I have an old Toshiba portable Model no 1510RBT and I cannot program cable into it. Can you help?
  • 8,617 Answers
Sounds like a tuner issue. alot of the older sets can develope solder cracks where they mount to the chassis. Check the solder joints, and if its the twin type tuner check the pins that connect them together. Alot of times resoldering can straighten then out. Hope this helps. Let me know if i can be of further assistance.
Posted on Jan 11, 2008
Trying to hookup vhs analog player to hd proscan
your toshiba player should have output composite video and audio which are color coded Yellow for video, red and white for audio same goes for proscan hdtv. connect between the two keeping in mind color of cables. If the toshiba player is really old you can connect the RF cable output to antenna input to the proscan tv and watch taped programs from the player on channel 3 of the proscan tv. If then you want to keep the hookup and still watch HDTV connect the antenna to the toshiba vcr and when you shut off the vcr you can now watch the hdtv channels as usual because now you are bypassing the antenna to the Proscan tv. Hope this Helps..
Dec 29, 2009 | Proscan 32LB30QD 32 in. LCD TV
Very low sound in my toshiba satellite
that's not surprising all old Toshiba dn't usually have a great sound in fact i'm using an old toshiba right now... there's only one thing you can really do is buy some portable 4.0 speakers...
if you need any help please pm me... =]
Jun 01, 2009 | Toshiba Satellite A45-S150 Notebook
Recording TV programs on DVD Recorder
if you are using a cable box / converter dvd-r and tv must be on ch 3.............
okay you dont have a cable box the tv is set to ch 3....the dvd-r, set up, initial settings and change cable to air...........then channel setting auto (scans all channels except HBO)...now you able to look at a dvd, record your show (s)
feel free to rate if helpful
Mar 02, 2009 | Toshiba DR410 DVD Recorder
Toshiba 42HP66, HDMI problems
Your Cable box might need to be reprogrammed. Call the cable company and they will drive you thru the steps to program it, this way you will get the channels. This process might take you 30-45 minutes.
Artgirlny
Jul 12, 2008 | Toshiba 42HP66 42 in. LCD Television
Unlocking region code
Hi. Same problem re TOSHIBA portable DVD player bought in the USA, model SD-P91SKN. Wonder if anyone found the solution to unlock it to multi-region? Thanks!
Jun 25, 2008 | Toshiba RD-XS34 DVD Player/HDD Recorder
Toshiba sat. 1805-S254
I am currently using the laptop model that you described. Go to toshiba support, click download, click portables, click satellite, and where it says: choose model, click show older models. Type in your satellite model on the search bar, (1805-S254) and click 1805-S254 in the results and hit GO. Now, the second thing from the top of the list of drivers says: BIOS. click the plus. Find: ACPI Flash BIOS version 1.10 for Satellite 1800/1805-S204/254/274 (v1.10; 10-23-2001; 671K)
and click it. Download the file and run it. Now follow the directions to make a BIOS floppy disk. After the disk is created, restart the computer. When the screen that says: Toshiba comes on, hit F12 to boot from a different device. Then it gives you a bunch of options. Hit the letter on the keyboard that tells the computer to boot from floppy disk. Then it should erase your current bios and rewrite the old one in. DO NOT update the BIOS! In the new BIOS, toshiba has a file that DOWNCLOCKS your processor. This is what makes your computer run so slow. Now people have complained that computer has overheated and shutdown but since i've downgraded the BIOS, it's been running just fine! Hope this helps! If it doesn't, email me at: fneoh7832@live.com.
Feb 13, 2008 | Toshiba Satellite 1805-S204 Notebook
Connecting to front inputs of a Toshiba tv
As a replacement for "Dolby Digital DT3 AV cable" can be used a " 3.5mm (mono) to RCA(or coaxal)" Cable.
Just make sure that DVD Player set for "SPDIF/RAW" or "SPDIF/PCM" output
Oct 12, 2007 | GPX PDL805 Portable DVD Player
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
