draft induction blower is clear. To check, remove the rubber tubing end at the pressure switch and blow into the tubing. It should be easy to blow through it. If it is plugged, remove the tubing from the blower orfice and use a paperclip, inserting it into the orfice to clear the opening. After repairing, and all is hooked up, retry the furnace start up procedure. If the code comes up again, replace the pressure switch.
Dec 17, 2014 | Goodman Manufacturing...
Unit will not lite
Look on the circuit board, is ther a flashing diagnostic code?
tell me this code sequence.
Typically an induced draft motor will be the first thing to run, is this running? is the pressure switch for the induced draft operating, it its tubing and the tubings ports clear?
is the condensate line clear?
is the flame sensor clean? use 0000 steel wool to wipe it off.
Jan 22, 2013 | Rinnai E75CN Condensing Boiler
Error message on my electrolux INDUCTION STOVE TOP
Hello - Typically error code E on Electrolux induction cook top indicates an error with the user interface board/control board. Contact a professional to move forward accurately and properly diagnose/repair the unit.
Oct 30, 2012 | Electrolux ICON Designer Series E36IC80ISS...
Ok, I checked both rollouts, primary limit, and aux limit switches...all normally closed. I checked resistance on the draft induction motor and got around 2 ohms. LED on control board steady on for normal...
Hello, check to see if you are getting a 120 volts at the motor, if no voltage then the control board is bad. Make sure tje door switch is taped down when checking. Also, check for 24 volts on a call for heat at the w and c terminals on the control board, if you have voltage but but motor does not run also indicates a bad board
May 02, 2011 | Heating & Cooling
I turn my thermostat to the HEAT position, I hear the Thermostat click and the Furnace begins to hum but no air comes out of the vents. Also if i turn the fan to the ON position air will come out of the...
need to go to furnace and watch it...if your hearing a hum the enducer draft motor may have failed...it should start first if there is no fault codes...reset unit by unplugging furnace or in some cases turning power switch off...turn thermostat on heat and watch unit ..the small enducer draft motor should start first the a ignitor glows and the should light...goodman units have a control board with a light on control board when it fails should flash a code and on the door or inside on lable should give you what that code is...hope this helps good luck
Jan 07, 2011 | Goodman GMS90703BXA Heater
My furnace is flashing 21 green and then it flashes red ...the furance will not run . I have replaced the thermostat and cleaned tha condensate drain
not sure what 21 is ,but if you are getting acode normally the code comments are on the door or the manufacture lable to tell you what they are...
i can tell you the operation and maybe that will help you out...
the unit should start off with the enducer draft motor small motor in furnace that pulls all the stale air out..then the negative pressure switch activates which should have a hose coming from the enducer draft moto to the pressure switch..once the pressure switch closes it sends power to the ignitor and the ignitor should glow once it gets hot a milivolt current is sent back to the gas valve and it opens up and fires...after it fires you should have a flame sensor small metal rod in the direct path of flame that keep sensing the flame and sends signal back to board.... unplug unit and watch it start where is it failing or in what part of the operation does it flash a code....
Jan 03, 2011 | American Standard Heating & Cooling
Need help with a goodman gmt070 furnace...error code flashes three times, i have replaced pressure switch, still flashed, replaced board, still flashes three times...flue is clear, draft inducer motor is...
it may be clogged at the barbed fitting on the induced draft motor where the pressuer switch tubing connects. take a paper clip and **** it out make sure you can stick it thru freely till you can feel the Inducer wheel then reconnect and try again.
Nov 04, 2009 | Heating & Cooling
Induction Motor continues to run.
pull the rubber hose off the pressure switch. and blow into the Induced draft motor housing if you cant you can pull the hose off the IDM and try to clear it with a small paper clip. reconnect and try again. you can also get the flash code off the board while the unit is running but not working.
Dec 11, 2008 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
464 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
