Question about Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw
I've owned a 357 xp for 3 yrs now and my carb seems really gummed up the dealer says I need to buy a new carb but can I not just get a carb kit. The saw runs good till warm then once you let go on the throttle it's like the saw leans right out and stalls.
I just had my 15 month old 357xp into the dealer for a week. It had the same issues as yours.i had a walbro carb on it and they replaced the car with a walbro from 2 other new 357s and no good. finally the company told them not to use a carb from the new saws but to use a replacement carb which is a zama. it ran perfect with the zama. the dealer thinks husky is having problems with the walbro's but doesnt want to admit it due to having to do a recall. go in, tell them what you know and request consideration for free replacement. they might do it to keep you quiet. jandtthompson8@msn.com for more info!
Posted on Dec 21, 2009
  • 169 Answers
Yes a carb kit is avail all day long. Go online to my website and enter your carb kit number Lakeviewpower.com
Posted on Nov 20, 2009
I picked up a 79 cx500deluxe and it had been setting for 7 years under a taro. i drained the tank cleaned it out and the carbs seem to be fine in that as far as i can see there is no real tarnish or...
One carburetor is fed by the other carburetor. There is probably some blockage in the crossover pipe between the carburetors. You will probably have to take the carburetor rack off and split the carburetors apart to get proper access to the crossover tube, unless you can figure out how to clean out the crossover with out separation. You will need to replace the crossover pipe o-rings if you split the rack. They are only available in expensive Honda carburetor gasket kits. You may be able to purchase the o-rings separately out of a K&L Supply carburetor o-ring kit if your local dealer has one. Other wise an auto store may be able to match up the fuel proof o-rings.
Jul 23, 2011 | Honda CX 500 B Motorcycles
2004 Honda sportrak 400ex quad, Carburator diagram & adjustments. Will start run for a few sec. & then die. Sat 4 almost a year, took old fuel (as much as i can)out & put in new 91oct...
your carb needs to be cleaned/rebuilt,the jets are clogged from the old fuel,if the fuel that was in the tank had a really bad smell,then the fuel is bad,and what was in the tank is also inside of carb.(carb kit).
Mar 06, 2011 | 2005 Honda XR 400 Motard
Husqvarna 137 chain saw - put a new plug in and won't start run if you put a small amount of gas in plugfor just a second or so made sure gas line is not stopped up from tank to carb. less than 2 yrs...
Sounds like the diaphragms in the carburetor have gotten dry and won't flex anymore. Install a new kit in the carb and recalibrate the screws. You should be good to go.
Nov 18, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a Husqvarna 357 xp which is about a year and a half old, but has had very little use for a professional saw. I was cutting with the saw upside down when it suddenly cut out. After letting it rest...
The carb is an "all position" type and shouldn't be the problem.
Check and clean/replace the fuel filter in the tank. Dirty or old gas, sawdust and/or water etc. settle on the bottom of the tank; and when the saw is turned over will plug the filter, causing the symptoms you discribe.
It is possible, if you used old gas(3 to 6 months) that small varnish particles have gotten through the fuel filter and have pluged the fine screen in the carb(located under the diaphram).
Sep 22, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
My carbbys keep cuttin not wanting to idle
most likely problem will be the slow speed idle jets and airway's. you can try stripping and cleaning with a good quality carb cleaner and a compressor to blow through the jets, but this does not always work as modern fuels tend gum up really quick, the best way to get them clean is to have them sonically cleaned, i would also buy a service kit for each carb and reset the floats to spec and possible add a dynojet kit and new set of spark plugs,( some new coil packs would also give it a new lease of life)
Jul 23, 2010 | 1995 Suzuki GSX-R 750 WS
I want to rebuild the carbs.
Hello. Honda has a rebuild kit specifically for your bike. Contact your local Honda dealer to purchase one. Joe
Mar 31, 2010 | 2005 Honda CB 750
1976 f250 truck sat for 6 yrs the gas has turned orange and smells like varnish this truck has an electric fuel pump i replaced the fuel filter and tried to start it several times with starter fluid ive...
hello, usually when gas sets in carb for a long time it turns into a varnish, you will have to take carb apart and clean all jets out, even the fuel pump may be clogged up, you will probably have to rebuild carb, unless you have access to air line to blow any and all jets, pretty much all passage ways, power jets, in other words you have a carb problem, you may need a new one, unless you have a strong solvent, that will break away any varnish or gum up.
Feb 06, 2010 | 1982 Ford F 250
My 2005 650 bandit seems only to be running on 3 cylinders at idle speed and at low revs.it usually cuts out after about 10 seconds when idling. under acceleration it goes back to running on all cylinders...
First thing that I would do is a compression test. Go to you local auto part store and tell them you need to buy a compression gauge. It should come in a kit that has a gauge, hose and adapters. Remove all the spark plugs. On the cylinder that you think isnt running screw the adapter and hose into the spark plug hole then hook the gauge to the hose. Once done crack the motor over buy pressing the start button and watch the gauge. If there is good compression the gauge will build up pressure and stay up. If the compression is bad the gauge will eather go up and fall or not go up at all...after that give send me an email and I can tell you where to go from there....cj_monaco@hotmail.com
Jun 21, 2009 | 2005 Suzuki GSF 650 N Bandit
Have a Poulan Gas Powered Chain Saw, I haven't started in 10 yrs.
check that plug is getting spark (remove plug, w/ cap attached hold tip of plug on cooling fin. pull starter rope, should see spark). if not receiving gas check filter in tank, if ok procede to carb possibly add a bit of starter fluid.
Mar 14, 2009 | Poulan Pro 16-Inch 38 cc Anti-Vibration...
Getting a fuel dump
Sounds like you need to clean the carbs out, as they are probably gummed/varnished badly after sitting for 2 years.
Mar 07, 2009 | 2000 Honda VT 1100 C2 Shadow Sabre
Husqvarna Forest & Garden No.967012396 345 16" Gas Chain Saw Logo
367 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
