Question about Denon AVR-4308CI Receiver
Denon 4380CI HDMI PC resolution problem
Hi guys
I have problem with HDMI connection in my Denon 4308CI, I checked firmware update and I did it from the website.(Before the update everyting worked fine)
When the update was completed, I got the message that the status is ok.
But later I had problem with my PC connections - DVI to HDMI ----> No signal when I connect the PC to TV
Everything works fine but when is connect to the receiver i get NO SIGNAL. (Resolution in TV is 1360x768 PC Video Card Evega 8800 GTS !!!).
Now when I change resolution on video card to HD,SD 1080i,1360x768 it WORKS, but this is not correct - should be 1368x768 PC) so basically when I use all HD,SD resolution i see pictures on my TV. PC
resolution doesnt work..
I tried to: restart denon processor, unplug power cord, check connection, and reinstall drivers but nothing helps me.
Also I called Denon supports a They told me that "this update doesn't change anything with the video and that I NEED TO CALL to producer of my video card or technical suppot ay Nvidia
It does't make any sense because when i connect to tv everything works fine
Any ideas how to fix it?
THx
  • 4234 Answers
SOURCE: input signal clicks on and off 4308ci
When you say the the input clicks on/off, does the sound cut out? I suspect that the protection circuit is kicking in. Can you please post the connections you have? # of speakers connected etc?
Thanks,
Dan
Posted on Jun 10, 2008
marsrover
  • 682 Answers
SOURCE: Mac Mini and Denon 3801
http://www.retrevo.com/samples/Denon-Receiver-manuals.html
Posted on Aug 09, 2008
webdevil
  • 43 Answers
SOURCE: HDMI XBOX360 Elite -"No Signal"
The connection order can be a key issue as to whether or not the HDMI signals will pass through the system. For best results the receiver should be turned on first, then the source device(s) and then the display. The reason for this has to do with getting the equipment to handshake properly for the HDCP protocol.
If HDMI video will not pass through your receiver, you may with to just connect the xbox using the component cables. Since component will pass through 720p and your TV is 1080i you should expect the same qualtiy and a more crisp picture.
Posted on Jan 06, 2009
SOURCE: No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Posted on Apr 15, 2009
  • 128 Answers
SOURCE: Denon AVR 1610 hdmi to component video conversion missing?
hello i believe your problem is that you are trying to downconvert from hdmi to component connections and Denon receivers will not do that.
I have a 4310 and I know it will UPconvert from an analog signal to HDMI but won't do it the other way around.
you may have to use component inputs for all your equipment. You will also have to go into the receivers menu and designate which signal is being used for each component as it won't auto select between analog and digital signals when it comes to video.
hope that helps
Posted on Jan 25, 2010
Testimonial: "Thanks. Very helpful"
Denon update firmware
www.usa.denon.com/US/Downloads/Pages/Product-Updates.aspx
Jun 29, 2014 | Denon DBP-1611UD Universal Blu-ray / DVD /...
Ping/Green Bars on TV Display
I would first check and replace the cables to make sure you have clean signal. If that all checks out then I would consider putting in an amplifier in line to boost your signal. What is the distance you have on the cables all combined? Another thing to check in troubleshooting is to remove everything (cables) except the unit you are experiencing trouble with. If after all of this I would say your connection to your component itself is suspect.
Jan 27, 2014 | Denon AVR-4308CI Receiver
My DENON AVR-4308CI HOME has no sound. Everything comes on as it should and unit looks great but no audio comes out. It's had off and on issues since I bought it, but firmware helped with some. Now, no...
This may require quite a bit more info. Verify that there are no shorts in the speaker connections to the Denon - it has a short detection circuit that will shut down the audio amps in the event of a short. If you are using optical or coaxial digital input for you audio - verify that the correct digital input has been assigned to the component selected on the Source Select dial: Menu > Source Select > Assign > Digital. If this is an HDMI connection go into the HDMI setup menu and select Audio: AMP: Menu > Manual Setup > HDMI Setup > Audio > AMP. If it is set to TV the audio passes through the AMP without being decoded and goes to the TV instead: there is no 'Both' setting.
Oct 26, 2013 | Denon AVR-4308CI Receiver
Denon avr-2113ci hdmi can't change source
Can you update the firmware on the amp as this could also affect the connection between the players.
Jan 15, 2013 | Denon AVR-2113CI
Sound went out today. Mute is not on, and all
Does it think you have headphones connected? If you have headphones, check to see if they have sound output.
Jan 26, 2010 | Denon AVR-4308CI Receiver
I have Denon 4308. Is it possible to use video select with hdmi?  When I try,the screen goes blank. -- Regards JP Naess Norway
From the manual of your Denon page 41:
http://www.usa.denon.com/AVR-4308CI-OM-E_305A.pdf
"Video Select -It is not possible to select HDMI input signals. • When playing HDMI video input signals, the analog video signal of another input source cannot be selected for the HDMI video output."
Nov 24, 2009 | Denon AVR-2807 Receiver
Sound and video goes out periodically for a a couple of seconds every few minutes. Power stays on, all sound and video stops.
I am assuming you are connected HDMI?
This is a common problem when connected with HDMI. HDMI checks for HDCP codes every three seconds and if it doesnt get the proper response from the devices or repeater (amp) it will drop the connection and ask again in 3 seconds. If it receives the proper key it will display the signal again.
Have you tried the firmware update? http://www.usa.denon.com/AVR-4308CIFirmwareUpdate-Web1128.pdf
I hate to say this but HDMI is not perfect yet so there may not be a solution to this except to drop your inputs and outputs to component video and digital audio. The only source that will be effected from a resolution stand point is a BluRay which can only display 720p or 1080i (not 1080p) when ran through component video.
Nov 08, 2009 | Denon AVR-4308CI Receiver
Hdmi not working
Please rephrase you get an "ant screen"?
Does the sound work? What is your hdmi video output device?
At any rate, you can also try this quick fix. In the setup menu go to Source Select. Make sure these settngs are right:
Assign>HDMI = HDMI 1 - 4 (depending on device)
Input Mode>Input Mode = Auto
Decod Mode>Decode Moe = Auto
Other>Video Convert = On
Set this for sources (devices) you have connected to the hdmi.
Jan 03, 2009 | Denon AVR-4308CI Receiver
I have a Denon 4802 and now want to pgrade to HDMI inputs, what do I do on the cheap?
Hi why ! you will gain nothing . but if you want to waste your money the company you need i C.P.C they sell the leads to do this look on line regards kirk
Dec 11, 2008 | Denon AVR-4308CI Receiver
Denon AVR-4308CI Receiver Logo
376 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
