Question about Dell Dimension 2400 PC Desktop
When i turn my computer on it says it is on save mode and to hit any key but when i do nothing happens.
    Brigadier General:
  • 10,406 Answers
You probably mean "Safe Mode" -- it is a restricted-functionality version of Windows, designed to be used when trouble-shooting because Windows will not start normally.
Press the SPACE bar, or click on the 'OK'.
But, the big question is why is Windows starting in "Safe Mode"?
Just shutdown, and restart, and see if it will restart in "Normal" mode.
Posted on Nov 19, 2009
5 Suggested Answers
  • 33 Answers
SOURCE: Inspiron 530S Power Save Mode
VIRUS
Posted on May 28, 2009
  • 42 Answers
SOURCE: Dell Inspiron 530 I turns on and nothing happens
1.) If when hitting the power button, ABSOLUTELY nothing happens, no fans come on, nothing- You need a new power supply most likely. I see this all the time in my shop. Here's the bad news- Dell likes to use their own special power supplies, so a normal one may not even fit in the case. If that is the case, then I'm sorry to say Dell likes to charge over $100 easily for a new one.
2.) Fans come on, lights come on, but no screen. This can mean any number of things. Bad VGA cable (or DVI), bad RAM, bad mobo, even a bad PCI card. time to start troubleshooting. Change what parts you can, remove any PCI cards that are not needed, remove one RAM card then the other, etc....
Posted on Apr 29, 2009
frcs68
  • 1605 Answers
SOURCE: power save mode turns on while I'm still on the computer.
check the BIOS setting
Posted on May 27, 2009
  • 131 Answers
SOURCE: Power Save mode on, can not use computer
If your computer is indeed running, simply unplug your monitor from the wall, and then plug it back in. This will bring your monitor out of power save mode instantly.
Posted on Apr 23, 2010
Testimonial: "Will try when the monitor does this again. Was very helpful. Thanks!"
Tried unpluging and nothing tried al buttons nothing the computer was at a shop to BE FIXED AT SHOP OK CAME HOME STUCK IN POWER SAVE MODE BUTTON ORANGE ON MONITOR HIT GOES GREEN SAYS PAWER SAVE MODE HIT...
Press and hold the power button for 5 seconds this will turn the system completely off wait 5 seconds then turn it back on as soon as it boots up go into power options in the control panel and click the option from power saver mode to do nothing as there is a fault with some computers that it gets stuck in power saver mode
Jun 27, 2011 | Computers & Internet
My toshiba C655 turns on to the toshiba and then it goes to "launch startup repair" after hitting enter, it goes through a few things and then a cursor appears on the screen and nothing else...
Have you got anything on the computer that you want to save? If so save it some how I am not sure how you would save it but if not you can do a full system recovery on it. Now if it doesn't go onto the desktop then I would see about getting someone to check it to see if it could be a hardware problem. thanks for posting I hope this helps you out. I am sorry to hear it doesn't work for you it sucks to have things like this happen.
Dec 12, 2017 | Toshiba Satellite C655-S5139 Notebook
I have a dell monitor (2002) and all of a sudden when I try to turn the computer on I get blinking yellow light and (took to Best Buy and computer is fine) when I hit the buttons on monitor I get (power...
Hi Tomccaw,
In this case your monitor is working fine. Your system is going to power saving mode. To resolve that remove your RAM and insert it. It will fix your issue.
Jun 15, 2010 | Dell E172FP 17" LCD Flat Panel Monitor
Apr 22, 2010 | Dell Dimension 8400 PC Desktop
I accidently hit power save mode on the keyboard and now nothing with work on my PC...help,,,how do I get out of power save mode
It should come out of it when you hit any key on the keyboard, or if this doesn't work, when you momentarily click the power button on the computer.
Nov 28, 2009 | Dynex Multimedia Keyboard
Sleep Mode Lockup on Dell Inspirion 530 w/ Vista
Try hitting the "Windows" key on your keyboard to bring it out of sleep mode. The "Windows" key is generally found on the bottom row of the keyboard, near the Alt and Ctrl keys, and it has no letters on it, just the Windows logo. That key brings my Windows Vista machines out of sleep mode when other keys won't.
As for the power button, anytime you need to force a computer to turn off, you can press and hold the power button to do so. Usually, you need to hold the power button for 5-10 seconds and it will shut down. Use this option with caution, as it turns the computer off without running through the shutdown process and can cause you to lose data.
Hope this helps.
Mar 08, 2009 | HP Media Center m7060n PC Desktop
Unable to get monitor out of power save mode
turn your moniter off waite 30sec back on this should get your screen on. Try this Rigth click on your desk'top >properties
>screen saver, click Power then change the turn of monitor tab
Jan 24, 2009 | Dell E172FP 17" LCD Flat Panel Monitor
In power save mode
The monitor is not receiving signal from the computer. Is the power light on on the computer? If so - press and hold power button on computer until the power light goes off, then press again to restart. If the computer starts and you still have no picture it is most likely a video card or motherboard problem.
Nov 17, 2008 | Dell E173FP 17" LCD Monitor
In power save mode
Try hitting the space bar on the keyboard. Does the mouse work normally?
Nov 30, 2007 | Dell E173FP 17" LCD Monitor
Dell Dimension 2400 PC Desktop Logo
Alun Cox
