Question about Cell Phones
How do i clear my voicemail? phone shows a
How do i clear my voicemail? phone shows a voicemail but there is no voicemail when called!
Voicemail button redirected to phone line
If, perhaps you mean "it rings another one of our..." Phone Extensions, then just press the illuminated red message button, go to the ringing phone (the extension number will appear on your phone if you have a display phone) and answer the call by lifting the phone off-hook, then hang it up. Now the message button on your phone will work normally. What happened was that the user of the phone that was ringing when you pressed the button had inadvertently left you a "message waiting" after they called your phone on the intercom. By pressing the message button on your phone, you returned their call, and by answering the return call, you cleared the message waiting indication on your phone. There can be more than one message waiting, so if the light is still on after you clear the first call, using the procedure above, do it again and again until each call is returned, answered and cleared.
Mar 04, 2015 | Panasonic KXDT343 Phone
How to delete voicemail
You apparently have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Mar 29, 2014 | Uniden DECT 6.0 Cordless Phone ID
How do I set up voice mail
Call services From your phone, you'll be able to access and change the settings of various call services for your phone.Contact your mobile operator to find out about the availability of call services. From the Home screen, press MENU and then tap Settings > Call. Fixed Dialing Numbers Restrict outgoing calls to a fixed set of numbers. To enable this feature, you must know your SIM card's PIN2 code.
Voicemail service Shows the current voicemail service being used.
Voicemail settings Specify another voicemail number aside from the voice mail number on your SIM card.
Clear voicemail notification If you have a notification of a new voicemail, you can clear the notification with this option.
TTY mode Enable this mode to connect and use a compatible TTY device with the phone.
Hearing aids Enable HAC (Hearing Aid Compatible) to amplify in-call volume.
Phone settings Edit the call reject message, choose whether to open the message editor when you reject a call with a message, and choose whether to allow automatic saving of an unknown contact number when a call with that number ends.
Cell broadcast Enable or disable receipt of cell broadcast messages from your service provider.
Cell broadcast settings Configure channels and language for cell broadcast messages.
Call forwarding Select how you want your phone to handle busy, unanswered, and unreachable calls. You can also set the call forwarding option for all incoming calls. Call barring settings Choose whether to block various categories of incoming and outgoing call.
Additional settings Enable or disable operator services such as caller ID and call waiting.
Jun 28, 2011 | HTC Inspire 4G Smartphone
I cleared all messages on the DECT 6.0 answering system and the blinking light still shows. How do I get the light to stop blinking until I get a new message?
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Sep 17, 2010 | Uniden DECT 6.0 Cordless Telephone...
Phone is showing there is a voice mail message
Jul 07, 2010 | Uniden DECT 6.0 Cordless Phone ID
Panasonic DECT 6.0 always says "New Voicemail"
Try pressing and holding the MUTE (CLEAR) button until the handset beeps. Then clear all incoming calls.
Nov 23, 2009 | Panasonic KX-TG1033S Cordless Phone
Change voicemail PW on used phone
You'll need to go to your carrier or call in and ask that they reset the password as it is a Network setting and not something that is attached to that specific phone (which is why when you get a new phone with the same phone number, the voicemail transfers over)
Nov 16, 2009 | Cell Phones
Missed calls are not being logged
Clear the call log. it stores up to 20 (30) calls. Some firmware doesn't support overwriting.
Jun 10, 2009 | Nokia N95 Cellular Phone
Motorola Razr Cell phone
This is a common problem, most often fixed by calling your voicemail from another phone and checking the messages. Call your mobile, press * when the voicemail answers, and then enter your pin code. If you don't have any voicemails, leave one first, then call back from the outside line and clear them out.
Dec 19, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
159 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
