Question about Hitachi 50UX26B/27K 50" Rear Projection Television
I turn on the tv then it immediatly turns off, there is a red little light in the back that is labled protection that is lit, i saw 2 fuses and they are good
  • 585 Answers
Hi my name is Roety,
I can help you with your issue ,
Most likey you need the convergence ICs replaced.
A repairman would charge about $350 to replace them
Voltage checks and a visual would be needed to determine exactly what is bad in your TV
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Nov 20, 2009
Daytek television will not turn on.
There is a manual switch on the bottom of the TV. Flick it on and TV screen should come on. The power light will come with this switch off but the screen won't. It had me cursing for a while until I saw the little switch.
May 15, 2010 | Televison & Video
When tv is turned on green light comes on then goes to standby
had the same problem on mine.
Found loose solder terminals on the main power transformer, resoldered fixed it up about 5 min.
Nov 01, 2008 | Pioneer SD-532HD5 53" Rear Projection...
Code for the one forall for a sharp tv
You do not need a code...
Heres how to set up your remete..
Turn on the devise you want to set up.
Press the set up key on the control firmly until the red light lites up and stays lit. Now press the key for the devise you are trying to set up(dvd, vcr, tv etc..).. the red light will now turn off.
Now facing the devise, begin pressing the power button several times until the devise turns off. Be careful not to press the power button any more after it turns off. After it turns off , you must immediatly press the enter key in order for the control to save the code. Now your control is set up. If this does not work , it is because you pressed the power button once more after the tv turned off....
This process might take you anywhere from 3 to 5 minutes.
despino1@hotmail.com
Jan 10, 2008 | Sharp 27C-240 27" TV
Will not stay on
RED light is protect circuit = do not disable !
Look for C702 near flyback transformer - might be hidden in
glue = check it = if shorted, replace 102K / 2KV with 3KV =
Sony part # 1-161-754-00 and replace E994 pico fuse.....T.
Nov 08, 2007 | Hitachi 60UX54B/55K 60" Rear Projection...
Wont power on
Needs Convergence amps replaced. Also fuses around this board are out. There should be small pico-fuses open around this board(replace)
Aug 26, 2007 | Hitachi 55FX48B 55" Rear Projection...
Tv will not turn on--- flashing red led
I'm sorry, I don't have a solution, but I seem to be having a similar problem. When I turn my TV on, the green light comes on like it's powered up, but then the TV turns itself back off and the red LED light flashes. I can't do anything to turn it on or anything.
Jul 11, 2007 | Philips 37FD9954 37 in. HD-Ready Plasma...
Picture comes on than turns off and red light stays on
you can reset the tv to factory default settings , but before that I need more info ab manufacture date and purchase date you can find the first one on the back cover, if the tv has more than 5000 hrs of use problably the lamp, filter or fans can cause this problem, hope it helps you . let me know
Jun 10, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Open Questions:
Televison & Video Logo
259 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
