Question about Dryers
My kenmore 110 will fill and rinse, but will not agitate, drain, or spin. I ran 2 tests before this post. Once the washer gets to the wash cycle, it just stops, I get nothing. I also don't hear any motor noises either. 1st, I manually emptied the tub, reset the timer to the beginning, and restarted the washer and closed the lid. Washer filled as normal, then stopped when it achieved low level water, I changed to medium level and water began to fill again, so level switch I think is OK. I let the timer run through its entire course of time and it did fine, but no cycles or noise. So my 2nd test was to jump the lid switch, to eliminate the switch, I got exact same results as 1st test. What now? Kenmore 110.82874120
  • 3 more comments
  • mcris77 Nov 20, 2009
    No did you read my post? I already by jumped the switch, same problem!
    Even though the timer ran its full course? I closed the lid and the timer went through all stages of the cycle, just no action once the tub is to proper level.
    Thank you, that does help. There is no noise at all from the motor, do you have the motor part number and perhaps instructions on the replacement? Is it worth the repair?
    Is there any way to test the motor switch before I buy a motor and switch?
  • 5,911 Answers
Check your lid switch. If the washer fills and agitates, but stops at the rinse cycle, or, if the washer fills, then stops and will NOT drain, this is a common symptom of a lid switch malfunction. The following link explains how to access and/or replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug.
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30. Prices differ between these sites, so shop around for the best price.
This is a very simple repair, but if you have questions, please let me know. I hope this helps you.
NOTE: You do not need to drain the washer to replace the switch.
Posted on Nov 19, 2009
  • 3 more comments
  • Jeff Rockwell
    Jeff Rockwell Nov 20, 2009
    NOTE: If you've by-passed the switch with the same result, you may have a defective timer.
  • Jeff Rockwell
    I apologize, but I didn't see the last segment of your post until I posted the solution. I immediately jumped on it thinking I had the solution, because I'm familiar with the initial symptoms. Most commonly this is caused by a lid switch. However, after re-reading it, you've confirmed the lid switch and timer action. The only thing left that activates the transmission to begin agitation is the drive motor. The drive motor is also used to drive the drain pump, which would explain why it also does not drain. I"m sorry, I was trying to help...
  • Jeff Rockwell
    One last item: If you HEAR the drive motor running, then this problem would be attributed to a broken motor coupling between the drive motor and gearcase (transmission). The washer usually makes a loud rattling type noise if the coupler is broken. The symptoms would still be the same. Washer fills, attempts to run, no agitation, and will not drain. The part number is 285753A.
  • Jeff Rockwell
    The following link explains how to replace the drive motor:
    http://www.fixya.com/support/r599953-rep...
    Now...in the case with your drive motor, it is a small motor switch that you can purchase as a separate item. Either the switch has failed, or the motor itself is not working. The part numbers are as follows:
    Drive Motor - 3349644
    Motor Switch - 8529896
    If you purchase just the switch it runs about $60. If you purchase the entire motor (which includes the switch), you'll spend about $120. You'll find it listed the cheapest at pcappliancerpair.com. If you wish to view an exploded view diagram of your washer you can go to searspartsdirect.com and type in your model number.
    Its not a terribly expensive repair, but its not cheap, either. It still costs less than purchasing a new one. The decision is yours...
  • Jeff Rockwell
    Access the motor and remove the switch. It simply unplugs. You should be able to take resistance readings across the switch terminals and toggle the switch to see if you get a change in resistance. Open - Off, Short - Closed.
    If the switch is toggling properly, plug it back into the drive motor and momentarily by-pass the lid switch. With the timer set on an operate position, you should be able to push the switch toggle to see if the drive motor runs. If the motor still does not run, you more than likely have a bad motor.
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 21, 2010 | Kenmore Washing Machines
I have a Kenmore top loading washer model #110 and won't agitate
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?pop=true&modelNumber=110.23912100
Also see the Whirlpool (Kenmore) Service Manual for top load, direct drive washers.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
The first thing I'd try is using a different cycle. If the washer works as it should, the problem points to the timer.
I'd also check to make sure that when replacing the switch, the connections to the timer haven't come loose.
Since you've replaced the Lid Switch, the motor has power for the drain and spin cycles.
These washers use a reversing motor. The motor turns one way for agitating and reverses for the drain and spin.
Since you cannot hear anything when it is supposed to be agitating, the problem does point to the timer or motor.
Nov 14, 2009 | Kenmore 22422 Top Load Washer
Kenmore 80's series top loader only works on wash and rinse cycle
This is a problem with the pump being stuck so the motor cant turn the whole thing. Turn the washer on its side, underneath you can acces the pump, which is connected to the motor by two long clips. remove the pump and take out the colg that caused it to get stuck.
Jul 01, 2009 | Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore stack washer and dryer
gabehart....sounds like belt is slipping. Replace it. The water pump is on a separate smaller motor so is not affected by the agitator/spin motor.
Jun 04, 2008 | Kenmore 98702 Stacked Washer/Dryer
98702 Washer Drain/Spin Dead.
My Kenmore 98702 washer Fills and agitates as expected but stops at the end of cycle failing to drain or spin
Dec 05, 2007 | Kenmore 98702 Stacked Washer/Dryer
Dryers Logo
270 people viewed this question
Top Dryers Experts
