Question about Epson Perfection 3200 Photo Flatbed Scanner
Image missing When we scan an image the result only shows half of the original image as if it has been cut cleanly with a knife
  • juni1 Jan 11, 2008
    The full light is on for the full travel of the bed
  • Dean Joly
    Dean Joly May 11, 2010
    Does the light from the scanner travel the whole way when you scan or does it get stuck?
    Master:
  • 788 Answers
In order to determine if the problem is related to the scanner or to the software installed on your computer I would try your scanner on another computer. If it does the same thing then the scanner is faulty.
Posted on Jan 11, 2008
6ya staff
SOURCE:
Bizhub C652 has horizontal lines.
its important to find out whether the \'lines\' are in scan direction/ or only through Radf or only from scan glass,
if the lines are only showing when documents are fed throught the Radf, then the problem lies with the document scan plate( left of the main glass platen (about 2" in width)) or with the scan plate blade cleaner
if the lines ONLY appear when copying from the Glass then the issue lies within the optics (probably nothing more than a clean will be needed)
another question would be to ask if the lines are solid (black line overprinting image) or if they are \'missing\' lines where the image has failed to copy, sometimes it can be hard to work out which side the fault lies,so try shaded greys as a copy original .
if the scan lines are appearing on both Radf and Glassplatten ,mode then the issue may be dirty optics/ccd sensor or it could e an indication of the ccd failing or image control pwb in error while interpreting the image file.
what to do
1) place a grey sheet of paper in the Radf and have the copier photocopy both sides of the original and print to single sided sheets ( so the printer turns the original over to complete the task)
observe the result.
2) have the copier photocopy directly from the platten glass- single sided.
observe the result.
ckeck to see if the error has appeared on both sets of prints ,
if the error has only appeared in the first set of prints then the issue may be a tiny DOT on the slit glass (left of platten) - a dot on this glass will indeed appear as a Line as the original is scanned across the glass.
hhope thhis helps
Feb 19, 2014 | Konica Minolta Bizhub C652 Color&b/w...
SCANNER DOESNT SCAN ALL OF THE IMAGE
If the scanner is connect to Surge protector, try connecting the scanner to wall outlet. Also turn off the scanner and Clean the Scanner glass with lint free cloth
Regards,
Seans
Feb 26, 2013 | HP LaserJet 3055 All-In-One Printer
I have a Ricoh Aficio 1013 that prints fine but copies are unclear and off
Problem Cause Solution Colored lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About this Machine . Copies appear dirty. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies appear dirty. Auto Image Density is not selected. On the control panel, select [Auto Density]. The reverse side of an original image is copied. Image density is too high. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . The reverse side of an original image is copied. Auto Image Density is not selected. On the control panel, select [Auto Density]. A shadow appears on copies if you use pasted originals. Image density is too high.
  • Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference .
  • Change the orientation of the original.
  • Put mending tape on the pasted part.
The same copy area is dirty whenever making copies. The exposure glass, scanning glass, or ADF is dirty. Clean them. See "Maintaining Your Machine", About This Machine . The same copy area is dirty whenever making copies.
  • The original that has already been printed is scanned.
  • Original Type is set to [Text / Photo], and an original with text and photographs that can hardly be distinguished from each other is loaded.
On the control panel, press [Generation Copy], and then begin copying. Copies are too light. Image density is too light. Adjust the image density settings. See "Adjusting Copy Image Density", Copy and Document Server Reference . Copies are too light. A light copy may result when you use damp or rough grain paper. Use recommended paper only and be sure its storage environment meets the recommended temperature and humidity conditions. For details about recommended paper and the proper way to store it, see "Recommended Paper Sizes and Types" and "Paper Storage", About This Machine . Parts of images are not copied. The original is not set correctly. Set originals correctly. See "Placing Originals", Copy and Document Server Reference . Parts of images are not copied. The correct paper size is not selected. Select the proper paper size. Parts of images are not copied. Even if you place originals in the ADF correctly, margin of a few millimeters on all four sides of the original might not be copied. Use "Create Margin" function to reduce the image of its original size.
For details about missing image area, see "Missing Image Area", Copy and Document Server Reference . images appear only partially. The paper is damp. Use paper that has been stored in the recommended temperature and humidity condition. For details about the proper way to store it, see "Paper Storage", About This Machine . Black lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The exposure glass or scanning glass is dirty. Clean them. See "Maintaining Your Machine", About This Machine . White lines appear. The dustproof glass is dirty. Clean the dustproof glass. See "Cleaning the Dustproof Glass", About This Machine . Copies are blank. The original is not set correctly. When using the exposure glass, face the originals down. When using the ADF, face them up. A moir? pattern is produced on copies. Your original has a dot pattern image or many lines. Place the original on the exposure glass at a slight angle. Black spots appear on the copy of a photographic print. Because of high humidity, the photographic print has stuck to the exposure glass. Place the print on the exposure glass in either of the following ways:
  • Place an OHP transparency on the exposure glass, and then place the print on the OHP transparency.
  • Place the print on the exposure glass, and then place two or three sheets of white paper on it. Leave the ADF open when copying.
White stripes appear on the OHP. Fragments of paper are stuck to the OHP. Use a dry cloth to wipe any paper fragments off the back of the OHP. The image on the back side of duplex copies has mottled blank patches or is smudged. Missing patches and smudges are caused by moisture leaking from the paper.
  • Do not install the machine in areas that are susceptible to low temperatures.
  • Use paper that has been stored where temperature and humidity conditions meet the limitations we recommend. For details about the paper storage conditions we recommend, see "Paper Storage", About This Machine .
  • Install the Optional anti-humidity heater. For details about the anti-humidity heater, contact your service representative.
When You Cannot Make Clear Copies
Feb 02, 2018 | Ricoh Aficio 1013 All-In-One Laser Printer
How do I scan with HP psc 1210
Answer is on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&lc=en&dlc=en&cc=us&product=90764#N305
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 24, 2011 | HP PSC 1210 All-In-One InkJet Printer
We have a Canon Scanner Canoscan N124OU. We have
hey try to crop it, once the scan image is been previewed the sides of the scanned image can be resize, try to resize it by using your mouse.
Oct 25, 2009 | Canon CanoScan N1240U Flatbed Scanner
Scanning an image only gives a scan 1/4 the size of original...
if u mean the size of image is reduced, as i know, the resolution of image, dpi, is too small --> try bigger dpi
if u mean the image is cut off, u have to clear the scan area or by default
May 07, 2009 | HP Scanjet 5470c Flatbed Scanner
Scanning OLD Negatives - old browning? Scanner is cutting half
you better not used the automatic detection of the pictures, it never works fine
Dec 08, 2008 | Epson Perfection 4490 Office Flatbed...
Trying to convert slides to digital images
to scan a slide is difficult, and it is alomst impossible to get a clear image. since slide needs intense light to show a clean image. the scaners' light bar just not enough light to reflect back to get a clean image.
you may get the same result if you take them to a professional for conversion.
I don't have any suggestion at this time.
any one???
Oct 31, 2008 | Office Equipment & Supplies
PSCAN shows up on my tv screen when I try to watch movies. How do I delete this?
The solution to the PSCAN! (half screen cut image) is just as suggested, turn off the progressive scan switch in the back of the DVD player to get the full image and enjoy your movie.
Dec 26, 2007 | Memorex MVD2040 DVD Player
Epson Perfection 3200 Photo Flatbed Scanner Logo
80 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
