Question about LG KC910 Renoir Cell Phone
How do i set up my internet on my LG Renoir via WLAN
How do i set up my internet on my LG Renoir (on orange) so that no wifi point/security code is needed?
Flashing WLAN LIGHT ON EDIMAX ROUTER
No, it means it cannot set up a Internet Connection.
Try Powering Off and On again, if not contact your Internet Supplier.
Jan 27, 2013 | Edimax WiFi 150Mbps ADSL2 Modem Router
Tip
Wifi Guide For C3 also other phones
<span><b><u> <span><b><u><img src="vhin100889_25.jpg" /><br /></u></b></span>* How to deal with WLAN (WiFi) *</u></b></span> <span><b><u><br /></u></b></span> <span><b>Setting 1:- Go to Menu &gt; Settings &gt; Connectitvity &gt; WLAN &gt; Internet connection &gt; Ask first<br /><br />- Goto Menu &gt; Settings &gt; Configuration &gt; Default config. settings &gt; myGlobe (or Smart)<br /><br />- Goto Menu &gt; Settings &gt; Configuration &gt; Preffered access point &gt; myGlobe Internet (or Smart Internet)<br /><br />- Goto Menu &gt; Internet &gt; Web settings &gt; Configuration settings &gt; Configuration &gt; myGlobe Internet (or Smart Internet)<br /><br />- Goto Menu &gt; Internet &gt; Web settings &gt; Configuration settings &gt; Account &gt; myGlobe Internet (or Smart Internet)<br /><br />- Select your preferred scanned network, then Connect.<br /><br />- You will notice a WiFi signal logo ..oo)))) on the top screen indicating you're connected.<br /><br />- Go to MENU &gt; Internet &gt; Go to address <i>(and enter the website you want)</i><br /><br />- Done. Enjoy browsing via WiFi.</b><b><br />Setting 2:- Go to Menu &gt; Settings &gt; Configuration &gt; Personal Settings &gt; Add &gt; Access point (leave others as is) &gt; press back &gt; Option &gt; Activate- Goto Menu &gt; Settings &gt; Configuration &gt; Preferred access point &gt; My access point- Go to Menu &gt; Settings &gt; Connectitvity &gt; WLAN &gt; Internet connection &gt; Ask first<br /><br />- Go to Menu &gt; Settings &gt; Connectitvity &gt; WLAN &gt; Available WLANs<br /><br />- Select your preffered connection, then connect.</b><b><br />Note:- Update your phone to the latest firmware, preferrably version 7.20 or higher. Firmware upgrade might solve Web browser bugs and WiFi issues.<br /><br />- Check your WLAN server, you might have a weak WiFi signal.</b></span> <span><b><u><br /></u></b></span>
on Jul 12, 2011 | Cell Phones
I cannot connect my nokia c7 to the internet through wifi
Hi, pls verify below steps,
1.Whether WLAN switched on and has a good WLAN coveage. 2.Security settings on WLAN options
- Check the security modes (Open/WEP/WEP2 - this depends on your WLAN connection) - Check Security settings (Public shared Key settings)
3.You have to be a authorized user in WLAN network if it requires authentication login. 4.Open the browser on you mobile and select General->Connection->Always Ask, then it will prompt for the connection type, Select WLAN.
Thanks, Ramaly
Feb 28, 2011 | Nokia C7 (8 GB) Smartphone
I have wifi connection but no web page apears
make sure your not connected to a wifi connection with a password, or in the interm, just use the internet off 3g if you have it, or edge networks.
Sep 29, 2009 | LG KC910 Renoir Cell Phone
Nokia E61 Wifi connection
setup Internet access point for WLAN menu>tool>settings>connections>access points select options>new access points Enter Connection name Data bearer: select Wireless LAN WLAN network name: select search wlan to select wlan in range. network status: select "public" if you can see wlan in range WLAN network mode: select infrs or adhoc WLAN security mode: select same settings used by WLAN access point WLAN security settings: Homepage: select the homepage you want
now you can connect & browse the internet. hope this helps
Jul 08, 2009 | Nokia E61 Smartphone
Lg kc 910 security key
the default setting for security code on the renoir isnt listed in the manual but is 0000 (four zeroes) which youll need to change the code or access some of the features
Mar 09, 2009 | LG KC910 Renoir Cell Phone
LG Kc910 connectivity to pc/wifi
3845#*910# Master Reset code for lg kc910 , once in do a factory reset
Mar 08, 2009 | LG KC910 Renoir Cell Phone
LG 910 Internet Settings Problem
i had the same problem with my 910 , i rang my service provider and they text me the codes and software to load directly onto my phone , problem fixed straight away !
Feb 06, 2009 | LG KC910 Renoir Cell Phone
I cannot connect to the internet via my wireless network on my acer computer. however i can access it with my 4 other laptops
Please use this tip as check list if any of the mandatory settings is not clear let me know.
Check if you see the network name in your PC. (if you do not see it SSID is not broadcast OR your wireless adapter on Acer is not on same standard (801.11 a / b /g/ n) as your router (Model???).
If you see WLAN, is it secured? (= you need network key ) Please check the security standard of WLAN (WEP, WPA, AES, TKIP) and use accordinly.
If you cannot connec check if an access list is on router and insert your new PC (or disable it)
Jan 29, 2009 | WiFlyer - Portable, shareable WiFi base...
LG KC910 Renoir Cell Phone Logo
230 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
