Question about Nikon F65 35mm SLR Camera
I received an error message FEE on the aperture
    Problem Solver:
  • 15 Answers
You need to have the installed lens set to it's smallest aperture (largest numerically) when using this camera in most exposure modes.
Posted on Nov 20, 2009
Fee error message in monitor screen flickering, will not allow pics to be taken
My D70s gives error FEE on aperture display, when a lens is mounted with manual aperture ring. This ring should be locked on smallest aperture.
The body closes the aperture just before taking a photo, but a manual (mechanical) setting could avoid that. You can choose the aperture with the front wheel on the body.
May 23, 2015 | Nikon D70s Digital Camera
I have a Nikon D70, and a Quantaray lens (28-90mm). I have had this camera for about four months, and it has been working fine with the lens. When I received the camera, the aperture ring moved, but the...
In order for the aperture to be controlled by the camera's program or primary and secondary control knobs, the lens must be set to the smallest opening - or highest number value f stop. The aperture must be operated by the ring if it is not left in the smallest opening position.
The FEE code you are seeing refers to a communication error between the lens and the camera body. Sometimes, simply removing the lens from the body and reseating it to the body will solve the problem. While the lens is off the body, carefully inspect the gold colored contacts on the lens and mating contacts on the camera body. Remove any dirt or debris found, being careful not to allow it to fall into the camera - or land on the back glass of the lens.
I found another explanation and possible remedy that stated:
"A flashing "FEE" is an improperly set aperture ring in 99.9% of all cases with this error message (i.e. user error). In very rare circumstances it can be caused by a damaged aperture ring (small lug broken from back edge) that can't "tell" the camera it is at the minimum position. If the aperture rings on the lens is set to minimum aperture (highest number) and locked there, but you still get a FEE error, it's possible that sloppy tolerances are causing the lens aperture ring to not move the little switch at the 8 o'clock position (on the D70 lens mount) as far as necessary to get a proper indication of minimum aperture. Try to see if the aperture ring (while locked) will move slightly when mounted on the camera to clear the FEE error.
Another remote possibility is that the little switch at the 8 o'clock position mentioned above is not functioning properly (sometimes they get dirty). Try "exercising" it by moving it back and forth with your finger, then try the lenses again. Usually FEE has nothing at all to do with CPU contacts (with a reverse engineered third party lens anything is possible I suppose), but it doesn't hurt to clean them to eliminate that possibility."
You can also try a different Nikon compatible lens. If the trouble is still present, the camera may need to be returned for repair. If the the problem goes away, then the issue is tied to the lens itself. This would mean the the lens needs repair.
I hope this helps and good luck! Please rate my reply - thanks!
Jun 30, 2011 | Quantaray 28-90mm f/3.5-5.6 for Pentax
What does FEE mean? The camera won't take a picture and I see that in the display of my Nikon N90S
FEE error message displayed on SLR camera LCD Description If the cameras LCD screen displays "FEE" in the area where the aperture is normally displayed, please ensure that the lens is attached to the camera correctly. This error message will appear if the lens is not attached correctly to the camera or if you are not using a CPU lens such as the Nikon AF or Nikkor P lenses. Alternatively, if the lens has an aperture ring, it may not be set to f22 (or the highest aperture number on the aperture ring - normally marked in orange). Select the aperture number marked in orange on the lens and lock it using the aperture locking switch to prevent this occurring again.
The FEE error message
Set to F22, or the highest aperture number - normally marked in orange. Note the locking switch.
If the above did not resolve the problem and you still experence the the error display FEE, please contact your local Nikon office. Before doing so please also check the following.
1157d.gif That the EE servo coupling highlighted above on the lenses has not been broken. That the F-min switch highlighted above on the camera body has not been broken. If either of the two items above are broken please contact your local Nikon service center.
Apr 19, 2011 | Nikon N90S 35mm SLR Camera
I just bought a Tokina 100mm f/2.8 AT-X M100 AF Pro D Macro Auto Focus Lens from B & H and put it on my Nikon D300. When I press the button a blinking FEE appears. What seems to be the problem?...
The FEE error indicates that the camera cannot control the full range of the lens aperture. If your lens has a mechanical aperture ring, rotate the aperture to its smallest opening, or highest f-number - normally marked in orange. Select this aperture and lock it using the aperture locking switch to prevent this message from appearing again.
Dec 18, 2010 | Cameras
Error code eFF
This normally indicates that you're using a lens with an aperture ring, and the ring is not locked in position. Turn the aperture ring on the lens to its smallest setting (largest f/number) and lock it if the lens has a lock. Control the aperture from the body, just as with a lens without an aperture ring.
If the lens doesn't have an aperture ring, could you reply to this post and specify what lens you do have on the D100?
Dec 05, 2010 | Nikon D100 Digital Camera
When I push the botten to take a pictures it said fee
You haven't stated the exact Nikon model, but the error message usually applies to Nikon bodies with aperture control via the body. The message is telling you to set the lens to it's minimum aperture (highest number).
Sep 05, 2010 | Nikon Cameras
Error message FEE on aperture
Make sure the lens is mounted on the camer fully. Make sure the aperture ring is set for the largest numbe like 22 or 32 if the lens has it. Some lenses have a lock to lock the aperture ring on the largest number for you. Also make sure the lens you are using is compatible with the F65 camera. if the lens is older then it will not give you any electronic data and the camera will never give you the f information in the viewfinder.
Nov 19, 2009 | Nikon F65 35mm SLR Camera
Our Nikon d1x won't take a picture. It gives me an FEE type of error and the battery flashes.
The blinking FEE message means the aperture ring is not set to minimum aperture (highest number). Turn the aperture ring to the highest number, and then find the aperture lock -- either a little slider or a button you press and turn. That will keep it from accidentally changing again.
Dec 31, 2008 | Nikon D1X Digital Camera
F-100 Won't take any shots
fEE blinking is Nikon's error message for cameras that control the aperture from the body instead of the lens. You need to set the lens to the smallest aperture (and lock it there, if the lens has a lock for the aperture setting).
Dec 27, 2007 | Photography
What does the fEE error message displayed on an SLR camera mean?
The "fEE" error indicates that the camera is not communicating with the lens. The lens may not be attached to the camera properly, or if it has an aperture ring, it may not be set to f22 (or the highest aperture number of the lens) - which is normally marked in orange. Select this aperture and lock it using the aperture locking switch to prevent this from occuring again. The fEE error message Set to f22, or the highest aperture number - normally marked in orange. Note the locking switch.
Aug 30, 2005 | Nikon D70 Digital Camera with 18-50mm Lens
Open Questions:
Nikon F65 35mm SLR Camera Logo
81 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
