Question about John Deere Model 440 Crawler Tractor Puzzle
I have a j.d. 440 crawler . it takes about 20 seconds after the clutch is released for it to travel. seems like it is not getting any oil to the drive. i have the forward and reverse shift on the left hand side. is there a oil filer or some thing to restrict oil flow
    Problem Solver:
  • 6 Answers
That IS a problem, are there ANY noises,clicks, crunches, or slight jerking on the reverser lever? what about reverse mode,, same problem? there are 5 different clutch packs on that drivetrain, so we have to eliminate 1 by 1. ask this... does it loose power when moving, and under load?(main clutch) or when turning(steering clutches) or going from fwd to rev ,, and in each of the gears(trans.)
Posted on Nov 23, 2009
Clutch biting point very high on peugeot 206sw 1.4dhi it it about to fail
The reason for the high biting point is simple. The clutch is made of 3 main components.
The pressure plate friction plate and the release bearing.
The more times clutch is depressed the concentric spring fingers wear in 2 ways . Firstly by good old metal to metal rubbing and secondly the concentric spring fingers don't return as far as a new one causing the release bearing or csc to adjust .
When the pressure plate concentric spring gingers wear they don't sit proud and require more pedal effort to depress. .
When they loose there spring like feature they require a greater distance from the release bearing. Or it has to travel further to depress them to lift The pressure plate and fee the friction plate from the lay shaft on which it is splined onto to give you drive once released.
The further back the bearing has to travel to allow the fingers to clamp the pressure plate to the friction plate . The more the clutch has become worn and unserviceable.
Self adjustment on hydraulic clutches are a hard one to gauge as you have no idea how far the piston has moved out to compensate for this wear . With a cable you can physically see the wear and adjust .
High biting points on any car are useless. You want a biting point to be 2 to 3 inches from the top and not nearly level with the brake pedal.
Anyway it seems apparent that Peugeot and Citroen both have high to almost no point at which they bite .
I myself would modify this as an engineer.
But it seems to be normal on these cats to have absolutely no biting point worth talking about.
My sisters 2012 206 1.4 is a very high biting point and I myself would not be happy with it . It gives u no indication of a worn clutch if its self adjusting.
Alll hydraulic clutches are self adjusting. So why are Peugeot and Citroens sooo high. Its ridiculous.
A very idiotic idea and I'm taking it back with her and I'm complaining. Hopefully I should get somewhere and ill update you all
Jul 02, 2012 | Peugeot 206 Cars & Trucks
Need instructions on how to install clutch cables on a 02 fxst
First, you have to drain the oil from the transmission by removing the plug located just below the chrome plated clutch release mechanism on the right side of the transmission. Then, take the bolts out of the clutch release mechanism and pull it away from the transmission. Disconnect the link from the clutch release ramp and the clutch lever at the handlebars. Unscrew the clutch cable from the clutch release mechanism. Reinstall the clutch cable in reverse of the way you took the old one out. Refill the transmission with 20-24 ounces of transmission lube.
Good Luck
Steve
May 08, 2011 | Harley Davidson FXST Softail Standard...
Clutch pedal travel is excessive. Sits about 2"
A clutch pedal takes MUCH more travel to function correctly, when compared to a brake system...
A clutch needs to be replaced (maybe) when it SLIPS, Chatters, Or fails to release...
Other than that, the clutch will need to be adjusted to allow for total release of the relese bearing when pedal is released, and full disengaugement when pedal is depressed....Have a mechanic look at the adjustement, as proper adjustment gives longer clutch life. This is a periodic adjustment item.
Apr 03, 2011 | 2001 Subaru Impreza
C90 clutch- takes almost all of the clutch lever travel before cluch starts to engage. Can this be adjusted?
the only adjustment is on the clutch lever, it has 4 positions with numbers 1 is most contact less travel and 4 is less travel to release
Jan 20, 2011 | 2005 Suzuki Boulevard C90
How to check oil level on my 03 yz 250
Checking the oil is easy. Changing the oil and filter is a bit more complicated. I am giving you a website where you can do a free download of a factory service manual. Go to this site >
www.carlsalter.com/motorcycle-manuals.asp The site may take up to 20 seconds to fully load all the manuals available. Yours is in the list. Go to section 3 pages 13 to 17. Below is one of the diagrams.
Oct 25, 2009 | 2003 Yamaha YZ 250
How do i check if it needs oil on the manual transmission because the shifts are hard to change when running or is there something else to do beside a new clutch already done
Hard shifting may be caused be the clutch not releasing properly.If you have a new clutch your problem might be caused by your hydraulic clutch release system.When stopped and idling you should be able to shift gears without grinding.Reverse grinding may indicate a clutch release problem.You should have some clutch pedal travel up from the floor before you feel it engaging.The oil fill check is either at the speedo or a plug at the axle shaft level.Be sure to use factory recommended fluid.Gear oil is not a proper fluid.
Oct 17, 2009 | 1997 Pontiac Sunfire
I have an Echo CS-440 18" chain saw and the chain came off. Now that I have put it back on, it won't move either by hand or when the engine is running. Help
OK.  This is simple. Either the chain brake is engaged or the chain is too tight. Start by pulling back on the chain brake toward you.  There should be a "click" if the brake was released.  If the chain is still immovable, try resetting the chain tension. 1. remove the spark plug wire 2. loosen the two clutch cover nuts 3.hold the bar nose up and loosen the tension adjustment screw until the chain moves freely without becoming loose. 4. tighten both clutch cover nuts with the bar held up. 5. Pull the chain around the bar by hand.  Loosen the adjustment if you feel tight spots. 6. When the chain is properly tensioned,tighten clutch cover nuts securely.  Do not overtighten! 7.  Check chain brake operation and release. 8. Replace spark plug wire and operate  saw.
Hope this solution will Fixya.
Jan 10, 2009 | Husqvarna Chain Saw 20" Bar
Clutch slipping
first i would try adjusting the clutch cable because commonly people with think that they're clutch is going out when really just the cable has gotten stretched....try adjusting that first and if that works then you should be fine for another couple thousand miles but if you want to not have to worry bout it for awhile i would just replace teh clutch assembly....usually ranges from $200 to $450 depending on the clutch set and the mechanic that does the work for you. Let me know what happens. :)
Oct 01, 2008 | 1990 Peugeot 405
Front wheel Drive query
DEar Customer,
your from is that your car is front wheel drive & you have to reset your car clutch point that loose its sensitivity as they had before,
its not a big prib you have to open bonet than make more active clutch wire with streching clutch joints.
THNX
May 17, 2008 | 1991 Peugeot 405
John Deere Model 440 Crawler Tractor Puzzle Logo
425 people viewed this question
Top John Deere Toys Experts
Colin Stickland
Colin Stickland
J.D. Browning
J.D. Browning
john h
Are you a John Deere Toy Expert? Answer questions, earn points and help others
