Question about Canon XL1S Mini DV Digital Camcorder
Attaching xlr input
Im attaching the MA 100 accessory to use xlr at a shoot for the first time. How do I set the audio settings within the menus to use it?
    Champion:
    Scholar:
  • 216 Answers
16 bit is the best audio mode for that camere.
atdlee@netzero.com
Posted on Jan 25, 2008
    Sergeant:
    Champion:
  • 317 Answers
You have to set the audio channels to record in 16 bit audio, and to accept all inputs. If I remember correctly, this should be in the menu under camera setup, or something similar to that.
Posted on Jan 18, 2008
Ch. 1 on Behringer pmp4000 not working
A short on the XLR input board, or possibly a short within the XLR connector itself.
Nov 14, 2017 | Behringer Europower PMP4000 Powered Mixer
How to connect the canon ma-200 to the canon xl1
You can mount the MA 200 shoulder pad to the XL1 and plug the RCA connector and the mini plug into the port located on the back of camcorder, first open the door. Next, on the side panel where the audio controls are select AUDIO 1. Now assemble a mic using an XLR Cable. Then plug it into the AUDIO 1 port located on the MA 200 Shoulder pad and conduct test. if your using just one mic test the right side, take notice of the gauges located under the handle. the levels should be jumping like crazy. Now remove the XLR cable from the right side and test the left side making your desired audio levels. Now that should work with out question. If not just email me and ill refer you to the YOUTUBE VIDEO. Email me at: dtspmedia@yahoo.com Peace, Enjoy your video sound.
May 27, 2012 | Canon MA-200 Microphone for XL1, XL1S
I can record voice, but no guitar. Just as many people on this forum, but i didn't saw a proper answer for my problem. I can hear my guitar im using pro tools SE. The light on my fast track lights up,...
In Protools go into hardware setup and make sure that your interface is being read properly. It may be set to something other then your fast track. Then, in the MIX window make sure that your input is set correctly. If your microphone is plugged into input 1, your input on your protools track should correspond to that.
Sep 06, 2011 | M-Audio Fast Track USB (FASTTRACK) Audio...
When ever i try to capture audio through xlr
whic soft ware are you using with blackmagic board Final cut or adobe primier
in mac go to system priferences and check for blackmagic is it set ok
and in pc go to controll pannel and you will find the blackmagic utilities please check also the setting nd also check the setting in priferences of the adobe primer and easy setup and capture setting in log and capture in finalcut if every thing is ok please download the latest software driver for the blackmagic board and install it it will *** a firmware upgrade and every thing should be cool .....
which board decklink extreem or the older one?
Apr 18, 2010 | Blackmagic Design DeckLink Extreme...
What kind of outlet do i plug my cm-p35 microphone into?
The cm-p35 is a low-impedance (low-Z) dynamic microphone. It can plug into a mixer or microphone preamp that has XLR input connectors, typically found on professional audio equipment.
If you want to attach it to a computer, you'll need to buy an audio interface for it, either a pro-grade sound card with XLR inputs, or a USB-to-XLR adaptor, like this one at ZZounds.com
Jan 10, 2010 | Coby CM-P35 Consumer Microphone
Panasonic dvx1000a has no audio input, for xlr connector, the switch line mic is in mic pos. and the external mic not work in that camera.
You have to switch the CH1 and CH2 switches inside the lcd display to input 1 or input 2 to control the xlr inputs. If these switches are in int (L) and int(R) position, then you are adjusting the audio on the CH1 ad CH2 dials below the lcd viewer on the outside of the lcd for the on camera mic. Only use line setting on the front of the camera when you are receiving an audio feed at line level from an audio board. If you set the camera to mic setting, and you are receiving a line level audio signal, you will blow out the audio 0 way too loud, if you are receiving a mic signal and your switch is set to line, you will not be able to hear the mic with the audio Ch1 and ch2 all the way up.
May 17, 2009 | Panasonic AG-DVX100A Mini DV Digital...
Channel Two Input silent
Not sure of particular model, but if it's like z1 then it's convoluted and non-intuitive.
But here goes.. if i can remember.
Go into menu, then audio
check that the channels aren't linked
if set to manual check manual adjustment wheels
The z1 doesn't seem to allow on board mic and xlrs, so check that
Does mic need phantom power?
Is XLR input set to mic?
Sorry i can't be more model specific... but hopefully something of this will be helpfull.. the main thing to check tho is that the xlrs aren't linked
Jan 29, 2008 | Sony Dvcam DSR-PDX10 DV Digital Camcorder
Sound recording with external microphone
An instruction manual is available for download at www.canon.com
Your camera, according to the manual, has a single input for microphones, and in the internal menu, AUDIO DUB has to be set to MIC. IN. when using an add-on microphone. An MA-300 hot-shoe microphone accessory can be used, and then the input controls would be on this device, not the camera. Your camera can also record in two different audio qualities: 16-bit two channel or 12-bit four channel. If you are using an accessory you may need to select 12-bit in the internal setup menu in order to have enough channels to add on the additional microphone(s).
Finally, and hopefully not, the camera may have an internal hardware problem, and so would need to be serviced.
Nov 05, 2007 | Canon GL2 Mini DV Digital Camcorder
Need of codes....
Hi I hope this will help http://www.dvcentral.org/tricks.html Tricks 4 XLR ins: Get the Canon MA-300 adapter and get yourself 4 XLR inputs. Perfect for a couple of wireless lavs, a boom, and another mic. Sure, it's less data for the audio channels, but it's plenty for voice recording. Sure, you can't digitize audio 3&4 easily, but it is possible, and it's just so darn useful to have four audio channels in the field. (Also, you can easily mount the wireless lav receivers right on the back of the camera.) Using the Canon on-camera mic via an XLR input: Say you're using a single boom mic, inputting via XLR 1. You've got XLR 2 doing nothing, and the on-camera mic doing nothing. Seems a waste. Well, all you need to do is adapt the on-camera mic to input through XLR 2. A short female-mini-to-male-XLR adapter will do for the audio signal, but the mic needs power. Simple, just get a short micro-mini extender cable, plug one end on to the mic, and the other into where the mic's connector would normally plug, on the camera's handle. Make sure the mic is switched to stereo, and voila, you have a second XLR mic. Monitoring in the field: Though many people told me it couldn't, the XL H1 downconverts to NTSC on the fly during recording, so you can plug a little monitor or deck into the video and audio out jacks and have yourself a video tap. Perfect for the director who wants to see what's going on through the camera. I used a little DV camera, and recorded it all so we could have a playback tape if needed. Very useful. (Note that the output NTSC is anamorphic, stretching the 16:9 image over the whole 4:3 frame. A monitor with a 16:9 switch is useful, or something that automatically adapts, such as what I used, a Sony PD-100 DVCAM camera.) Native slow motion: In a 24F project, shoot 30F and use Cinema Tools to slow down the footage to 24fps for a slight slow motion effect. Use 1/60 shutter speed for a standard look, or 1/30 for a slightly dreamier feel. Good Luck.
Sep 15, 2007 | Panasonic Proline AG-DVC7 Mini DV Digital...
Canon XM2 -Burned main-board
im wondering why it cant be repaired down to componet level as if the servicer has a schematic its probaly not more then a cap a diode or both snf msybr sa resistor as they do have a protection curcuit on thes camcorders that wount let it distroy the Board Maybe you need another servicer??? Im not sure of your queistion on the adaptor But im sure that if you look in your owners manual it will assist you in where to call to get or buy accessorys. Good luck
May 11, 2006 | Canon GL2 Mini DV Digital Camcorder
Canon XL1S Mini DV Digital Camcorder Logo
67 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
