Question about Delphi SKYFi3 XM Radio Receiver with Car Kit
Locks up on startup - checking firmware especially when cold temperatures.
  • Delphi Expert
  • 509 Answers
Call Delphi, Do firmware update.
Posted on Dec 29, 2009
Cold start problems but when started runs fine bought new battery,spark plug ,ht lead,cap
Did you check to see if fuel is getting to injectors on cold startup! If you have starting problems and the "check engine" light doesn't come on, you may have a bad engine coolant temperature sensor (ECT). Good-Day
Dec 01, 2014 | Cars & Trucks
Engine knocking at startup
bad air/fuel mixture could cause rod knock like that, which is a for of backlash or whip like action. Detonation, like very poor grade of fuel. IF your engineis running really rich, the extra rich fuel goes by your piston rings and thins out your engine oil. If you have a bad ROD bearing, it is probably TOO LATE. CLEAN YOUR THROTTLE BODY and IAC valve, since these things fine tune your FUEL/AIR mixture and PREVENT rich running. GOOD LUCK!!
Dec 12, 2013 | GMC Yukon XL Cars & Trucks
Hard to start on cold mornings. Battery and altenator are OK
I think you are missing the "cold start routine". The engine temperature sensor activates a computer circuit which changes the fuel mix and timing for the first few seconds to a minute or so on the startup.
Either it is failing to sense the engine is cold or the ECU is not using the info the temperature sensor is giving it. Go to a major autoparts store like Autozone and ask for the temperature sensor that controls the startup cycle. There may be a second sensor which just controls the dash gauge and you do not want that one if they are not one and the same.
I hope you find my soluiion useful. Please rate my info.
Nov 06, 2012 | 1990 Honda Accord
Kodak i40 scanner error 8 message but lamps are fine, worked OK last week, any suggestions
Check you have the latest firmware , the old version can cause this on startup especially when cold
Oct 10, 2011 | Kodak i40 Path-Through Scanner
Startup hestitation, check engine light 2006 Ion3
Since your "check engine" light is on you can get a free scan at Autozone or Oreillys. They can sell you a part and may have a diagram about where it fits. Just speculating it may be a coolant temperature sensor.
It sounds like you are not getting into the Cold Start mode.
May 07, 2010 | 2006 Saturn ION
Spa went over set temperature with loc message
How far over the set temperature did the hot tub go?
A hot tub may sometimes exceed the set temperature slightly especially if it's well insulated and has been on a long filtration cycle.
'Loc' usually means that the keyad is locked or partially locked. Check your quick reference guide and it will tell you how to remove the keypad lock.
Regards,
Ian.
http://hottub.synthasite.com
Apr 05, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Wont idle when cold. Especially on cooler mornings. Eventually it works fine. Sometimes it will clear after a hi rpm rev.
have someone check the engine temperature sensor to see what temperature it is telling the computer,if it is not telling the computer the correct temp,the computer won't give the engine more fuel on cold mornings
Nov 25, 2009 | 2000 Ford Explorer
Fridge side cant keep 100 percent cold
Have you noticed a big difference lately in the cooling of the cold food section? Any time you open doors to a refrigerator or freezer you allow them to exchange room temperatures with inside ambient temperatures. The only time you should be concerned is when these temperatures begin to remain abnormally high. Many times the temperature rises in the kitchen while diner is prepared. Those temperatures also affect how long your refrigerator need to run to maintain the temperature settings you select. Your refrigerator has something called an Adaptive Defrost Control. If you should have problems with it you would notice a big difference.Another thing that can help is to make sure the condenser coils below refrigerator remain clean and clear of dust. The warm air circulating below your refrigerator is as important as the cold air inside. As for the vents that lead from freezer to cold food section they sometime become obstructed especially if they have a damper inside and frost locks the damper shut. If I missed something here please let me know, Thank You, Sea Breeze
May 23, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Irratic idle at startup
No check engine light? You have a couple of sensors that may be causing that, coolant temperature, incoming air temperature sensor to name 2 of them. Personally I'd have it put on a scan tool & remove the guess work. Some parts places will do it for free, well as long as you buy the parts there.
Jan 16, 2009 | 1991 Acura Legend
Van won't start in early morning when it's cold.
I'd be real tempted to replace coolant temperature sensor, as it sends signal to ECM regarding engine temperature and fuel requirements pertaining to that temperature. For example, it tells ECM that engine is cold, send more fuel for cold start, but if it's defective, doesn't tell ECM to do so, or gives ECM the signal that engine is already warm, and doesn't require that extra fuel now for start up.
Dec 11, 2008 | 1997 Dodge Caravan
Delphi SKYFi3 XM Radio Receiver with Car Kit Logo
119 people viewed this question
Top Delphi Audio Players & Recorders Experts
John
John
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Delphi Audio Player and Recorder Expert? Answer questions, earn points and help others
