Question about Vanguard International Infra Red - Medium Infra-Red Mid-Size Heater
One panel doesn't light immediately. Fills room with gas. Do I need to clean panel?
    President:
  • 3,433 Answers
Light the panel at a very low pressure The panel not lighting is probabably the first pael to get gas and is not having the correct air /fuel ratio to burn. Make sure the igniror is properly positioned. The lit panel can ignite the raw gas expelled by the unlit and create a flash ignition . (explosion) The ceramics a very delicate and I would be reluctantant to advise on clean. You can blow it out with compressed air if available..
Posted on Nov 20, 2009
Mhu75ng stopped lighting after about a year. Fan starts, but burner doesn't light. Fan stops after about a minute. LED code is 3 flashes. Gas supply should be good, heater in another room ups
3 flashes could be the pressure switch ,jump it out see if it lights or clean the flame sensor or check the snap dice's 1 for high temp and 1 for low temp ..
Apr 12, 2013 | Mr. Heater MHU75NG
My oven makes a noise before it lights. A "whoosh"
That is common with gas since the gas fills the entire element before there is enough gas for the pilot to ignite. You have the same thing with outdoor gas grills.
Feb 19, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
I have a blizard split model 10.5 years old in a caravan. model sa101 the air feels cooler but seems to have no noticable difference in actual temperture and compressor seems to run continuously ...
Please understand first, air conditioning system not only cooling the area but also removing the heat. If heat in the room stays constantly, even 24 hrs running a/c couldn't cool the room.
Now, why the a/c could not cool the room or remove the heat from the room.
Check air filter, evaporator coil and blower wheel for clean. If not service the unit immediately. And also check indoor fan motor rpm. If rpm is low, replace fan capacitor. Check for gas pressure to confirm no leak or running with short of gas. It's advisable to service both indoor and out door once in 6 months at least. Otherwise, your electric bill will kill you lot. Thanks.
Jan 31, 2011 | Electrolux Heating & Cooling
Self light oven not lighting - gas fills the room
its the hot surface igntior that glows could be cracked might need replacing
Feb 02, 2010 | Tappan 24 in. Freestanding Gas Range...
I have a problems with my Viewsonic vx2235wm, the On/Off button does not always make a good connection in turning off the monitor. I will push it and it will go off and then come back on immediately. The...
press it several times very very quickly, if it doesn`t start functioning the front panel must be opened in a service and the contact cleaned...i don`t think it needs replacement
Oct 28, 2009 | ViewSonic VX2235wm LCD Monitor
One burner out of 6 will not light
It will need to be cleaned under the burner where the gas mixes with air to enable it to burn.
Sep 05, 2017 | DCS Kitchen Ranges
Oven works rarely
does it flip the breaker when it shuts off?if so sound like a short somewhere. i had kinda the same problem with a ge and it was the oven light was touching the panel and shorting out.
Dec 01, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
How do I light my oven?
which light is dim amy and dont turn it on till we fix it hold my rating as i need to ask you somes questions before we can repair it but basicly the gas valve should not open with out the oven lighting
Oct 25, 2007 | Hotpoint RB757 Electric Kitchen Range
Vanguard International Infra Red - Medium Infra-Red Mid-Size Heater Logo
99 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
john h
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
